MediaBrowser download option
chipg07
Post Sat Aug 26, 2023 10:18 am
You should make an option in one of the corners to download the video you are currently watching.
I don't think this should be too difficult and you could probably add it in just a few minutes.
Thanks,
Chip
Post Sat Aug 26, 2023 11:25 pm
Re: MediaBrowser download option
I don't believe the DLNA standard supports file downloading. I did a quick web search and can't find anything that mentions the ability to download the file.
chipg07
Post Mon Oct 09, 2023 8:04 am
I didn't say anything about using DLNA to do it. I said he could add the option to MediaBrowser.....
Return to Feature requests
