Support for nVidia GPU acceleration
Ty_Bower
Post Thu Sep 10, 2020 11:00 pm
The nVidia GPU from Pascal generation onward has capable hardware decoders and encoders for both h.264 and h.265 (HEVC) media.
I have some Android tablet devices which are not capable of playing h.265 files directly. They fall back to software decoding (MX Player, VLC) which results in stuttering and heavy battery consumption.
I would very much value the ability to transcode the h.265 source files to h.264 as they are served to my tablet device. I've got a capable nVidia GPU which I would like to use to offload this transcoding, as otherwise it presents quite a burden to the Serviio's CPU.
I've added request #1153 to the bit bucket so that my request may be recorded and prioritized.
Ty_Bower
Post Sat Sep 12, 2020 4:24 pm
Re: Support for nVidia GPU acceleration
I've tested FFmpeg v4.3.1 using an nVidia GTX 1060 graphics board. The setup was quite straight forward, using the Zeranoe build. The command line string was found in an old forum post concerning a similar request for Quick Sync Video (Intel QSV) support. Encoding rate is very good by my standards. The Core i3-2320 processor in this machine can barely muster 0.8x ~ 1.5x, while the GPU can do it in 6x ~ 8x realtime.
J:\Video>ffmpeg.exe -threads 3 -i demo_video.mp4 -y -c:v h264_nvenc -pix_fmt yuv420p -b:v 12000k -maxrate:v 12000k -bufsize:v 12000k -preset:v fast -r 24000/1001 -g 15 -bsf:v h264_mp4toannexb -flags -global_header -c:a:0 ac3 -b:a:0 384k -ac:a:0 6 -map 0:0 -map 0:1 -sn -f mpegts C:\Transcode\Serviio\transcoding-temp-test.stf
ffmpeg version 4.3.1 Copyright (c) 2000-2020 the FFmpeg developers
built with gcc 10.2.1 (GCC) 20200726
configuration: --enable-gpl --enable-version3 --enable-sdl2 --enable-fontconfig --enable-gnutls --enable-iconv --enable-libass --enable-libdav1d --enable-libbluray --enable-libfreetype --enable-libmp3lame --enable-libopencore-amrnb --enable-libopencore-amrwb --enable-libopenjpeg --enable-libopus --enable-libshine --enable-libsnappy --enable-libsoxr --enable-libsrt --enable-libtheora --enable-libtwolame --enable-libvpx --enable-libwavpack --enable-libwebp --enable-libx264 --enable-libx265 --enable-libxml2 --enable-libzimg --enable-lzma --enable-zlib --enable-gmp --enable-libvidstab --enable-libvmaf --enable-libvorbis --enable-libvo-amrwbenc --enable-libmysofa --enable-libspeex --enable-libxvid --enable-libaom --enable-libgsm --enable-librav1e --disable-w32threads --enable-libmfx --enable-ffnvcodec --enable-cuda-llvm --enable-cuvid --enable-d3d11va --enable-nvenc --enable-nvdec --enable-dxva2 --enable-avisynth --enable-libopenmpt --enable-amf
libavutil 56. 51.100 / 56. 51.100
libavcodec 58. 91.100 / 58. 91.100
libavformat 58. 45.100 / 58. 45.100
libavdevice 58. 10.100 / 58. 10.100
libavfilter 7. 85.100 / 7. 85.100
libswscale 5. 7.100 / 5. 7.100
libswresample 3. 7.100 / 3. 7.100
libpostproc 55. 7.100 / 55. 7.100
Input #0, mov,mp4,m4a,3gp,3g2,mj2, from 'demo_video.mp4':
major_brand : isom
minor_version : 512
compatible_brands: isomiso2mp41
creation_time : 2020-03-21T03:45:17.000000Z
title : demo_video
encoder : Lavf58.20.100
comment : demo_video
Duration: 02:03:02.42, start: 0.000000, bitrate: 2229 kb/s
Stream #0:0(und): Video: hevc (Main 10) (hev1 / 0x31766568), yuv420p10le(tv), 1920x804 [SAR 1:1 DAR 160:67], 1999 kb/s, 23.98 fps, 23.98 tbr, 1200k tbn, 23.98 tbc (default)
handler_name : VideoHandler
Stream #0:1(eng): Audio: aac (LC) (mp4a / 0x6134706D), 48000 Hz, 5.1, fltp, 224 kb/s (default)
handler_name : SoundHandler
Stream mapping:
Stream #0:0 -> #0:0 (hevc (native) -> h264 (h264_nvenc))
Stream #0:1 -> #0:1 (aac (native) -> ac3 (native))
Output #0, mpegts, to 'C:\Transcode\Serviio\transcoding-temp-test.stf':
major_brand : isom
minor_version : 512
title : demo_video
encoder : Lavf58.45.100
Stream #0:0(und): Video: h264 (h264_nvenc) (Main), yuv420p, 1920x804 [SAR 1:1 DAR 160:67], q=-1--1, 12000 kb/s, 23.98 fps, 90k tbn, 23.98 tbc (default)
encoder : Lavc58.91.100 h264_nvenc
Side data:
cpb: bitrate max/min/avg: 12000000/0/12000000 buffer size: 12000000 vbv_delay: N/A
Stream #0:1(eng): Audio: ac3, 48000 Hz, 5.1, fltp, 384 kb/s (default)
encoder : Lavc58.91.100 ac3
frame=176996 fps=146 q=9.0 Lsize=10776477kB time=02:03:02.40 bitrate=11958.3kbits/s dup=0 drop=2 speed= 6.1x
video:10130220kB audio:346050kB subtitle:0kB other streams:0kB global headers:0kB muxing overhead: 2.865590%
Ty_Bower
Post Sun Sep 13, 2020 1:08 pm
I have access to a number of different processors and graphics boards, so I did some testing of various encode options with FFmpeg. All CPUs are 4th generation Intel or older (Haswell, circa 2015). The nVidia GPU was released in 2016, but can be purchased today on the used market for around $100. The Radeon RX5700 was released last year (2019) and typically sells for over $300.
My goal is to find a cost effective combination of hardware that offers solid transcoding performance. I am hopeful that support for these GPU accelerated encoders can be added to Serviio in the near future.
Here is a quick summary of results. In all cases, GPU (or iGPU) encoding outperforms CPU encoding. More cores and more threads outperform fewer. Newer generation hardware typically outperforms older, except in cases where other factors (such as core count) weigh heavily.
Haswell i3, CPU 0.835 x
Sandy Bridge i5, CPU 0.861 x
Haswell i7, CPU 1.73 x
Haswell i3, QSV 1.87 x
nVidia GTX 1060 3GB 5.96 x
AMD RX5700 8GB 7.2 x
The same input file was used in all test cases.
All transcodes were performed using:
Core i5-2320 (Sandy Bridge), 4C/4T, 3.0 GHz, libx264 (CPU encode - transcoding aborted due to lack of time)
J:\Video>ffmpeg.exe -threads 3 -i demo_video.mp4 -y -c:v libx264 -pix_fmt yuv420p -b:v 12000k -maxrate:v 12000k -bufsize:v 12000k -preset:v fast -r 24000/1001 -g 15 -bsf:v h264_mp4toannexb -flags -global_header -c:a:0 ac3 -b:a:0 384k -ac:a:0 6 -map 0:0 -map 0:1 -sn -f mpegts C:\Transcode\Serviio\transcoding-libx264.stf
frame=57600 fps= 21 q=-1.0 Lsize= 3640044kB time=00:40:02.49 bitrate=12411.8kbits/s speed=0.861x
video:3426479kB audio:112617kB subtitle:0kB other streams:0kB global headers:0kB muxing overhead: 2.852378%
Core i5-2320, nVidia GTX 1060 3GB (Pascal), h264_nvenc (GPU encode)
J:\Video>ffmpeg.exe -threads 3 -i demo_video.mp4 -y -c:v h264_nvenc -pix_fmt yuv420p -b:v 12000k -maxrate:v 12000k -bufsize:v 12000k -preset:v fast -r 24000/1001 -g 15 -bsf:v h264_mp4toannexb -flags -global_header -c:a:0 ac3 -b:a:0 384k -ac:a:0 6 -map 0:0 -map 0:1 -sn -f mpegts C:\Transcode\Serviio\transcoding-h264_nvenc.stf
frame=176996 fps=143 q=9.0 Lsize=10776477kB time=02:03:02.40 bitrate=11958.3kbits/s dup=0 drop=2 speed=5.96x
Core i3-4170 (Haswell), 2C/4T, 3.7 GHz, libx264 (CPU encode)
E:\Video>ffmpeg.exe -threads 3 -i demo_video.mp4 -y -c:v libx264 -pix_fmt yuv420p -b:v 12000k -maxrate:v 12000k -bufsize:v 12000k -preset:v fast -r 24000/1001 -g 15 -bsf:v h264_mp4toannexb -flags -global_header -c:a:0 ac3 -b:a:0 384k -ac:a:0 6 -map 0:0 -map 0:1 -sn -f mpegts C:\Transcode\Serviio\transcoding-libx264.stf
frame=176996 fps= 20 q=-1.0 Lsize=10904180kB time=02:03:02.40 bitrate=12100.0kbits/s dup=0 drop=2 speed=0.835x
video:10253964kB audio:346050kB subtitle:0kB other streams:0kB global headers:0kB muxing overhead: 2.869495%
Core i3-4170 (Haswell), 2C/4T, 3.7 GHz, h264_qsv (Quick Sync Video encode)
E:\Video>ffmpeg.exe -threads 3 -i demo_video.mp4 -y -c:v h264_qsv -pix_fmt yuv420p -b:v 12000k -maxrate:v 12000k -bufsize:v 12000k -preset:v fast -r 24000/1001 -g 15 -bsf:v h264_mp4toannexb -flags -global_header -c:a:0 ac3 -b:a:0 384k -ac:a:0 6 -map 0:0 -map 0:1 -sn -f mpegts C:\Transcode\Serviio\transcoding-temp.stf
Incompatible pixel format 'yuv420p' for codec 'h264_qsv', auto-selecting format 'nv12'
[mpegts @ 0000005fb0a05a80] Non-monotonous DTS in output stream 0:0; previous: 7508, current: 7508; changing to 7509. This may result in incorrect timestamps in the output file.
frame=176996 fps= 45 q=10.0 Lsize=11477859kB time=02:03:02.40 bitrate=12736.6kbits/s dup=0 drop=2 speed=1.87x
video:10816133kB audio:346050kB subtitle:0kB other streams:0kB global headers:0kB muxing overhead: 2.828080%
Xeon E3-1271 v3 (Haswell, w/o iGPU), 4C/8T, 3.6~4.0 GHz, libx264 (CPU encode)
G:\Video>ffmpeg.exe -threads 3 -i demo_video.mp4 -y -c:v libx264 -pix_fmt yuv420p -b:v 12000k -maxrate:v 12000k -bufsize:v 12000k -preset:v fast -r 24000/1001 -g 15 -bsf:v h264_mp4toannexb -flags -global_header -c:a:0 ac3 -b:a:0 384k -ac:a:0 6 -map 0:0 -map 0:1 -sn -f mpegts G:\Transcode\Serviio\transcoding-libx264.stf
frame=176996 fps= 42 q=-1.0 Lsize=10814763kB time=02:03:02.40 bitrate=12000.8kbits/s dup=0 drop=2 speed=1.73x
video:10166430kB audio:346050kB subtitle:0kB other streams:0kB global headers:0kB muxing overhead: 2.875468%
Xeon E3-1271 v3, AMD Radeon RX5700 8GB (Navi/RDNA1), h264_amf (GPU encode)
G:\Video>ffmpeg.exe -threads 3 -i demo_video.mp4 -y -c:v h264_amf -pix_fmt yuv420p -b:v 12000k -maxrate:v 12000k -bufsize:v 12000k -preset:v fast -r 24000/1001 -g 15 -bsf:v h264_mp4toannexb -flags -global_header -c:a:0 ac3 -b:a:0 384k -ac:a:0 6 -map 0:0 -map 0:1 -sn -f mpegts G:\Transcode\Serviio\transcoding-h264_amf.stf
frame=176996 fps=173 q=-0.0 Lsize=11453620kB time=02:03:02.40 bitrate=12709.7kbits/s dup=0 drop=2 speed= 7.2x
video:10792486kB audio:346050kB subtitle:0kB other streams:0kB global headers:0kB muxing overhead: 2.828779%
GhostNZ
Post Tue Sep 15, 2020 6:56 am
Hopefully this gains traction, GPU's that support transcoding are getting cheaper all the time so it would be a huge feature if it can be included.
My Poor G7 HP Microserver is starting to struggle, might have to get an Nvidia Quadro p400 and run some tests myself..
Post Wed Sep 16, 2020 12:04 pm
Looks good. I'll have a look.
Ty_Bower
Post Wed Sep 16, 2020 12:41 pm
Thanks. Let me know if I can do anything to help test.
Ty_Bower
Post Mon Oct 12, 2020 2:59 pm
Ty_Bower wrote:I've tested FFmpeg v4.3.1 using an nVidia GTX 1060 graphics board. The setup was quite straight forward, using the Zeranoe build.
It seems the Zeranoe site is no longer with us. For the moment, the FFmpeg builds are available here:
http://acyun.org/
Post Mon Oct 12, 2020 10:14 pm
http://acyun.org/
Well, that's a bummer. I'm sure someone will continue to maintain the Windows version.
jg.a
Post Sat Jan 16, 2021 1:23 am
It should be noted (in case you don't know) that the GPU encoded video needs a higher bitrate to look as good as a CPU encode.
Don't know the exact numbers for X264, but for my X265 tests I found that GPU encodes ended up with file-size more than twice the CPU encodes (to get the same quality). So in that regards you should note that this could be un-optimal for limited network and for metered connections. However for most mobiles and tabs with small monitors you probably not be able notice the quality loss if you lower the quality.
For speed the GPU HW-encoder is king, but for quality (and archives) you should avoid it.
Ty_Bower
Post Mon Jan 18, 2021 2:42 pm
jg.a wrote:It should be noted (in case you don't know) that the GPU encoded video needs a higher bitrate to look as good as a CPU encode.
Yes, I am well aware that GPU encode quality falls behind a careful CPU encode. My video is already archived in an acceptable level of quality (for my liking, at least).
I just want to be able to transcode video for playback devices on the local network. Speed and compatible codec is everything for my application. In this case, I expect the Pascal GPU encoder is going to give me more speed than I could possibly muster from the Haswell generation processor, even using Intel QSV. My test encodes have demonstrated this.
I'm looking forward to seeing Serviio version 2.2. Hopefully this feature will be included in that release.
Ty_Bower
Post Thu Jul 01, 2021 10:11 pm
I'm still hoping to see this feature released in the next version... it would still be useful to me.
Ty_Bower
Post Thu Sep 16, 2021 6:17 pm
I've received a couple of bitbucket notifications this feature request has been "Resolved" in version 2.2.
Has anyone seen a download link for the new version yet? I'm quite excited to try it out.
louspag@hotmail.com
Post Mon Oct 04, 2021 1:34 pm
So i read the thread and I can understand the logic in this request. What I don't understand is how to leverage it. Is there something that needs to be turned on or adjusted in the settings or will serviio just make that determination to transcode anything from x265 to x264 depending on profile used for the device?
Lou
Post Mon Oct 04, 2021 11:53 pm
Ty_Bower wrote:I've received a couple of bitbucket notifications this feature request has been "Resolved" in version 2.2.
Version 2.2 was released on Sept 30/Oct 1 (depending on your time zone). But I don't think this made it into the build. 2.2 was mostly to replace TheTVDB with TheMovieDB, since the former was going to require a paid license to work. This is the post announcing 2.2: https://www.serviio.org/news/122-version-2-2-released
d0ng3r
Post Mon Oct 18, 2021 12:07 am
I see the release notes say to enable via useNVidiaAcceleration system property, but nothing really great on just where you set this value. Anyone have luck with this?
Post Tue Oct 26, 2021 1:13 pm
d0ng3r
Post Tue Nov 02, 2021 8:41 pm
Great, thanks!
tomy1992
Post Mon Dec 13, 2021 6:16 pm
Hi guys, can someone post me exactly correct syntax to enable HW acceleration through Nvidia GPU in serviio pro v2.2 installed on windows server 2022?
I add -Dserviio.useNVidiaAcceleration parameter into C:\Program Files\Serviio\config\user.vmoptions file and transcoding is still realized through CPU.
In system is correctly installed Nvidia Quadro P600 2GB with all drivers.
Thanks for any help
Tomas
shan1504
Post Sat Jan 15, 2022 3:13 pm
tomy1992 wrote:Hi guys, can someone post me exactly correct syntax to enable HW acceleration through Nvidia GPU in serviio pro v2.2 installed on windows server 2022?
Thanks for any help
Tomas
I have same problem. HW acceleration doen't work. I have GTX 1660, windows 10 64b.
Zun
Post Sat Apr 15, 2023 11:37 am
I have the same problem.
I opened the user.vmoptions (which was empty) -> entered -Dserviio.useNVidiaAcceleration and saved.
Restarted the PC -> CPU transcoded.
Exchanged the ffmpeg (https://www.gyan.dev/ffmpeg/builds/#git-master-builds) -> old to ffmpeg.bat.
CPU still encoded ...
Any tips ?
( Serviio 2.3 - Nvidia 1030 GDDR5 newest drivers)
Many thanks and best regards
Return to Feature requests
Users browsing this forum: Google [Bot] and 2 guests
