Re: Web UI in PHP
Do you have a timeframe on providing an update to work with 0.6B4? Thanks for what you've done in the past!
Would be honored to help if needed.
Blessings,
Xmantium wrote:Im hoping it would be ready when 0.6 final comes out. NAS users like me would struggle without a GUI to add feeds.
mrfusker wrote:Xmantium wrote:Im hoping it would be ready when 0.6 final comes out. NAS users like me would struggle without a GUI to add feeds.
Yeah... release it
Xmantium wrote:Nice work Mark! Adding feeds works fine on my NAS
The "Presentation" tab still doesnt work like previous version, when you select "Disabled", it doesnt save.
mpemberton5 wrote:I have contacted the author and hope to have an official release out soon.
Xmantium wrote:Hello Mark, sorry for late reply.
It must be a linux issue, yes all QNAP users with previous version had this same issue.
It does not come up with any errors, when you try to change anything in the dropdown and press save, it doesn't save anything, the page just refreshes with original presentation settings. It doesn't matter if you change one or many, it does not save in the presentation tab.
But all the other tabs, the save button works.
I'll try to see if there's any debug logs.
The only fix is to use the windows console to connect to change the values.
Cerberus wrote:Xmantium wrote:Hello Mark, sorry for late reply.
check the code for the save button could be a mistype and that would make it refresh but not actualy save
mpemberton5 wrote:UPDATE: Please refer to the first post of this topic to download the latest version
r-win wrote:mpemberton5 wrote:UPDATE: Please refer to the first post of this topic to download the latest version
Nice work, Mark!
Adding feeds works fine, as long as they don't have an & in the querystring. If they do, the feed is added without the portion behind the ampersand (and the ampersand itself is, of course, also not added).
cburbs wrote:Upgrade issue -
I downloaded the newest serviio as well as v0.6b update http://blog.tolik.org/2011/09/serviio-w ... -v06b.html (patched by Mark Pemberton)
I can get to the web ui but get the following error. Is this because v0.6b doesn't work with 0.6.0.1? This is running on Vortexbox. The service is running as I verified it with my Oppo DVD Player. Looks like it is more of a web ui issue.
ERROR in web ui:
Big red X and Required Serviio 0.6, but found '0.6.0.1'Cannot connect to Serviio server, it does not seem to be running. Exiting...
