Frequent disconnects even when not playing media
sdobron
Post Mon Aug 29, 2011 2:37 am
I have recently installed serviio after using windows 7's built in DLNA client for about 6 months. During this time I never had one signal drop, however with Serviio it happens anywhere from 5 minutes to 15 minutes after establishing connection with no rhyme or reason.
I am not using the network for anything but DLNA during this time. I have a Samsung C5500 and a Verizon FiOS wireless router.
Someone please assist in diagnosing my problem.
Post Mon Aug 29, 2011 4:12 am
Re: Frequent disconnects even when not playing media
can you post the serviio.log file. Also run the tool from this link to make sure no-one else is using the same channel as you are on your wireless router.
http://forum.serviio.org/viewtopic.php?f=17&t=2439
sdobron
Post Mon Aug 29, 2011 1:29 pm
Lost the log file when I uninstalled and reinstalled to see if that fixed anything...
However, I changed my wifi channel to 8 and turned off the hardware firewall and it seems like it may have fixed the problem.
Will post back if I have another disconnect and can pull the log file.
edit: Had a disconnect after about 10 minutes of play this time.
2011-08-29 01:09:35,119 INFO  [MediaServer] ------------------------------------------------------------------------
2011-08-29 01:09:35,143 INFO  [MediaServer] Serviio DLNA media streaming server v 0.5.2 (rev. 4e3210bd9ff3)
2011-08-29 01:09:35,143 INFO  [MediaServer] Petr Nejedly 2009-2011
2011-08-29 01:09:35,143 INFO  [MediaServer] http://www.serviio.org
2011-08-29 01:09:35,143 INFO  [MediaServer] Java 1.6.0_25-Sun Microsystems Inc.
2011-08-29 01:09:35,143 INFO  [MediaServer] OS Windows 7 amd64 6.1
2011-08-29 01:09:35,143 INFO  [MediaServer] File encoding: windows-1252
2011-08-29 01:09:35,143 INFO  [MediaServer] ------------------------------------------------------------------------
2011-08-29 01:09:35,681 INFO  [RestletServer] Starting Restlet server exposed on localhost:23423
2011-08-29 01:09:35,971 INFO  [DBSchemaUpdateExecutor] Checking if DB schema needs to be updated
2011-08-29 01:09:38,653 INFO  [DBSchemaUpdateExecutor] Updating DB schema
2011-08-29 01:09:41,102 INFO  [ProfilesDefinitionParser] Parsing Profiles definition
2011-08-29 01:09:41,462 INFO  [ProfilesDefinitionParser] Added profile 'Generic DLNA profile' (id=1)
2011-08-29 01:09:41,551 INFO  [ProfilesDefinitionParser] Added profile 'Samsung TV (B-series)' (id=2)
2011-08-29 01:09:41,600 INFO  [ProfilesDefinitionParser] Added profile 'XBox 360' (id=3)
2011-08-29 01:09:41,633 INFO  [ProfilesDefinitionParser] Added profile 'Playstation 3' (id=4)
2011-08-29 01:09:41,681 INFO  [ProfilesDefinitionParser] Added profile 'Samsung TV (A-series)' (id=5)
2011-08-29 01:09:41,708 INFO  [ProfilesDefinitionParser] Added profile 'DirecTV HD-DVR' (id=6)
2011-08-29 01:09:41,786 INFO  [ProfilesDefinitionParser] Added profile 'Samsung TV / player (C/D-series)' (id=7)
2011-08-29 01:09:41,808 INFO  [ProfilesDefinitionParser] Added profile 'LG BD player' (id=8)
2011-08-29 01:09:41,920 INFO  [ProfilesDefinitionParser] Added profile 'Sony Bravia TV' (id=9)
2011-08-29 01:09:42,091 INFO  [ProfilesDefinitionParser] Added profile 'Sony BD Player' (id=10)
2011-08-29 01:09:42,138 INFO  [ProfilesDefinitionParser] Added profile 'Panasonic Viera' (id=12)
2011-08-29 01:09:42,204 INFO  [ProfilesDefinitionParser] Added profile 'Toshiba Rezga' (id=13)
2011-08-29 01:09:42,492 INFO  [AbstractTranscodingDeliveryEngine] Cleaning transcode engine and its data
2011-08-29 01:09:42,507 INFO  [WebServer] Socket buffer set to 65535 bytes
2011-08-29 01:09:42,584 INFO  [WebServer] WebServer starting on port 8895
2011-08-29 01:09:42,998 INFO  [Device] Created UPnP Device with UUID: 92364609-eb74-3e48-a97f-fb1c988d0a03, bound address: 192.168.1.3
2011-08-29 01:09:43,033 INFO  [CompositeCacheManager] Creating cache manager from config file: /cache.ccf
2011-08-29 01:09:43,041 INFO  [ThreadPoolManager] thread_pool.default PoolConfiguration = useBoundary = [true] boundarySize = [2000] maximumPoolSize = [150] minimumPoolSize = [4] keepAliveTime = [300000] whenBlockedPolicy = [RUN] startUpSize = [4]
2011-08-29 01:09:43,045 INFO  [CompositeCacheConfigurator] Setting default auxiliaries to null
2011-08-29 01:09:43,045 INFO  [CompositeCacheConfigurator] No special CompositeCacheAttributes class defined for key [jcs.default.cacheattributes], using default class.
2011-08-29 01:09:43,047 INFO  [CompositeCacheConfigurator] setting defaultCompositeCacheAttributes to [ useLateral = true, useRemote = true, useDisk = true, maxObjs = 100, maxSpoolPerRun = -1, diskUsagePattern = 0 ]
2011-08-29 01:09:43,047 INFO  [CompositeCacheConfigurator] No special ElementAttribute class defined for key [jcs.default.elementattributes], using default class.
2011-08-29 01:09:43,047 INFO  [CompositeCacheConfigurator] setting defaultElementAttributes to [ IS_LATERAL = true, IS_SPOOL = true, IS_REMOTE = true, IS_ETERNAL = true, MaxLifeSeconds = -1, IdleTime = -1, CreateTime = 1314594583047, LastAccessTime = 1314594583047, getTimeToLiveSeconds() = -1, createTime = 1314594583047 ]
2011-08-29 01:09:43,049 INFO  [CompositeCacheConfigurator] No special ElementAttribute class defined for key [jcs.region.local_resetafterplay.elementattributes], using default class.
2011-08-29 01:09:43,057 INFO  [LRUMemoryCache] initialized LRUMemoryCache for local_resetafterplay
2011-08-29 01:09:43,057 INFO  [CompositeCache] Constructed cache with name [local_resetafterplay] and cache attributes [ useLateral = true, useRemote = true, useDisk = true, maxObjs = 1000, maxSpoolPerRun = -1, diskUsagePattern = 0 ]
2011-08-29 01:09:43,057 INFO  [CompositeCacheConfigurator] No special ElementAttribute class defined for key [jcs.region.local_default.elementattributes], using default class.
2011-08-29 01:09:43,057 INFO  [LRUMemoryCache] initialized LRUMemoryCache for local_default
2011-08-29 01:09:43,058 INFO  [CompositeCache] Constructed cache with name [local_default] and cache attributes [ useLateral = true, useRemote = true, useDisk = true, maxObjs = 1000, maxSpoolPerRun = -1, diskUsagePattern = 0 ]
2011-08-29 01:09:43,058 INFO  [CompositeCacheConfigurator] Parsed regions [local_resetafterplay, local_default]
2011-08-29 01:09:43,058 INFO  [CompositeCacheConfigurator] Finished configuration in 15 ms.
2011-08-29 01:09:43,059 INFO  [EventSubscriptionExpirationChecker] Starting EventSubscriptionExpirationChecker
2011-08-29 01:09:43,060 INFO  [EventDispatcher] Starting EventDispatcher
2011-08-29 01:09:43,060 INFO  [DiscoveryAdvertisementNotifier] Starting DiscoveryAdvertisementNotifier
2011-08-29 01:09:43,063 INFO  [RendererSearchSender] Searching for Renderer devices
2011-08-29 01:09:43,063 INFO  [RendererExpirationChecker] Starting RendererExpirationChecker
2011-08-29 01:09:43,112 INFO  [DiscoverySSDPMessageListener] Starting DiscoverySSDPMessageListener using interface net3 (Intel(R) Centrino(R) Advanced-N 6250 AGN) and address 192.168.1.3, timeout = 0
2011-08-29 01:09:43,533 INFO  [RendererManager] Stored a new renderer: uuid='fd4c70af-e1d7-4c7a-83f4-2e1d8c7c48ef', name = 'Unrecognized device', ipAddress='192.168.1.3', profile = '1'
2011-08-29 01:10:09,478 INFO  [LibraryAdditionsCheckerThread] Started looking for newly added files
2011-08-29 01:10:09,488 INFO  [LibraryUpdatesCheckerThread] Started looking for updates to currently shared files
2011-08-29 01:12:22,999 INFO  [ServiioConsole] Starting Serviio Console
2011-08-29 01:12:23,536 INFO  [ServiioConsole] Connecting to Serviio REST on localhost:23423
2011-08-29 01:12:24,920 INFO  [Messages] Loaded console message bundle for locale: en
2011-08-29 01:12:26,031 INFO  [Messages] Loaded console message bundle for locale: en
2011-08-29 01:12:26,161 INFO  [UpdateChecker] Checking if a new version is available
2011-08-29 01:12:32,583 INFO  [ContentDirectoryDefinitionParser] Parsing ContentDirectory definition
2011-08-29 01:12:32,856 INFO  [BrowsingCategoriesMessages] Loaded browsing categories message bundle for locale: en
2011-08-29 01:36:07,203 INFO  [LibraryAdditionsCheckerThread] Finished looking for newly added files
2011-08-29 01:36:07,444 INFO  [LibraryAdditionsCheckerThread] Started looking for newly added files
2011-08-29 01:36:07,444 INFO  [LibraryUpdatesCheckerThread] Started looking for updates to currently shared files
2011-08-29 01:36:15,725 INFO  [LibraryAdditionsCheckerThread] Added file 'VTS_01_0.VOB' (title: VTS_01_0) to Library
2011-08-29 01:36:20,494 INFO  [LibraryAdditionsCheckerThread] Finished looking for newly added files
2011-08-29 01:36:20,699 INFO  [LibraryAdditionsCheckerThread] Started looking for newly added files
2011-08-29 01:36:20,700 INFO  [LibraryUpdatesCheckerThread] Started looking for updates to currently shared files
2011-08-29 01:36:20,914 INFO  [LibraryAdditionsCheckerThread] Added file 'VTS_01_1.VOB' (title: VTS_01_1) to Library
2011-08-29 01:36:20,984 INFO  [LibraryUpdatesCheckerThread] Updated 'VTS_01_0' (E:\Movies\Anathema - (2004) - Were You There\VIDEO_TS\VTS_01_0.VOB) in Library
2011-08-29 01:36:21,189 INFO  [LibraryAdditionsCheckerThread] Added file 'VTS_01_2.VOB' (title: VTS_01_2) to Library
2011-08-29 01:36:21,428 INFO  [LibraryAdditionsCheckerThread] Added file 'VTS_01_3.VOB' (title: VTS_01_3) to Library
2011-08-29 01:36:21,714 INFO  [LibraryAdditionsCheckerThread] Added file 'VTS_01_4.VOB' (title: VTS_01_4) to Library
2011-08-29 01:36:21,925 INFO  [LibraryAdditionsCheckerThread] Added file 'VTS_02_1.VOB' (title: VTS_02_1) to Library
2011-08-29 01:36:22,150 INFO  [LibraryAdditionsCheckerThread] Added file 'VTS_03_1.VOB' (title: VTS_03_1) to Library
2011-08-29 01:36:22,367 INFO  [LibraryAdditionsCheckerThread] Added file 'VTS_04_1.VOB' (title: VTS_04_1) to Library
2011-08-29 01:36:22,572 INFO  [LibraryAdditionsCheckerThread] Added file 'VTS_05_1.VOB' (title: VTS_05_1) to Library
2011-08-29 01:36:23,104 INFO  [LibraryAdditionsCheckerThread] Added file 'Battle for Haditha (HD).m4v' (title: Battle for Haditha (HD)) to Library
2011-08-29 01:36:23,385 INFO  [LibraryAdditionsCheckerThread] Added file 'Big Fish (2003) (Serabi).avi' (title: Big Fish (2003) (Serabi)) to Library
2011-08-29 01:36:23,685 INFO  [LibraryAdditionsCheckerThread] Added file 'binjip.m4v' (title: binjip) to Library
2011-08-29 01:36:23,931 INFO  [LibraryAdditionsCheckerThread] Added file 'Black Swan.avi' (title: Black Swan) to Library
2011-08-29 01:36:24,213 INFO  [LibraryAdditionsCheckerThread] Added file 'Limitless.2011.DVDrip.avi' (title: Limitless.2011.DVDrip) to Library
2011-08-29 01:36:24,555 INFO  [LibraryAdditionsCheckerThread] Added file 'VIDEO_TS.VOB' (title: VIDEO_TS) to Library
2011-08-29 01:36:24,672 INFO  [LibraryAdditionsCheckerThread] Added file 'VTS_01_0.VOB' (title: VTS_01_0) to Library
2011-08-29 01:36:25,149 INFO  [LibraryAdditionsCheckerThread] Added file 'VTS_02_1.VOB' (title: VTS_02_1) to Library
2011-08-29 01:36:25,518 INFO  [LibraryAdditionsCheckerThread] Added file 'VTS_02_2.VOB' (title: VTS_02_2) to Library
2011-08-29 01:36:25,906 INFO  [LibraryAdditionsCheckerThread] Added file 'VTS_02_3.VOB' (title: VTS_02_3) to Library
2011-08-29 01:36:26,256 INFO  [LibraryAdditionsCheckerThread] Added file 'VTS_02_4.VOB' (title: VTS_02_4) to Library
2011-08-29 01:36:26,617 INFO  [LibraryAdditionsCheckerThread] Added file 'VTS_02_5.VOB' (title: VTS_02_5) to Library
2011-08-29 01:36:26,909 INFO  [LibraryAdditionsCheckerThread] Added file 'VTS_02_6.VOB' (title: VTS_02_6) to Library
2011-08-29 01:36:27,143 INFO  [LibraryAdditionsCheckerThread] Added file 'VTS_03_1.VOB' (title: VTS_03_1) to Library
2011-08-29 01:36:27,564 INFO  [LibraryAdditionsCheckerThread] Added file 'VTS_01_0.VOB' (title: VTS_01_0) to Library
2011-08-29 01:36:27,968 INFO  [LibraryAdditionsCheckerThread] Added file 'VTS_02_1.VOB' (title: VTS_02_1) to Library
2011-08-29 01:36:28,257 INFO  [LibraryAdditionsCheckerThread] Added file 'VTS_02_2.VOB' (title: VTS_02_2) to Library
2011-08-29 01:36:28,553 INFO  [LibraryAdditionsCheckerThread] Added file 'VTS_02_3.VOB' (title: VTS_02_3) to Library
2011-08-29 01:36:28,855 INFO  [LibraryAdditionsCheckerThread] Added file 'VTS_02_4.VOB' (title: VTS_02_4) to Library
2011-08-29 01:36:29,022 INFO  [LibraryAdditionsCheckerThread] Added file 'VTS_03_1.VOB' (title: VTS_03_1) to Library
2011-08-29 01:36:29,227 INFO  [LibraryAdditionsCheckerThread] Added file 'VTS_04_1.VOB' (title: VTS_04_1) to Library
2011-08-29 01:36:29,492 INFO  [LibraryAdditionsCheckerThread] Added file 'VTS_05_1.VOB' (title: VTS_05_1) to Library
2011-08-29 01:36:29,705 INFO  [LibraryAdditionsCheckerThread] Added file 'VTS_06_1.VOB' (title: VTS_06_1) to Library
2011-08-29 01:36:30,218 INFO  [LibraryAdditionsCheckerThread] Added file 'Religulous.avi' (title: Religulous) to Library
2011-08-29 01:36:30,344 INFO  [LibraryAdditionsCheckerThread] Added file 'VIDEO_TS.VOB' (title: VIDEO_TS) to Library
2011-08-29 01:36:30,714 INFO  [LibraryAdditionsCheckerThread] Added file 'VTS_01_1.VOB' (title: VTS_01_1) to Library
2011-08-29 01:36:30,981 INFO  [LibraryAdditionsCheckerThread] Added file 'VTS_01_2.VOB' (title: VTS_01_2) to Library
2011-08-29 01:36:31,273 INFO  [LibraryAdditionsCheckerThread] Added file 'VTS_01_3.VOB' (title: VTS_01_3) to Library
2011-08-29 01:36:31,653 INFO  [LibraryAdditionsCheckerThread] Added file 'Sanctum 2011 R5 H264 [Eng] johno70.mp4' (title: Sanctum 2011 R5 H264 [Eng] johno70) to Library
2011-08-29 01:36:31,834 INFO  [LibraryAdditionsCheckerThread] Added file 'South Park S14 E01.avi' (title: South Park S14 E01) to Library
2011-08-29 01:36:31,995 INFO  [LibraryAdditionsCheckerThread] Added file 'South Park S14 E02.avi' (title: South Park S14 E02) to Library
2011-08-29 01:36:32,135 INFO  [LibraryAdditionsCheckerThread] Added file 'South Park S14 E03.avi' (title: South Park S14 E03) to Library
2011-08-29 01:36:32,289 INFO  [LibraryAdditionsCheckerThread] Added file 'South Park S14 E04.avi' (title: South Park S14 E04) to Library
2011-08-29 01:36:32,428 INFO  [LibraryAdditionsCheckerThread] Added file 'South Park S14 E05.avi' (title: South Park S14 E05) to Library
2011-08-29 01:36:32,570 INFO  [LibraryAdditionsCheckerThread] Added file 'South Park S14 E06.avi' (title: South Park S14 E06) to Library
2011-08-29 01:36:32,715 INFO  [LibraryAdditionsCheckerThread] Added file 'South Park S14 E07.avi' (title: South Park S14 E07) to Library
2011-08-29 01:36:32,862 INFO  [LibraryAdditionsCheckerThread] Added file 'South Park S14 E08.avi' (title: South Park S14 E08) to Library
2011-08-29 01:36:33,002 INFO  [LibraryAdditionsCheckerThread] Added file 'South Park S14 E09.avi' (title: South Park S14 E09) to Library
2011-08-29 01:36:33,149 INFO  [LibraryAdditionsCheckerThread] Added file 'South Park S14 E10.avi' (title: South Park S14 E10) to Library
2011-08-29 01:36:33,287 INFO  [LibraryAdditionsCheckerThread] Added file 'South Park S14 E11.avi' (title: South Park S14 E11) to Library
2011-08-29 01:36:33,429 INFO  [LibraryAdditionsCheckerThread] Added file 'South Park S14 E12.avi' (title: South Park S14 E12) to Library
2011-08-29 01:36:33,567 INFO  [LibraryAdditionsCheckerThread] Added file 'South Park S14 E13.avi' (title: South Park S14 E13) to Library
2011-08-29 01:36:33,707 INFO  [LibraryAdditionsCheckerThread] Added file 'South Park S14 E14.avi' (title: South Park S14 E14) to Library
2011-08-29 01:36:33,937 INFO  [LibraryAdditionsCheckerThread] Added file 'Taken [2008].avi' (title: Taken [2008]) to Library
2011-08-29 01:36:34,148 INFO  [LibraryAdditionsCheckerThread] Added file 'The Fighter (2010)[DVDRip][big_dad_e™].avi' (title: The Fighter (2010)[DVDRip][big_dad_e™]) to Library
2011-08-29 01:36:34,333 INFO  [LibraryAdditionsCheckerThread] Added file '1-1. Pilot.avi' (title: 1-1. Pilot) to Library
2011-08-29 01:36:34,477 INFO  [LibraryAdditionsCheckerThread] Added file '1-2. Diversity Day.avi' (title: 1-2. Diversity Day) to Library
2011-08-29 01:36:34,632 INFO  [LibraryAdditionsCheckerThread] Added file '1-3. Health Care.avi' (title: 1-3. Health Care) to Library
2011-08-29 01:36:34,778 INFO  [LibraryAdditionsCheckerThread] Added file '4. The Alliance.avi' (title: 4. The Alliance) to Library
2011-08-29 01:36:34,916 INFO  [LibraryAdditionsCheckerThread] Added file '5. Basketball.avi' (title: 5. Basketball) to Library
2011-08-29 01:36:35,050 INFO  [LibraryAdditionsCheckerThread] Added file '6. Hot Girl.avi' (title: 6. Hot Girl) to Library
2011-08-29 01:36:35,217 INFO  [LibraryAdditionsCheckerThread] Added file '1. The Dundies.avi' (title: 1. The Dundies) to Library
2011-08-29 01:36:35,366 INFO  [LibraryAdditionsCheckerThread] Added file '10. Christmas Party.avi' (title: 10. Christmas Party) to Library
2011-08-29 01:36:35,510 INFO  [LibraryAdditionsCheckerThread] Added file '11. Booze Cruise.avi' (title: 11. Booze Cruise) to Library
2011-08-29 01:36:35,662 INFO  [LibraryAdditionsCheckerThread] Added file '12. The Injury.avi' (title: 12. The Injury) to Library
2011-08-29 01:36:35,802 INFO  [LibraryAdditionsCheckerThread] Added file '13. The Secret.avi' (title: 13. The Secret) to Library
2011-08-29 01:36:35,948 INFO  [LibraryAdditionsCheckerThread] Added file '14. The Carpet.avi' (title: 14. The Carpet) to Library
2011-08-29 01:36:36,090 INFO  [LibraryAdditionsCheckerThread] Added file '15. Boys and Girls.avi' (title: 15. Boys and Girls) to Library
2011-08-29 01:36:36,228 INFO  [LibraryAdditionsCheckerThread] Added file '16.  Valentine's Day.avi' (title: 16.  Valentine's Day) to Library
2011-08-29 01:36:36,380 INFO  [LibraryAdditionsCheckerThread] Added file '17. Dwight's Speech.avi' (title: 17. Dwight's Speech) to Library
2011-08-29 01:36:36,532 INFO  [LibraryAdditionsCheckerThread] Added file '18. Take Your Daughter to Work Day.avi' (title: 18. Take Your Daughter to Work Day) to Library
2011-08-29 01:36:36,671 INFO  [LibraryAdditionsCheckerThread] Added file '19. Michael's Birthday.avi' (title: 19. Michael's Birthday) to Library
2011-08-29 01:36:36,812 INFO  [LibraryAdditionsCheckerThread] Added file '2. Sexual Harassment.avi' (title: 2. Sexual Harassment) to Library
2011-08-29 01:36:36,968 INFO  [LibraryAdditionsCheckerThread] Added file '20. Drug Testing.avi' (title: 20. Drug Testing) to Library
2011-08-29 01:36:37,099 INFO  [LibraryAdditionsCheckerThread] Added file '21. Conflict Resolution.avi' (title: 21. Conflict Resolution) to Library
2011-08-29 01:36:37,241 INFO  [LibraryAdditionsCheckerThread] Added file '22. Casino Night.avi' (title: 22. Casino Night) to Library
2011-08-29 01:36:37,369 INFO  [LibraryAdditionsCheckerThread] Added file '3. Office Olympics.avi' (title: 3. Office Olympics) to Library
2011-08-29 01:36:37,507 INFO  [LibraryAdditionsCheckerThread] Added file '4. The Fire.avi' (title: 4. The Fire) to Library
2011-08-29 01:36:37,649 INFO  [LibraryAdditionsCheckerThread] Added file '5. Halloween.avi' (title: 5. Halloween) to Library
2011-08-29 01:36:37,780 INFO  [LibraryAdditionsCheckerThread] Added file '6. The Fight.avi' (title: 6. The Fight) to Library
2011-08-29 01:36:37,920 INFO  [LibraryAdditionsCheckerThread] Added file '7. The Client.avi' (title: 7. The Client) to Library
2011-08-29 01:36:38,051 INFO  [LibraryAdditionsCheckerThread] Added file '8. Performance Review.avi' (title: 8. Performance Review) to Library
2011-08-29 01:36:38,190 INFO  [LibraryAdditionsCheckerThread] Added file '9. EMail Surveillance.avi' (title: 9. EMail Surveillance) to Library
2011-08-29 01:36:38,355 INFO  [LibraryAdditionsCheckerThread] Added file '1. Gay Witch Hunt.avi' (title: 1. Gay Witch Hunt) to Library
2011-08-29 01:36:38,528 INFO  [LibraryAdditionsCheckerThread] Added file '10. A Benihana Christmas.avi' (title: 10. A Benihana Christmas) to Library
2011-08-29 01:36:38,662 INFO  [LibraryAdditionsCheckerThread] Added file '11. Back from Vacation.avi' (title: 11. Back from Vacation) to Library
2011-08-29 01:36:38,808 INFO  [LibraryAdditionsCheckerThread] Added file '12. Traveling Salesman.avi' (title: 12. Traveling Salesman) to Library
2011-08-29 01:36:38,942 INFO  [LibraryAdditionsCheckerThread] Added file '13. The Return.avi' (title: 13. The Return) to Library
2011-08-29 01:36:39,079 INFO  [LibraryAdditionsCheckerThread] Added file '14. Ben Franklin.avi' (title: 14. Ben Franklin) to Library
2011-08-29 01:36:39,210 INFO  [LibraryAdditionsCheckerThread] Added file '15. Phyllis' Wedding.avi' (title: 15. Phyllis' Wedding) to Library
2011-08-29 01:36:39,348 INFO  [LibraryAdditionsCheckerThread] Added file '16.  Business School.avi' (title: 16.  Business School) to Library
2011-08-29 01:36:39,475 INFO  [LibraryAdditionsCheckerThread] Added file '17. Cocktails.avi' (title: 17. Cocktails) to Library
2011-08-29 01:36:39,659 INFO  [LibraryAdditionsCheckerThread] Added file '18. The Negotiation.avi' (title: 18. The Negotiation) to Library
2011-08-29 01:36:39,798 INFO  [LibraryAdditionsCheckerThread] Added file '19. Safety Training.avi' (title: 19. Safety Training) to Library
2011-08-29 01:36:39,939 INFO  [LibraryAdditionsCheckerThread] Added file '2. The Convention.avi' (title: 2. The Convention) to Library
2011-08-29 01:36:40,076 INFO  [LibraryAdditionsCheckerThread] Added file '20. Product Recall.avi' (title: 20. Product Recall) to Library
2011-08-29 01:36:40,226 INFO  [LibraryAdditionsCheckerThread] Added file '21. Women's Appreciation.avi' (title: 21. Women's Appreciation) to Library
2011-08-29 01:36:40,375 INFO  [LibraryAdditionsCheckerThread] Added file '22. Beach Games.avi' (title: 22. Beach Games) to Library
2011-08-29 01:36:40,547 INFO  [LibraryAdditionsCheckerThread] Added file '23. The Job.avi' (title: 23. The Job) to Library
2011-08-29 01:36:40,675 INFO  [LibraryAdditionsCheckerThread] Added file '3. The Coup.avi' (title: 3. The Coup) to Library
2011-08-29 01:36:40,813 INFO  [LibraryAdditionsCheckerThread] Added file '4. Grief Counseling.avi' (title: 4. Grief Counseling) to Library
2011-08-29 01:36:40,950 INFO  [LibraryAdditionsCheckerThread] Added file '5. Initiation.avi' (title: 5. Initiation) to Library
2011-08-29 01:36:41,110 INFO  [LibraryAdditionsCheckerThread] Added file '6. Diwali.avi' (title: 6. Diwali) to Library
2011-08-29 01:36:41,259 INFO  [LibraryAdditionsCheckerThread] Added file '7. Branch Closing.avi' (title: 7. Branch Closing) to Library
2011-08-29 01:36:41,404 INFO  [LibraryAdditionsCheckerThread] Added file '8. The Merger.avi' (title: 8. The Merger) to Library
2011-08-29 01:36:41,567 INFO  [LibraryAdditionsCheckerThread] Added file '9. The Convict.avi' (title: 9. The Convict) to Library
2011-08-29 01:36:41,763 INFO  [LibraryAdditionsCheckerThread] Added file '1. Fun Run.avi' (title: 1. Fun Run) to Library
2011-08-29 01:36:41,902 INFO  [LibraryAdditionsCheckerThread] Added file '10. The Chair Model.avi' (title: 10. The Chair Model) to Library
2011-08-29 01:36:42,037 INFO  [LibraryAdditionsCheckerThread] Added file '11. Night Out.avi' (title: 11. Night Out) to Library
2011-08-29 01:36:42,181 INFO  [LibraryAdditionsCheckerThread] Added file '12. Did I Stutter.avi' (title: 12. Did I Stutter) to Library
2011-08-29 01:36:42,312 INFO  [LibraryAdditionsCheckerThread] Added file '13. Job Fair.avi' (title: 13. Job Fair) to Library
2011-08-29 01:36:42,495 INFO  [LibraryAdditionsCheckerThread] Added file '14. Goodbye, Toby.avi' (title: 14. Goodbye, Toby) to Library
2011-08-29 01:36:42,669 INFO  [LibraryAdditionsCheckerThread] Added file '2. Dunder Mifflin Infinity.avi' (title: 2. Dunder Mifflin Infinity) to Library
2011-08-29 01:36:42,844 INFO  [LibraryAdditionsCheckerThread] Added file '3. Launch Party.avi' (title: 3. Launch Party) to Library
2011-08-29 01:36:43,026 INFO  [LibraryAdditionsCheckerThread] Added file '4. Money.avi' (title: 4. Money) to Library
2011-08-29 01:36:43,166 INFO  [LibraryAdditionsCheckerThread] Added file '5. Local Ad.avi' (title: 5. Local Ad) to Library
2011-08-29 01:36:43,307 INFO  [LibraryAdditionsCheckerThread] Added file '6. Branch Wars.avi' (title: 6. Branch Wars) to Library
2011-08-29 01:36:43,463 INFO  [LibraryAdditionsCheckerThread] Added file '7. Survivor Man.avi' (title: 7. Survivor Man) to Library
2011-08-29 01:36:43,599 INFO  [LibraryAdditionsCheckerThread] Added file '8. The Deposition.avi' (title: 8. The Deposition) to Library
2011-08-29 01:36:43,740 INFO  [LibraryAdditionsCheckerThread] Added file '9. Dinner Party.avi' (title: 9. Dinner Party) to Library
2011-08-29 01:36:43,995 INFO  [LibraryAdditionsCheckerThread] Added file '1. Weight Loss.avi' (title: 1. Weight Loss) to Library
2011-08-29 01:36:44,151 INFO  [LibraryAdditionsCheckerThread] Added file '10. Moroccan Christmas.avi' (title: 10. Moroccan Christmas) to Library
2011-08-29 01:36:44,291 INFO  [LibraryAdditionsCheckerThread] Added file '11. The Duel.avi' (title: 11. The Duel) to Library
2011-08-29 01:36:44,427 INFO  [LibraryAdditionsCheckerThread] Added file '12. Prince Family Paper.avi' (title: 12. Prince Family Paper) to Library
2011-08-29 01:36:44,597 INFO  [LibraryAdditionsCheckerThread] Added file '13. Stress Relief.avi' (title: 13. Stress Relief) to Library
2011-08-29 01:36:44,733 INFO  [LibraryAdditionsCheckerThread] Added file '14. Lecture Circuit Part 1.avi' (title: 14. Lecture Circuit Part 1) to Library
2011-08-29 01:36:44,867 INFO  [LibraryAdditionsCheckerThread] Added file '15. Lecture Circuit Part 2.avi' (title: 15. Lecture Circuit Part 2) to Library
2011-08-29 01:36:45,002 INFO  [LibraryAdditionsCheckerThread] Added file '16. Blood Drive.avi' (title: 16. Blood Drive) to Library
2011-08-29 01:36:45,133 INFO  [LibraryAdditionsCheckerThread] Added file '17. Golden Ticket.avi' (title: 17. Golden Ticket) to Library
2011-08-29 01:36:45,276 INFO  [LibraryAdditionsCheckerThread] Added file '18. New Boss.avi' (title: 18. New Boss) to Library
2011-08-29 01:36:45,412 INFO  [LibraryAdditionsCheckerThread] Added file '19. Two Weeks.avi' (title: 19. Two Weeks) to Library
2011-08-29 01:36:45,551 INFO  [LibraryAdditionsCheckerThread] Added file '2. Business Ethics.avi' (title: 2. Business Ethics) to Library
2011-08-29 01:36:45,690 INFO  [LibraryAdditionsCheckerThread] Added file '20. Dream Team.avi' (title: 20. Dream Team) to Library
2011-08-29 01:36:45,840 INFO  [LibraryAdditionsCheckerThread] Added file '21. The Michael Scott Paper Company.avi' (title: 21. The Michael Scott Paper Company) to Library
2011-08-29 01:36:45,977 INFO  [LibraryAdditionsCheckerThread] Added file '22. Heavy Competition.avi' (title: 22. Heavy Competition) to Library
2011-08-29 01:36:46,112 INFO  [LibraryAdditionsCheckerThread] Added file '23. Broke.avi' (title: 23. Broke) to Library
2011-08-29 01:36:46,252 INFO  [LibraryAdditionsCheckerThread] Added file '24. Casual Friday.avi' (title: 24. Casual Friday) to Library
2011-08-29 01:36:46,387 INFO  [LibraryAdditionsCheckerThread] Added file '25. Cafe Disco.avi' (title: 25. Cafe Disco) to Library
2011-08-29 01:36:46,521 INFO  [LibraryAdditionsCheckerThread] Added file '26. Company Picnic.avi' (title: 26. Company Picnic) to Library
2011-08-29 01:36:46,664 INFO  [LibraryAdditionsCheckerThread] Added file '3. Shower.avi' (title: 3. Shower) to Library
2011-08-29 01:36:46,810 INFO  [LibraryAdditionsCheckerThread] Added file '4. Crime Aid.avi' (title: 4. Crime Aid) to Library
2011-08-29 01:36:46,943 INFO  [LibraryAdditionsCheckerThread] Added file '5. Employee Transfer.avi' (title: 5. Employee Transfer) to Library
2011-08-29 01:36:47,081 INFO  [LibraryAdditionsCheckerThread] Added file '6. Customer Survey.avi' (title: 6. Customer Survey) to Library
2011-08-29 01:36:47,216 INFO  [LibraryAdditionsCheckerThread] Added file '7. Business Trip.avi' (title: 7. Business Trip) to Library
2011-08-29 01:36:47,361 INFO  [LibraryAdditionsCheckerThread] Added file '8. Frame Toby.avi' (title: 8. Frame Toby) to Library
2011-08-29 01:36:47,498 INFO  [LibraryAdditionsCheckerThread] Added file '9. The Surplus.avi' (title: 9. The Surplus) to Library
2011-08-29 01:36:47,656 INFO  [LibraryAdditionsCheckerThread] Added file '1. Gossip.avi' (title: 1. Gossip) to Library
2011-08-29 01:36:47,785 INFO  [LibraryAdditionsCheckerThread] Added file '10. Murder.avi' (title: 10. Murder) to Library
2011-08-29 01:36:47,920 INFO  [LibraryAdditionsCheckerThread] Added file '11. Shareholders Meeting.avi' (title: 11. Shareholders Meeting) to Library
2011-08-29 01:36:48,061 INFO  [LibraryAdditionsCheckerThread] Added file '12. Scott's Tots.avi' (title: 12. Scott's Tots) to Library
2011-08-29 01:36:48,230 INFO  [LibraryAdditionsCheckerThread] Added file '13. Secret Santa.avi' (title: 13. Secret Santa) to Library
2011-08-29 01:36:48,366 INFO  [LibraryAdditionsCheckerThread] Added file '14. The Banker.avi' (title: 14. The Banker) to Library
2011-08-29 01:36:48,499 INFO  [LibraryAdditionsCheckerThread] Added file '15. The Sabre.avi' (title: 15. The Sabre) to Library
2011-08-29 01:36:48,634 INFO  [LibraryAdditionsCheckerThread] Added file '16. Manager and Salesman.avi' (title: 16. Manager and Salesman) to Library
2011-08-29 01:36:48,805 INFO  [LibraryAdditionsCheckerThread] Added file '17-18. The Delivery Part 1 & 2.avi' (title: 17-18. The Delivery Part 1 & 2) to Library
2011-08-29 01:36:48,949 INFO  [LibraryAdditionsCheckerThread] Added file '19. St. Patrick's Day.avi' (title: 19. St. Patrick's Day) to Library
2011-08-29 01:36:49,088 INFO  [LibraryAdditionsCheckerThread] Added file '2. The Meeting.avi' (title: 2. The Meeting) to Library
2011-08-29 01:36:49,231 INFO  [LibraryAdditionsCheckerThread] Added file '20. New Leads.avi' (title: 20. New Leads) to Library
2011-08-29 01:36:49,361 INFO  [LibraryAdditionsCheckerThread] Added file '21. Happy Hour.avi' (title: 21. Happy Hour) to Library
2011-08-29 01:36:49,493 INFO  [LibraryAdditionsCheckerThread] Added file '22. Secretary's Day.avi' (title: 22. Secretary's Day) to Library
2011-08-29 01:36:49,635 INFO  [LibraryAdditionsCheckerThread] Added file '23. Body Language.avi' (title: 23. Body Language) to Library
2011-08-29 01:36:49,776 INFO  [LibraryAdditionsCheckerThread] Added file '24. The Cover-Up.avi' (title: 24. The Cover-Up) to Library
2011-08-29 01:36:49,935 INFO  [LibraryAdditionsCheckerThread] Added file '25. The Chump.avi' (title: 25. The Chump) to Library
2011-08-29 01:36:50,072 INFO  [LibraryAdditionsCheckerThread] Added file '26. Whistleblower.avi' (title: 26. Whistleblower) to Library
2011-08-29 01:36:50,205 INFO  [LibraryAdditionsCheckerThread] Added file '3. The Promotion.avi' (title: 3. The Promotion) to Library
2011-08-29 01:36:50,372 INFO  [LibraryAdditionsCheckerThread] Added file '4-5. Niagara Part 1 & 2.avi' (title: 4-5. Niagara Part 1 & 2) to Library
2011-08-29 01:36:50,679 INFO  [LibraryAdditionsCheckerThread] Added file '6. Mafia.avi' (title: 6. Mafia) to Library
2011-08-29 01:36:50,831 INFO  [LibraryAdditionsCheckerThread] Added file '7. The Lover.avi' (title: 7. The Lover) to Library
2011-08-29 01:36:50,992 INFO  [LibraryAdditionsCheckerThread] Added file '8. Koi Pond.avi' (title: 8. Koi Pond) to Library
2011-08-29 01:36:51,128 INFO  [LibraryAdditionsCheckerThread] Added file '9. Double Date.avi' (title: 9. Double Date) to Library
2011-08-29 01:36:51,505 INFO  [LibraryAdditionsCheckerThread] Added file 'The Rite {2011} - Mr. KickASS.mp4' (title: The Rite {2011} - Mr. KickASS) to Library
2011-08-29 01:36:51,782 INFO  [LibraryAdditionsCheckerThread] Added file 'THE SOCIAL NETWORK [2010] DVD Rip Xvid [StB].avi' (title: THE SOCIAL NETWORK [2010] DVD Rip Xvid [StB]) to Library
2011-08-29 01:36:52,084 INFO  [LibraryAdditionsCheckerThread] Added file 'The Truman Show  [1998]-720p-BRrip-x264-StyLishSaLH.mp4' (title: The Truman Show  [1998]-720p-BRrip-x264-StyLishSaLH) to Library
2011-08-29 01:36:52,333 INFO  [LibraryAdditionsCheckerThread] Added file 'The Whale Warrior - Pirate for the Sea.avi' (title: The Whale Warrior - Pirate for the Sea) to Library
2011-08-29 01:36:52,546 INFO  [LibraryAdditionsCheckerThread] Added file 'The.Human.Centipede.2009.BRRip.XviD.Feel-Free.avi' (title: The.Human.Centipede.2009.BRRip.XviD.Feel-Free) to Library
2011-08-29 01:36:52,814 INFO  [LibraryAdditionsCheckerThread] Added file 'Tron Legacy 2010 DVDRip.avi' (title: Tron Legacy 2010 DVDRip) to Library
2011-08-29 01:36:53,068 INFO  [LibraryAdditionsCheckerThread] Added file 'Unknown[2011].avi' (title: Unknown[2011]) to Library
2011-08-29 09:16:58,667 INFO  [LibraryUpdatesCheckerThread] Removing 'South Park S14 E09' (E:\Movies\South Park S14\South Park S14 E09.avi) from Library
2011-08-29 09:16:58,842 INFO  [LibraryUpdatesCheckerThread] Removing 'South Park S14 E10' (E:\Movies\South Park S14\South Park S14 E10.avi) from Library
2011-08-29 09:16:58,963 INFO  [LibraryUpdatesCheckerThread] Removing 'South Park S14 E11' (E:\Movies\South Park S14\South Park S14 E11.avi) from Library
2011-08-29 09:16:59,081 INFO  [LibraryUpdatesCheckerThread] Removing 'South Park S14 E12' (E:\Movies\South Park S14\South Park S14 E12.avi) from Library
2011-08-29 09:16:59,208 INFO  [LibraryUpdatesCheckerThread] Removing 'South Park S14 E13' (E:\Movies\South Park S14\South Park S14 E13.avi) from Library
2011-08-29 09:16:59,329 INFO  [LibraryUpdatesCheckerThread] Removing 'South Park S14 E14' (E:\Movies\South Park S14\South Park S14 E14.avi) from Library
2011-08-29 09:16:59,454 INFO  [LibraryUpdatesCheckerThread] Removing '1-1. Pilot' (E:\Movies\The Office - Seasons 1-6\Season 1\1-1. Pilot.avi) from Library
2011-08-29 09:16:59,581 INFO  [LibraryUpdatesCheckerThread] Removing '1-2. Diversity Day' (E:\Movies\The Office - Seasons 1-6\Season 1\1-2. Diversity Day.avi) from Library
2011-08-29 09:16:59,697 INFO  [LibraryUpdatesCheckerThread] Removing '1-3. Health Care' (E:\Movies\The Office - Seasons 1-6\Season 1\1-3. Health Care.avi) from Library
2011-08-29 09:16:59,813 INFO  [LibraryUpdatesCheckerThread] Removing '4. The Alliance' (E:\Movies\The Office - Seasons 1-6\Season 1\4. The Alliance.avi) from Library
2011-08-29 09:16:59,928 INFO  [LibraryUpdatesCheckerThread] Removing '5. Basketball' (E:\Movies\The Office - Seasons 1-6\Season 1\5. Basketball.avi) from Library
2011-08-29 09:17:00,050 INFO  [LibraryUpdatesCheckerThread] Removing '6. Hot Girl' (E:\Movies\The Office - Seasons 1-6\Season 1\6. Hot Girl.avi) from Library
2011-08-29 09:17:00,216 INFO  [LibraryUpdatesCheckerThread] Removing '1. The Dundies' (E:\Movies\The Office - Seasons 1-6\Season 2\1. The Dundies.avi) from Library
2011-08-29 09:21:05,268 INFO  [RendererManager] Stored a new renderer: uuid='2726e940-739e-43a9-81da-bfbfc5d34344', name = 'Samsung TV / player (C/D-series)', ipAddress='192.168.1.5', profile = '7'
2011-08-29 09:27:15,589 INFO  [LibraryAdditionsCheckerThread] Finished looking for newly added files
2011-08-29 09:27:15,802 INFO  [LibraryAdditionsCheckerThread] Started looking for newly added files
2011-08-29 09:27:15,803 INFO  [LibraryUpdatesCheckerThread] Started looking for updates to currently shared files
2011-08-29 09:27:18,539 INFO  [LibraryAdditionsCheckerThread] Added file 'South Park S14 E09.avi' (title: South Park S14 E09) to Library
2011-08-29 09:27:18,688 INFO  [LibraryAdditionsCheckerThread] Added file 'South Park S14 E10.avi' (title: South Park S14 E10) to Library
2011-08-29 09:27:18,828 INFO  [LibraryAdditionsCheckerThread] Added file 'South Park S14 E11.avi' (title: South Park S14 E11) to Library
2011-08-29 09:27:18,967 INFO  [LibraryAdditionsCheckerThread] Added file 'South Park S14 E12.avi' (title: South Park S14 E12) to Library
2011-08-29 09:27:19,103 INFO  [LibraryAdditionsCheckerThread] Added file 'South Park S14 E13.avi' (title: South Park S14 E13) to Library
2011-08-29 09:27:19,253 INFO  [LibraryAdditionsCheckerThread] Added file 'South Park S14 E14.avi' (title: South Park S14 E14) to Library
2011-08-29 09:27:19,471 INFO  [LibraryAdditionsCheckerThread] Added file '1-1. Pilot.avi' (title: 1-1. Pilot) to Library
2011-08-29 09:27:19,628 INFO  [LibraryAdditionsCheckerThread] Added file '1-2. Diversity Day.avi' (title: 1-2. Diversity Day) to Library
2011-08-29 09:27:19,767 INFO  [LibraryAdditionsCheckerThread] Added file '1-3. Health Care.avi' (title: 1-3. Health Care) to Library
2011-08-29 09:27:19,912 INFO  [LibraryAdditionsCheckerThread] Added file '4. The Alliance.avi' (title: 4. The Alliance) to Library
2011-08-29 09:27:20,045 INFO  [LibraryAdditionsCheckerThread] Added file '5. Basketball.avi' (title: 5. Basketball) to Library
2011-08-29 09:27:20,192 INFO  [LibraryAdditionsCheckerThread] Added file '6. Hot Girl.avi' (title: 6. Hot Girl) to Library
2011-08-29 09:27:20,356 INFO  [LibraryAdditionsCheckerThread] Added file '1. The Dundies.avi' (title: 1. The Dundies) to Library
Nothing in the log about disconnect...disconnect time was 9:35. Gonna turn on debug mode and try again.
sdobron
Post Mon Aug 29, 2011 2:06 pm
2011-08-29 10:00:31,984 DEBUG [DiscoverySSDPMessageListener] Received a valid M-SEARCH message for search target uuid:92364609-eb74-3e48-a97f-fb1c988d0a03 from address /192.168.1.5:1025
2011-08-29 10:00:31,984 DEBUG [DiscoverySearchResponder] Sending 1 M-SEARCH response message(s) to /192.168.1.5:1025
2011-08-29 10:00:32,347 DEBUG [DiscoverySSDPMessageListener] Received a valid M-SEARCH message for search target uuid:92364609-eb74-3e48-a97f-fb1c988d0a03 from address /192.168.1.5:1025
2011-08-29 10:00:32,347 DEBUG [DiscoverySearchResponder] Sending 1 M-SEARCH response message(s) to /192.168.1.5:1025
2011-08-29 10:00:34,447 DEBUG [DiscoverySSDPMessageListener] Received a valid M-SEARCH message for search target urn:schemas-upnp-org:device:InternetGatewayDevice:1 from address /192.168.1.3:61049
2011-08-29 10:00:38,416 DEBUG [DiscoverySSDPMessageListener] Received a valid M-SEARCH message for search target urn:schemas-upnp-org:device:InternetGatewayDevice:1 from address /192.168.1.3:61049
2011-08-29 10:00:41,416 DEBUG [DiscoverySSDPMessageListener] Received a valid M-SEARCH message for search target urn:schemas-upnp-org:device:InternetGatewayDevice:1 from address /192.168.1.3:61049
2011-08-29 10:00:41,767 DEBUG [DiscoverySSDPMessageListener] Received a valid M-SEARCH message for search target uuid:92364609-eb74-3e48-a97f-fb1c988d0a03 from address /192.168.1.5:1025
2011-08-29 10:00:41,768 DEBUG [DiscoverySearchResponder] Sending 1 M-SEARCH response message(s) to /192.168.1.5:1025
2011-08-29 10:00:41,983 DEBUG [DiscoverySSDPMessageListener] Received a valid M-SEARCH message for search target uuid:92364609-eb74-3e48-a97f-fb1c988d0a03 from address /192.168.1.5:1025
2011-08-29 10:00:41,984 DEBUG [DiscoverySearchResponder] Sending 1 M-SEARCH response message(s) to /192.168.1.5:1025
2011-08-29 10:00:42,381 DEBUG [DiscoverySSDPMessageListener] Received a valid M-SEARCH message for search target uuid:92364609-eb74-3e48-a97f-fb1c988d0a03 from address /192.168.1.5:1025
2011-08-29 10:00:42,382 DEBUG [DiscoverySearchResponder] Sending 1 M-SEARCH response message(s) to /192.168.1.5:1025
2011-08-29 10:00:44,416 DEBUG [DiscoverySSDPMessageListener] Received a valid M-SEARCH message for search target urn:schemas-upnp-org:device:InternetGatewayDevice:1 from address /192.168.1.3:61049
2011-08-29 10:00:47,458 DEBUG [DiscoverySSDPMessageListener] Received a valid M-SEARCH message for search target urn:schemas-upnp-org:device:InternetGatewayDevice:1 from address /192.168.1.3:61049
2011-08-29 10:00:50,458 DEBUG [DiscoverySSDPMessageListener] Received a valid M-SEARCH message for search target urn:schemas-upnp-org:device:InternetGatewayDevice:1 from address /192.168.1.3:61049
2011-08-29 10:00:52,723 DEBUG [DiscoverySSDPMessageListener] Received a valid M-SEARCH message for search target uuid:92364609-eb74-3e48-a97f-fb1c988d0a03 from address /192.168.1.5:1025
2011-08-29 10:00:52,724 DEBUG [DiscoverySearchResponder] Sending 1 M-SEARCH response message(s) to /192.168.1.5:1025
2011-08-29 10:00:53,030 DEBUG [DiscoverySSDPMessageListener] Received a valid M-SEARCH message for search target uuid:92364609-eb74-3e48-a97f-fb1c988d0a03 from address /192.168.1.5:1025
2011-08-29 10:00:53,031 DEBUG [DiscoverySearchResponder] Sending 1 M-SEARCH response message(s) to /192.168.1.5:1025
2011-08-29 10:00:53,337 DEBUG [DiscoverySSDPMessageListener] Received a valid M-SEARCH message for search target uuid:92364609-eb74-3e48-a97f-fb1c988d0a03 from address /192.168.1.5:1025
2011-08-29 10:00:53,338 DEBUG [DiscoverySearchResponder] Sending 1 M-SEARCH response message(s) to /192.168.1.5:1025
2011-08-29 10:00:53,458 DEBUG [DiscoverySSDPMessageListener] Received a valid M-SEARCH message for search target urn:schemas-upnp-org:device:InternetGatewayDevice:1 from address /192.168.1.3:61049
2011-08-29 10:01:00,710 DEBUG [DiscoverySSDPMessageListener] Received a valid M-SEARCH message for search target uuid:92364609-eb74-3e48-a97f-fb1c988d0a03 from address /192.168.1.5:1025
2011-08-29 10:01:00,712 DEBUG [DiscoverySearchResponder] Sending 1 M-SEARCH response message(s) to /192.168.1.5:1025
2011-08-29 10:01:01,016 DEBUG [DiscoverySSDPMessageListener] Received a valid M-SEARCH message for search target uuid:92364609-eb74-3e48-a97f-fb1c988d0a03 from address /192.168.1.5:1025
2011-08-29 10:01:01,017 DEBUG [DiscoverySearchResponder] Sending 1 M-SEARCH response message(s) to /192.168.1.5:1025
2011-08-29 10:01:01,323 DEBUG [DiscoverySSDPMessageListener] Received a valid M-SEARCH message for search target uuid:92364609-eb74-3e48-a97f-fb1c988d0a03 from address /192.168.1.5:1025
2011-08-29 10:01:01,324 DEBUG [DiscoverySearchResponder] Sending 1 M-SEARCH response message(s) to /192.168.1.5:1025
2011-08-29 10:01:13,979 DEBUG [DiscoverySSDPMessageListener] Received a valid M-SEARCH message for search target uuid:92364609-eb74-3e48-a97f-fb1c988d0a03 from address /192.168.1.5:1025
2011-08-29 10:01:13,980 DEBUG [DiscoverySearchResponder] Sending 1 M-SEARCH response message(s) to /192.168.1.5:1025
2011-08-29 10:01:14,328 DEBUG [DiscoverySSDPMessageListener] Received a valid M-SEARCH message for search target uuid:92364609-eb74-3e48-a97f-fb1c988d0a03 from address /192.168.1.5:1025
2011-08-29 10:01:14,329 DEBUG [DiscoverySearchResponder] Sending 1 M-SEARCH response message(s) to /192.168.1.5:1025
2011-08-29 10:01:14,724 DEBUG [WebServer] Incoming connection from /192.168.1.5:44358
2011-08-29 10:01:14,725 DEBUG [DeviceDescriptionRequestHandler] DeviceDescription request received for device 92364609-eb74-3e48-a97f-fb1c988d0a03 from 192.168.1.5 (headers = [HOST: 192.168.1.3:8895,USER-AGENT: SEC_HHP_BD-C5500/1.0,ACCEPT-LANGUAGE: en-us])
2011-08-29 10:01:14,725 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.1.5
2011-08-29 10:01:14,727 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.1.5
2011-08-29 10:01:14,732 DEBUG [DeviceDescriptionRequestHandler] Sending DeviceDescription XML back using profile 'Samsung TV / player (C/D-series)'
2011-08-29 10:01:14,867 DEBUG [WebServer] I/O error: Connection reset by peer: socket write error
Socket write error...
sdobron
Post Mon Aug 29, 2011 11:05 pm
Think I'm just gonna go back to Windows 7 managed DLNA.
Doesn't seem to be an issue on my end because I've had zero disconnects through Windows. I'll just have to wait for Serviio to be updated to hopefully correct this issue.
Post Tue Aug 30, 2011 4:43 am
There is no issue with serviio, as many people have it working, it has to be something in you specific setup.
Kahanamoku
Post Tue Aug 30, 2011 5:10 am
Also run on the assumption that Serviio is not the only change that occurred and is causing your drop outs. Something outside of your control may have changed coincidentally at the same time (Neighbor purchased a new cordless phone system perhaps)
I'd try going back to the windows server temporarily and see if it drops out. if successful (does not drop out) try serviio again. Find a laptop or something and run a DLNA player on it over the wireless and test serviio on that too (if possible).
sdobron
Post Tue Aug 30, 2011 6:30 am
Tried windows again. No drop outs... try to increase Serviio buffer size possibly?
Post Thu Sep 01, 2011 4:51 pm
sdobron wrote:Tried windows again. No drop outs... try to increase Serviio buffer size possibly?
this is not a serviio issue changing buffer size will have no affect and for the record WMP uses different ports to serviio and is designed completely differeent and does not follow the DLNA standard.
Post Thu Sep 01, 2011 5:00 pm
Maybe that is the problem, something else is trying to use the ports that Serviio uses or something trys to block them.
Look in your router configuration and see if there is a QOS setting. If so enable it and set it up for streaming video.
Also look and see if you have a UPNP setting on your router. If so try enabling or disabling depending on your router setup and see if that helps.
Post Thu Sep 01, 2011 5:08 pm
moltra wrote:Maybe that is the problem, something else is trying to use the ports that Serviio uses or something trys to block them.
also remember to disable the WMP network sharing service.
