Re: WTV and/or DVR-MS files?
Is this because full WTV support is not in 0.5.2 yet, or do I have some other problem. If it is not in 0.5.2, when do you think it will be in working version?
Any other assitance would be appreciated.
Matthew
swainstm wrote:From my limited knowledge, it looks to be failing. I could even see that without the debugging.
As requested, I have turned on the debugging and have attached both the serviio log. I have dug out what I assume is the problematic ffmpeg command, and run this manually with both the serviio ffmpeg and another later version I have, and uploaded the output from this in ffmpeg-output.txt. This was all done on a smaller bb.wtv file that I made, and was done at around 2011-06-03 10:48:27.
I am not a video or ffmpeg expert, but hopefully this all makes sense to you and you can give further direction to resolve this.
Once again thanks for your excellent support.
Matthew
lightsailpro wrote:rcooper5908, could you post your ffmpeg.exe file which can fix "mpeg_decode_postinit() failure" error? Thanks.
zip wrote:I've tried your example with the ffmpeg I have and it successfully remuxed into mpegts. I'll include the support for a next version.
https://bitbucket.org/xnejp03/serviio/i ... -wtv-files
