Fri Sep 15, 2023 12:46 pm by atc98092
Any updates to the profiles usually have to come from someone with that player. I have no Sony TVs, so have no ability to work on a new profile. But your problem is found on other devices as well. It's not specifically a Sony problem, but unfortunately there's nothing in the Serviio coding that can help either. I can give one example: Roku devices will not FF, rewind, resume, or even pause with media in the TS/M2TS container. The only workaround is to repackage the media into a different format, either manually modifying each file or having Serviio transcode the files. Either way is not a good way to handle it, but the problem lies with the Roku device, not anything Serviio is doing.
The Sony profiles haven't been updated in a very long time, mainly because the Serviio developer doesn't have any of the new sets and no one with one has offered to assist with a new profile. Could a new profile make a difference with your missing playback features? My guess is no, because it sounds like a limitation on the player Sony uses, and anything that Serviio can do would only be a workaround, as I mentioned for the Roku devices.
