Devices cannot find Serviio
jasonlong75
Post Mon May 03, 2021 12:09 am
Neither device I use with Serviio can find the server. Every couple of weeks, it goes down, and I have to reinstall the software. Today, I reinstalled it FIVE times.
IP Addresses are correct.
No firewall issues.
No router issues.
Everything else I connect to my computer through, or use wifi for, is working perfectly fine. Serviio? No.
A few times, Serviio blinked active on my devices, then disappeared again. It's something with Serviio itself. This is the ONLY program I have issues with, and they've been progressively getting worse over the past few months. I don't want to hear, "It's uh, ur firewall thingy" or "Duz ya got da IP address?" I've checked, double checked, triple checked, and quadruple checked ALL those, plus NO OTHER ISSUES WITH ANY OTHER DEVICE OR SOFTWARE. Serviio needs to be fixed.
I'm sure I won't hear **** back from this, since I called out the BS, but there it is.
Post Mon May 03, 2021 1:48 am
Re: Devices cannot find Serviio
First, what is the OS of your Serviio computer? How is it and your other devices connected to your network: wired, wireless, or a combination? Does your Serviio computer have more than one network adapter (more than one wired connection, wired and wireless, VPN)?
