Alexa Skill User credentials
aiscifi
Post Thu Nov 03, 2022 9:53 pm
Hi folks, I am having difficulty in linking an alexa skill. I am running the latest version of Serviio (downloaded and installed today). I have media browser and console access. I have opened up the ports and have green checkmarks on both the insecure and secure connectivity checks in the Remote tab. when attempting to link the Alexa Skill, I am using the Serviio ID on the main page and the User ID and Password that I created on the User tab and am successfully logged in with. I have attempted to make the Alexa connection three times and no dice. The error message is: "We were unable to link Serviio at this time."
Any and all suggestions are very much appreciated!
Post Sat Nov 05, 2022 8:56 pm
Re: Alexa Skill User credentials
Do you have the Pro license? The 14 day trial is not enough.
aiscifi
Post Sun Nov 06, 2022 6:35 pm
Yes. I purchased the Pro version and applied the license.
Post Mon Nov 07, 2022 11:13 am
Can you PM me your serviioId and try again to log in and tell me the timestamp of your atempt?
Post Mon Nov 07, 2022 11:14 am
also, I think some users had issues with logging in when used capital letters in the username/password. Try changing it all to lowercase.
Drew3
Post Sun Feb 11, 2024 9:52 pm
I tried lower case and it still doesn't work. Any other ideas. I can log into the media browser and have the green check marks on the remote. I have Pro as well. IDuFJlStWyAK
Still cant link
weston.front
Post Fri Mar 29, 2024 4:35 pm
I am having the same problem and given the One Star rating of this Alexa Skill I was wanting to check out how well it worked before buying the licence. Is there anyway of doing this? I have used Serviio via other platforms and it performed well and was easier to use than Plex so I'm keen to try this out via my Echo and once I'm happy buy a licence. Please advise
Post Sat Mar 30, 2024 10:36 pm
Every time Serviio is installed/updated, you get a 15-day trial of the Pro version. I am not certain if you reinstall the same version if you get the trial.
