Working classical online radio streams
Mugwump
Post Fri Jan 06, 2012 2:00 am
The reliability of most streams varies depending on network traffic and location. However some are very high quality and can produce good results if listened to at the right time of day depending on where the stream originates and where the listener is located.
Thanks to all those who aided in getting the profiles set to work with some of these streams..happy listening :)
http://shoutcast.omroep.nl:8068/
Avro Baroque Around The Clock
256k 44,100 mp3 stream
http://174.36.206.197:8000
Venice Classic Radio
128k 44,100hz mp3 stream
http://sc1.abacast.com:9014/
WWFM
128k 44,100 mp3 stream
http://wttw.ic.llnwd.net/stream/wttw_wfmt_MP3
WFMT
24,000hz 48k mp3
http://audio-mp3.ibiblio.org:8000/wcpe.mp3
WCPE
44,100hz 96k mp3 stream
http://glb-stream11.streamserver.ch/1/rsc_de/mp3_128
http://zlz-stream11.streamserver.ch/1/rsc_de/mp3_128
http://zlz-stream10.streamserver.ch/1/rsc_de/mp3_128
http://glb-stream10.streamserver.ch/1/rsc_de/mp3_128
http://zlz-stream12.streamserver.ch/1/rsc_de/mp3_128
http://zlz-stream13.streamserver.ch/1/rsc_de/mp3_128
http://glb-stream12.streamserver.ch/1/rsc_de/mp3_128
http://glb-stream13.streamserver.ch/1/rsc_de/mp3_128
RSC Radio Swiss Classic in German
44,100hz 128k mp3 stream
A very reliable set of streams
http://radio.cesnet.cz:8000/cro-d-dur.ogg
CRo D-dur Czech Classical
48,000hz 128k .ogg stream
http://amp1.cesnet.cz:8000/cro-d-dur-256.ogg
48,000hz 256k ogg stream
(this stream and the following require a good connection, works best when net traffic is low to EU .cz domains)
http://radio.cesnet.cz:8000/cro-d-dur.flac
Czeck Classical
48,000hz 16 bit flac audio stream
(requires up to 4 times the bandwidth of an mp3 or ogg to listen to and must be a consistant connection without server throttle troubles or network trouble to work well however when working is as good as listening to a cd stereo audio recording)
http://classic-nonstop.atlantis.bg:8000 ... onstop.ogg
Can be problems but will work Mixed Classical Music
http://lyd.nrk.no/nrk_radio_klassisk_mp3_h
NRK Norwegian Broadcasting Classical Music
Mozart Radio...Nothing but ;-)
From .ru so it can be problematic. So here is the complete m3u listing.
(http://kvp-wow.ru:8000/radiomozart actual web site if you want to find out more info)
(http://fumail.dyndns.org:8000/radiomozart)
Actual stream addresses that you can enter into the console
http://streaming202.radionomy.com:80/Radio-Mozart
http://streaming206.radionomy.com:80/Radio-Mozart
http://streaming201.radionomy.com:80/Radio-Mozart
http://streaming205.radionomy.com:80/Radio-Mozart
http://streaming204.radionomy.com:80/Radio-Mozart
http://streaming203.radionomy.com:80/Radio-Mozart
CBC Radio 2 Classical
Can have some troubles depending on the commercial site streamtheworld.com has definite difficulties at times. Clicks pops and stream drop are sometimes inevitable. It is a standard mp3 stream but can cause trouble other times it works fine.
http://1651.live.streamtheworld.com/CBC_R2_CLASS_H_SC
CigDangle
Post Fri Jan 06, 2012 3:52 am
Re: Working classical online radio streams
After trying a handful, none of these seem to work for me. They work just fine on my Serviio server.
Is anyone else using a PS3 or Sony Blu-Ray Player with stream content?
Here is what I'm seeing in serviio.log when I browse to Audio/Serviio/Online and click on of the "Unsupported Data" entries using my PS3:
2012-01-05 22:15:06,875 DEBUG [WebServer] Incoming connection from /192.168.1.126:55459
2012-01-05 22:15:06,875 DEBUG [DeviceDescriptionRequestHandler] DeviceDescription request received for device 83403509-60a4-3ac0-bae1-94340baf2344 from 192.168.1.126 (headers = [Host: 192.168.1.2:8895,Date: Fri, 06 Jan 2012 04:18:58 GMT,User-Agent: UPnP/1.0,X-AV-Client-Info: av=5.0; cn="Sony Computer Entertainment Inc."; mn="PLAYSTATION 3"; mv="1.0";])
2012-01-05 22:15:06,875 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.1.126
2012-01-05 22:15:06,875 DEBUG [RendererManager] Looking for a renderer profile for Http headers: [Host: 192.168.1.2:8895,Date: Fri, 06 Jan 2012 04:18:58 GMT,User-Agent: UPnP/1.0,X-AV-Client-Info: av=5.0; cn="Sony Computer Entertainment Inc."; mn="PLAYSTATION 3"; mv="1.0";]
2012-01-05 22:15:06,875 DEBUG [DeviceDescriptionRequestHandler] Sending DeviceDescription XML back using profile 'Playstation 3'
2012-01-05 22:15:57,359 DEBUG [FeedUpdaterThread] Checking for new and expired online resources
2012-01-05 22:15:57,359 DEBUG [OnlineRepositoryDAOImpl] Reading all OnlineRepositories
2012-01-05 22:15:57,359 DEBUG [OnlineRepositoryDAOImpl] Reading an OnlineRepository (id = 4)
2012-01-05 22:15:57,359 DEBUG [OnlineRepositoryDAOImpl] Reading an OnlineRepository (id = 5)
2012-01-05 22:15:57,359 DEBUG [OnlineRepositoryDAOImpl] Reading an OnlineRepository (id = 29)
2012-01-05 22:15:57,375 DEBUG [OnlineRepositoryDAOImpl] Reading an OnlineRepository (id = 36)
2012-01-05 22:15:57,375 DEBUG [OnlineRepositoryDAOImpl] Reading an OnlineRepository (id = 40)
2012-01-05 22:15:57,375 DEBUG [OnlineRepositoryDAOImpl] Reading an OnlineRepository (id = 43)
2012-01-05 22:15:57,375 DEBUG [OnlineRepositoryDAOImpl] Reading an OnlineRepository (id = 44)
2012-01-05 22:15:57,375 DEBUG [OnlineRepositoryDAOImpl] Reading an OnlineRepository (id = 45)
2012-01-05 22:15:57,375 DEBUG [OnlineRepositoryDAOImpl] Reading an OnlineRepository (id = 50)
2012-01-05 22:15:57,375 DEBUG [OnlineRepositoryDAOImpl] Reading an OnlineRepository (id = 51)
2012-01-05 22:16:17,593 DEBUG [DiscoveryAdvertisementNotifier] Multicasting SSDP alive using interface eth0 (Broadcom NetXtreme 57xx Gigabit Controller) and address 192.168.1.2, timeout = 0
2012-01-05 22:16:17,593 DEBUG [DiscoveryAdvertisementNotifier] Sending 6 'alive' messages describing device 83403509-60a4-3ac0-bae1-94340baf2344
2012-01-05 22:16:18,937 DEBUG [WebServer] Incoming connection from /192.168.1.126:55453
2012-01-05 22:16:18,937 DEBUG [DeviceDescriptionRequestHandler] DeviceDescription request received for device 83403509-60a4-3ac0-bae1-94340baf2344 from 192.168.1.126 (headers = [Host: 192.168.1.2:8895,Date: Fri, 06 Jan 2012 04:20:10 GMT,User-Agent: UPnP/1.0,X-AV-Client-Info: av=5.0; cn="Sony Computer Entertainment Inc."; mn="PLAYSTATION 3"; mv="1.0";])
2012-01-05 22:16:18,937 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.1.126
2012-01-05 22:16:18,937 DEBUG [RendererManager] Looking for a renderer profile for Http headers: [Host: 192.168.1.2:8895,Date: Fri, 06 Jan 2012 04:20:10 GMT,User-Agent: UPnP/1.0,X-AV-Client-Info: av=5.0; cn="Sony Computer Entertainment Inc."; mn="PLAYSTATION 3"; mv="1.0";]
2012-01-05 22:16:18,937 DEBUG [DeviceDescriptionRequestHandler] Sending DeviceDescription XML back using profile 'Playstation 3'
2012-01-05 22:16:19,406 DEBUG [DiscoveryAdvertisementNotifier] Will advertise again in 00:01:18
2012-01-05 22:16:57,375 DEBUG [FeedUpdaterThread] Checking for new and expired online resources
2012-01-05 22:16:57,375 DEBUG [OnlineRepositoryDAOImpl] Reading all OnlineRepositories
2012-01-05 22:16:57,375 DEBUG [OnlineRepositoryDAOImpl] Reading an OnlineRepository (id = 4)
2012-01-05 22:16:57,390 DEBUG [OnlineRepositoryDAOImpl] Reading an OnlineRepository (id = 5)
2012-01-05 22:16:57,390 DEBUG [OnlineRepositoryDAOImpl] Reading an OnlineRepository (id = 29)
2012-01-05 22:16:57,390 DEBUG [OnlineRepositoryDAOImpl] Reading an OnlineRepository (id = 36)
2012-01-05 22:16:57,390 DEBUG [OnlineRepositoryDAOImpl] Reading an OnlineRepository (id = 40)
2012-01-05 22:16:57,406 DEBUG [OnlineRepositoryDAOImpl] Reading an OnlineRepository (id = 43)
2012-01-05 22:16:57,406 DEBUG [OnlineRepositoryDAOImpl] Reading an OnlineRepository (id = 44)
2012-01-05 22:16:57,406 DEBUG [OnlineRepositoryDAOImpl] Reading an OnlineRepository (id = 45)
2012-01-05 22:16:57,406 DEBUG [OnlineRepositoryDAOImpl] Reading an OnlineRepository (id = 50)
2012-01-05 22:16:57,406 DEBUG [OnlineRepositoryDAOImpl] Reading an OnlineRepository (id = 51)
2012-01-05 22:17:01,953 DEBUG [TranscodingJobListener] Transcoding finished; successful: true
2012-01-05 22:17:19,859 DEBUG [WebServer] Incoming connection from /192.168.1.126:55442
2012-01-05 22:17:19,859 DEBUG [ServiceControlRequestHandler] ServiceControl request received for action '"urn:schemas-upnp-org:service:ContentDirectory:1#GetSystemUpdateID"' from 192.168.1.126:
2012-01-05 22:17:19,859 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.1.126
2012-01-05 22:17:19,890 DEBUG [ServiceControlRequestHandler] Returning OK SOAP message
2012-01-05 22:17:19,890 DEBUG [WebServer] Incoming connection from /192.168.1.126:55441
2012-01-05 22:17:19,890 DEBUG [ServiceControlRequestHandler] ServiceControl request received for action '"urn:schemas-upnp-org:service:ContentDirectory:1#Browse"' from 192.168.1.126:
2012-01-05 22:17:19,890 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.1.126
2012-01-05 22:17:20,093 DEBUG [ContentDirectory] Browse() called for renderer Playstation 3 (profile 4) with parameters: objectID = 0, browseFlag = BrowseMetadata, filter = @id,upnp:class,res,res@protocolInfo,res@av:authenticationUri,res@size,dc:title,upnp:albumArtURI,res@dlna:ifoFileURI,res@protection,res@bitrate,res@duration,res@sampleFrequency,res@bitsPerSample,res@nrAudioChannels,res@resolution,res@colorDepth,dc:date,av:dateTime,upnp:artist,upnp:album,upnp:genre,dc:contributer,upnp:storageFree,upnp:storageUsed,upnp:originalTrackNumber,dc:publisher,dc:language,dc:region,dc:description,upnp:toc,@childCount,upnp:albumArtURI@dlna:profileID,res@dlna:cleartextSize, startIndex = 0, count = 1, sortCriteria =
2012-01-05 22:17:20,093 DEBUG [ServiceControlRequestHandler] Returning OK SOAP message
2012-01-05 22:17:20,093 DEBUG [WebServer] Incoming connection from /192.168.1.126:55440
2012-01-05 22:17:20,093 DEBUG [ServiceControlRequestHandler] ServiceControl request received for action '"urn:schemas-upnp-org:service:ContentDirectory:1#GetSystemUpdateID"' from 192.168.1.126:
2012-01-05 22:17:20,093 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.1.126
2012-01-05 22:17:20,281 DEBUG [ServiceControlRequestHandler] Returning OK SOAP message
2012-01-05 22:17:20,296 DEBUG [WebServer] Incoming connection from /192.168.1.126:55439
2012-01-05 22:17:20,296 DEBUG [ServiceControlRequestHandler] ServiceControl request received for action '"urn:schemas-upnp-org:service:ContentDirectory:1#Browse"' from 192.168.1.126:
2012-01-05 22:17:20,296 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.1.126
2012-01-05 22:17:20,484 DEBUG [ContentDirectory] Browse() called for renderer Playstation 3 (profile 4) with parameters: objectID = 0, browseFlag = BrowseMetadata, filter = @id,upnp:class,res,res@protocolInfo,res@av:authenticationUri,res@size,dc:title,upnp:albumArtURI,res@dlna:ifoFileURI,res@protection,res@bitrate,res@duration,res@sampleFrequency,res@bitsPerSample,res@nrAudioChannels,res@resolution,res@colorDepth,dc:date,av:dateTime,upnp:artist,upnp:album,upnp:genre,dc:contributer,upnp:storageFree,upnp:storageUsed,upnp:originalTrackNumber,dc:publisher,dc:language,dc:region,dc:description,upnp:toc,@childCount,upnp:albumArtURI@dlna:profileID,res@dlna:cleartextSize, startIndex = 0, count = 1, sortCriteria =
2012-01-05 22:17:20,484 DEBUG [ServiceControlRequestHandler] Returning OK SOAP message
2012-01-05 22:17:20,531 DEBUG [WebServer] Incoming connection from /192.168.1.126:55438
2012-01-05 22:17:20,531 DEBUG [ServiceControlRequestHandler] ServiceControl request received for action '"urn:schemas-upnp-org:service:ContentDirectory:1#Browse"' from 192.168.1.126:
2012-01-05 22:17:20,531 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.1.126
2012-01-05 22:17:20,687 DEBUG [ContentDirectory] Browse() called for renderer Playstation 3 (profile 4) with parameters: objectID = 0, browseFlag = BrowseDirectChildren, filter = @id,upnp:class,res,res@protocolInfo,res@av:authenticationUri,res@size,dc:title,upnp:albumArtURI,res@dlna:ifoFileURI,res@protection,res@bitrate,res@duration,res@sampleFrequency,res@bitsPerSample,res@nrAudioChannels,res@resolution,res@colorDepth,dc:date,av:dateTime,upnp:artist,upnp:album,upnp:genre,dc:contributer,upnp:storageFree,upnp:storageUsed,upnp:originalTrackNumber,dc:publisher,dc:language,dc:region,dc:description,upnp:toc,@childCount,upnp:albumArtURI@dlna:profileID,res@dlna:cleartextSize, startIndex = 0, count = 10, sortCriteria =
2012-01-05 22:17:20,687 DEBUG [RepositoryDAOImpl] Retrieving number of repositories for IMAGE
2012-01-05 22:17:20,687 DEBUG [RepositoryDAOImpl] Retrieving number of repositories for VIDEO
2012-01-05 22:17:20,687 DEBUG [ServiceControlRequestHandler] Returning OK SOAP message
2012-01-05 22:17:20,750 DEBUG [WebServer] Incoming connection from /192.168.1.126:55437
2012-01-05 22:17:20,750 DEBUG [ServiceControlRequestHandler] ServiceControl request received for action '"urn:schemas-upnp-org:service:ContentDirectory:1#GetSystemUpdateID"' from 192.168.1.126:
2012-01-05 22:17:20,750 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.1.126
2012-01-05 22:17:20,890 DEBUG [ServiceControlRequestHandler] Returning OK SOAP message
2012-01-05 22:17:20,890 DEBUG [WebServer] Incoming connection from /192.168.1.126:55436
2012-01-05 22:17:20,890 DEBUG [ServiceControlRequestHandler] ServiceControl request received for action '"urn:schemas-upnp-org:service:ContentDirectory:1#GetSystemUpdateID"' from 192.168.1.126:
2012-01-05 22:17:20,890 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.1.126
2012-01-05 22:17:21,093 DEBUG [ServiceControlRequestHandler] Returning OK SOAP message
2012-01-05 22:17:21,093 DEBUG [WebServer] Incoming connection from /192.168.1.126:55435
2012-01-05 22:17:21,093 DEBUG [ServiceControlRequestHandler] ServiceControl request received for action '"urn:schemas-upnp-org:service:ContentDirectory:1#Browse"' from 192.168.1.126:
2012-01-05 22:17:21,093 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.1.126
2012-01-05 22:17:21,296 DEBUG [ContentDirectory] Browse() called for renderer Playstation 3 (profile 4) with parameters: objectID = A, browseFlag = BrowseMetadata, filter = @id,upnp:class,res,res@protocolInfo,res@av:authenticationUri,res@size,dc:title,upnp:albumArtURI,res@dlna:ifoFileURI,res@protection,res@bitrate,res@duration,res@sampleFrequency,res@bitsPerSample,res@nrAudioChannels,res@resolution,res@colorDepth,dc:date,av:dateTime,upnp:artist,upnp:album,upnp:genre,dc:contributer,upnp:storageFree,upnp:storageUsed,upnp:originalTrackNumber,dc:publisher,dc:language,dc:region,dc:description,upnp:toc,@childCount,upnp:albumArtURI@dlna:profileID,res@dlna:cleartextSize, startIndex = 0, count = 1, sortCriteria =
2012-01-05 22:17:21,296 DEBUG [ServiceControlRequestHandler] Returning OK SOAP message
2012-01-05 22:17:21,296 DEBUG [WebServer] Incoming connection from /192.168.1.126:55434
2012-01-05 22:17:21,296 DEBUG [ServiceControlRequestHandler] ServiceControl request received for action '"urn:schemas-upnp-org:service:ContentDirectory:1#Browse"' from 192.168.1.126:
2012-01-05 22:17:21,296 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.1.126
2012-01-05 22:17:21,500 DEBUG [ContentDirectory] Browse() called for renderer Playstation 3 (profile 4) with parameters: objectID = A, browseFlag = BrowseDirectChildren, filter = @id,upnp:class,res,res@protocolInfo,res@av:authenticationUri,res@size,dc:title,upnp:albumArtURI,res@dlna:ifoFileURI,res@protection,res@bitrate,res@duration,res@sampleFrequency,res@bitsPerSample,res@nrAudioChannels,res@resolution,res@colorDepth,dc:date,av:dateTime,upnp:artist,upnp:album,upnp:genre,dc:contributer,upnp:storageFree,upnp:storageUsed,upnp:originalTrackNumber,dc:publisher,dc:language,dc:region,dc:description,upnp:toc,@childCount,upnp:albumArtURI@dlna:profileID,res@dlna:cleartextSize, startIndex = 0, count = 10, sortCriteria =
2012-01-05 22:17:21,500 DEBUG [PersonDAOImpl] Retrieving number of person initials for role ARTIST
2012-01-05 22:17:21,640 DEBUG [RepositoryDAOImpl] Retrieving number of repositories for AUDIO
2012-01-05 22:17:21,640 DEBUG [GenreDAOImpl] Retrieving number of genres for AUDIO
2012-01-05 22:17:22,125 DEBUG [OnlineRepositoryDAOImpl] Retrieving list of [FEED, WEB_RESOURCE] OnlineRepositories for AUDIO
2012-01-05 22:17:22,125 DEBUG [OnlineRepositoryDAOImpl] Retrieving list of [LIVE_STREAM] OnlineRepositories for AUDIO
2012-01-05 22:17:22,125 DEBUG [ServiceControlRequestHandler] Returning OK SOAP message
2012-01-05 22:17:22,140 DEBUG [WebServer] Incoming connection from /192.168.1.126:55433
2012-01-05 22:17:22,140 DEBUG [ServiceControlRequestHandler] ServiceControl request received for action '"urn:schemas-upnp-org:service:ContentDirectory:1#GetSystemUpdateID"' from 192.168.1.126:
2012-01-05 22:17:22,140 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.1.126
2012-01-05 22:17:22,296 DEBUG [ServiceControlRequestHandler] Returning OK SOAP message
2012-01-05 22:17:22,312 DEBUG [WebServer] Incoming connection from /192.168.1.126:55432
2012-01-05 22:17:22,312 DEBUG [ServiceControlRequestHandler] ServiceControl request received for action '"urn:schemas-upnp-org:service:ContentDirectory:1#Browse"' from 192.168.1.126:
2012-01-05 22:17:22,312 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.1.126
2012-01-05 22:17:22,500 DEBUG [ContentDirectory] Browse() called for renderer Playstation 3 (profile 4) with parameters: objectID = A_OF, browseFlag = BrowseMetadata, filter = @id,upnp:class,res,res@protocolInfo,res@av:authenticationUri,res@size,dc:title,upnp:albumArtURI,res@dlna:ifoFileURI,res@protection,res@bitrate,res@duration,res@sampleFrequency,res@bitsPerSample,res@nrAudioChannels,res@resolution,res@colorDepth,dc:date,av:dateTime,upnp:artist,upnp:album,upnp:genre,dc:contributer,upnp:storageFree,upnp:storageUsed,upnp:originalTrackNumber,dc:publisher,dc:language,dc:region,dc:description,upnp:toc,@childCount,upnp:albumArtURI@dlna:profileID,res@dlna:cleartextSize, startIndex = 0, count = 1, sortCriteria =
2012-01-05 22:17:22,500 DEBUG [OnlineRepositoryDAOImpl] Retrieving list of [FEED, WEB_RESOURCE] OnlineRepositories for AUDIO
2012-01-05 22:17:22,500 DEBUG [OnlineRepositoryDAOImpl] Retrieving list of [LIVE_STREAM] OnlineRepositories for AUDIO
2012-01-05 22:17:22,500 DEBUG [ServiceControlRequestHandler] Returning OK SOAP message
2012-01-05 22:17:22,515 DEBUG [WebServer] Incoming connection from /192.168.1.126:55431
2012-01-05 22:17:22,515 DEBUG [ServiceControlRequestHandler] ServiceControl request received for action '"urn:schemas-upnp-org:service:ContentDirectory:1#Browse"' from 192.168.1.126:
2012-01-05 22:17:22,515 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.1.126
2012-01-05 22:17:22,703 DEBUG [ContentDirectory] Browse() called for renderer Playstation 3 (profile 4) with parameters: objectID = A_OF, browseFlag = BrowseDirectChildren, filter = @id,upnp:class,res,res@protocolInfo,res@av:authenticationUri,res@size,dc:title,upnp:albumArtURI,res@dlna:ifoFileURI,res@protection,res@bitrate,res@duration,res@sampleFrequency,res@bitsPerSample,res@nrAudioChannels,res@resolution,res@colorDepth,dc:date,av:dateTime,upnp:artist,upnp:album,upnp:genre,dc:contributer,upnp:storageFree,upnp:storageUsed,upnp:originalTrackNumber,dc:publisher,dc:language,dc:region,dc:description,upnp:toc,@childCount,upnp:albumArtURI@dlna:profileID,res@dlna:cleartextSize, startIndex = 0, count = 10, sortCriteria =
2012-01-05 22:17:22,703 DEBUG [OnlineRepositoryDAOImpl] Retrieving list of [FEED, WEB_RESOURCE] OnlineRepositories for AUDIO
2012-01-05 22:17:22,703 DEBUG [OnlineRepositoryDAOImpl] Retrieving list of [LIVE_STREAM] OnlineRepositories for AUDIO
2012-01-05 22:17:22,703 DEBUG [AudioDeliveryEngine] Retrieving resource information for item 1000000000500001 and profile Playstation 3
2012-01-05 22:17:22,703 DEBUG [AudioDeliveryEngine] Retrieving resource information for item 1000000000510001 and profile Playstation 3
2012-01-05 22:17:22,703 DEBUG [ServiceControlRequestHandler] Returning OK SOAP message
2012-01-05 22:17:22,718 DEBUG [WebServer] Incoming connection from /192.168.1.126:55430
2012-01-05 22:17:22,718 DEBUG [ResourceTransportRequestHandler] HEAD /resource/1000000000500001/MEDIA_ITEM/MP3$0 HTTP/1.0, headers = [Host: 192.168.1.2:8895,User-Agent: PLAYSTATION 3,Connection: close,Accept-Encoding: identity,Cache-Control: no-cache]]
2012-01-05 22:17:22,718 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.1.126
2012-01-05 22:17:22,718 DEBUG [ResourceTransportRequestHandler] Resource request accepted. Using client 'IPAddress=/192.168.1.126, Profile=Playstation 3'
2012-01-05 22:17:22,718 DEBUG [ResourceTransportRequestHandler] Request for resource 1000000000500001 and type 'MEDIA_ITEM' received
2012-01-05 22:17:22,718 DEBUG [MediaResourceRetrievalStrategy] Getting information about media item 1000000000500001 (online)
2012-01-05 22:17:22,718 DEBUG [OnlineRepositoryDAOImpl] Reading an OnlineRepository (id = 50)
2012-01-05 22:17:22,718 DEBUG [AudioDeliveryEngine] Retrieving resource information for item 1000000000500001, format MP3 and profile Playstation 3
2012-01-05 22:17:22,718 DEBUG [ResourceTransportRequestHandler] Sending HEAD response back
2012-01-05 22:17:22,718 DEBUG [ResourceTransportRequestHandler] HTTP/1.1 200 OK, headers = [[Content-Type: audio/mpeg,Content-Length: 900000000,Date: Fri, 06 Jan 2012 04:17:22 GMT,Server: Windows 2003, UPnP/1.0 DLNADOC/1.50, Serviio/0.6.1,Cache-control: no-cache,transferMode.dlna.org: Streaming]]
2012-01-05 22:17:22,750 DEBUG [WebServer] Incoming connection from /192.168.1.126:55429
2012-01-05 22:17:22,750 DEBUG [ServiceControlRequestHandler] ServiceControl request received for action '"urn:schemas-upnp-org:service:ContentDirectory:1#GetSystemUpdateID"' from 192.168.1.126:
2012-01-05 22:17:22,750 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.1.126
2012-01-05 22:17:22,906 DEBUG [ServiceControlRequestHandler] Returning OK SOAP message
2012-01-05 22:17:22,906 DEBUG [WebServer] Incoming connection from /192.168.1.126:55428
2012-01-05 22:17:22,906 DEBUG [ServiceControlRequestHandler] ServiceControl request received for action '"urn:schemas-upnp-org:service:ContentDirectory:1#Browse"' from 192.168.1.126:
2012-01-05 22:17:22,906 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.1.126
2012-01-05 22:17:23,109 DEBUG [ContentDirectory] Browse() called for renderer Playstation 3 (profile 4) with parameters: objectID = A_OF, browseFlag = BrowseMetadata, filter = @id,upnp:class,res,res@protocolInfo,res@av:authenticationUri,res@size,dc:title,upnp:albumArtURI,res@dlna:ifoFileURI,res@protection,res@bitrate,res@duration,res@sampleFrequency,res@bitsPerSample,res@nrAudioChannels,res@resolution,res@colorDepth,dc:date,av:dateTime,upnp:artist,upnp:album,upnp:genre,dc:contributer,upnp:storageFree,upnp:storageUsed,upnp:originalTrackNumber,dc:publisher,dc:language,dc:region,dc:description,upnp:toc,@childCount,upnp:albumArtURI@dlna:profileID,res@dlna:cleartextSize, startIndex = 0, count = 1, sortCriteria =
2012-01-05 22:17:23,109 DEBUG [OnlineRepositoryDAOImpl] Retrieving list of [FEED, WEB_RESOURCE] OnlineRepositories for AUDIO
2012-01-05 22:17:23,109 DEBUG [OnlineRepositoryDAOImpl] Retrieving list of [LIVE_STREAM] OnlineRepositories for AUDIO
2012-01-05 22:17:23,109 DEBUG [ServiceControlRequestHandler] Returning OK SOAP message
2012-01-05 22:17:23,109 DEBUG [WebServer] Incoming connection from /192.168.1.126:55427
2012-01-05 22:17:23,109 DEBUG [ServiceControlRequestHandler] ServiceControl request received for action '"urn:schemas-upnp-org:service:ContentDirectory:1#GetSystemUpdateID"' from 192.168.1.126:
2012-01-05 22:17:23,109 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.1.126
2012-01-05 22:17:23,312 DEBUG [ServiceControlRequestHandler] Returning OK SOAP message
2012-01-05 22:17:23,312 DEBUG [WebServer] Incoming connection from /192.168.1.126:55426
2012-01-05 22:17:23,312 DEBUG [ServiceControlRequestHandler] ServiceControl request received for action '"urn:schemas-upnp-org:service:ContentDirectory:1#Browse"' from 192.168.1.126:
2012-01-05 22:17:23,312 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.1.126
2012-01-05 22:17:23,500 DEBUG [ContentDirectory] Browse() called for renderer Playstation 3 (profile 4) with parameters: objectID = A, browseFlag = BrowseMetadata, filter = @id,upnp:class,res,res@protocolInfo,res@av:authenticationUri,res@size,dc:title,upnp:albumArtURI,res@dlna:ifoFileURI,res@protection,res@bitrate,res@duration,res@sampleFrequency,res@bitsPerSample,res@nrAudioChannels,res@resolution,res@colorDepth,dc:date,av:dateTime,upnp:artist,upnp:album,upnp:genre,dc:contributer,upnp:storageFree,upnp:storageUsed,upnp:originalTrackNumber,dc:publisher,dc:language,dc:region,dc:description,upnp:toc,@childCount,upnp:albumArtURI@dlna:profileID,res@dlna:cleartextSize, startIndex = 0, count = 1, sortCriteria =
2012-01-05 22:17:23,515 DEBUG [ServiceControlRequestHandler] Returning OK SOAP message
2012-01-05 22:17:23,515 DEBUG [WebServer] Incoming connection from /192.168.1.126:55425
2012-01-05 22:17:23,515 DEBUG [ServiceControlRequestHandler] ServiceControl request received for action '"urn:schemas-upnp-org:service:ContentDirectory:1#Browse"' from 192.168.1.126:
2012-01-05 22:17:23,515 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.1.126
2012-01-05 22:17:23,703 DEBUG [ContentDirectory] Browse() called for renderer Playstation 3 (profile 4) with parameters: objectID = A, browseFlag = BrowseDirectChildren, filter = @id,upnp:class,res,res@protocolInfo,res@av:authenticationUri,res@size,dc:title,upnp:albumArtURI,res@dlna:ifoFileURI,res@protection,res@bitrate,res@duration,res@sampleFrequency,res@bitsPerSample,res@nrAudioChannels,res@resolution,res@colorDepth,dc:date,av:dateTime,upnp:artist,upnp:album,upnp:genre,dc:contributer,upnp:storageFree,upnp:storageUsed,upnp:originalTrackNumber,dc:publisher,dc:language,dc:region,dc:description,upnp:toc,@childCount,upnp:albumArtURI@dlna:profileID,res@dlna:cleartextSize, startIndex = 0, count = 10, sortCriteria =
2012-01-05 22:17:23,703 DEBUG [PersonDAOImpl] Retrieving number of person initials for role ARTIST
2012-01-05 22:17:23,843 DEBUG [RepositoryDAOImpl] Retrieving number of repositories for AUDIO
2012-01-05 22:17:23,843 DEBUG [GenreDAOImpl] Retrieving number of genres for AUDIO
2012-01-05 22:17:24,296 DEBUG [OnlineRepositoryDAOImpl] Retrieving list of [FEED, WEB_RESOURCE] OnlineRepositories for AUDIO
2012-01-05 22:17:24,296 DEBUG [OnlineRepositoryDAOImpl] Retrieving list of [LIVE_STREAM] OnlineRepositories for AUDIO
2012-01-05 22:17:24,312 DEBUG [ServiceControlRequestHandler] Returning OK SOAP message
2012-01-05 22:17:24,312 DEBUG [WebServer] Incoming connection from /192.168.1.126:55424
2012-01-05 22:17:24,312 DEBUG [ServiceControlRequestHandler] ServiceControl request received for action '"urn:schemas-upnp-org:service:ContentDirectory:1#GetSystemUpdateID"' from 192.168.1.126:
2012-01-05 22:17:24,312 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.1.126
2012-01-05 22:17:24,515 DEBUG [ServiceControlRequestHandler] Returning OK SOAP message
2012-01-05 22:17:24,515 DEBUG [WebServer] Incoming connection from /192.168.1.126:55423
2012-01-05 22:17:24,515 DEBUG [ServiceControlRequestHandler] ServiceControl request received for action '"urn:schemas-upnp-org:service:ContentDirectory:1#Browse"' from 192.168.1.126:
2012-01-05 22:17:24,515 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.1.126
2012-01-05 22:17:24,718 DEBUG [ContentDirectory] Browse() called for renderer Playstation 3 (profile 4) with parameters: objectID = A, browseFlag = BrowseMetadata, filter = @id,upnp:class,res,res@protocolInfo,res@av:authenticationUri,res@size,dc:title,upnp:albumArtURI,res@dlna:ifoFileURI,res@protection,res@bitrate,res@duration,res@sampleFrequency,res@bitsPerSample,res@nrAudioChannels,res@resolution,res@colorDepth,dc:date,av:dateTime,upnp:artist,upnp:album,upnp:genre,dc:contributer,upnp:storageFree,upnp:storageUsed,upnp:originalTrackNumber,dc:publisher,dc:language,dc:region,dc:description,upnp:toc,@childCount,upnp:albumArtURI@dlna:profileID,res@dlna:cleartextSize, startIndex = 0, count = 1, sortCriteria =
2012-01-05 22:17:24,718 DEBUG [ServiceControlRequestHandler] Returning OK SOAP message
2012-01-05 22:17:24,718 DEBUG [WebServer] Incoming connection from /192.168.1.126:55422
2012-01-05 22:17:24,718 DEBUG [ServiceControlRequestHandler] ServiceControl request received for action '"urn:schemas-upnp-org:service:ContentDirectory:1#GetSystemUpdateID"' from 192.168.1.126:
2012-01-05 22:17:24,718 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.1.126
2012-01-05 22:17:24,921 DEBUG [ServiceControlRequestHandler] Returning OK SOAP message
2012-01-05 22:17:24,921 DEBUG [WebServer] Incoming connection from /192.168.1.126:55421
2012-01-05 22:17:24,921 DEBUG [ServiceControlRequestHandler] ServiceControl request received for action '"urn:schemas-upnp-org:service:ContentDirectory:1#Browse"' from 192.168.1.126:
2012-01-05 22:17:24,921 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.1.126
2012-01-05 22:17:25,109 DEBUG [ContentDirectory] Browse() called for renderer Playstation 3 (profile 4) with parameters: objectID = 0, browseFlag = BrowseMetadata, filter = @id,upnp:class,res,res@protocolInfo,res@av:authenticationUri,res@size,dc:title,upnp:albumArtURI,res@dlna:ifoFileURI,res@protection,res@bitrate,res@duration,res@sampleFrequency,res@bitsPerSample,res@nrAudioChannels,res@resolution,res@colorDepth,dc:date,av:dateTime,upnp:artist,upnp:album,upnp:genre,dc:contributer,upnp:storageFree,upnp:storageUsed,upnp:originalTrackNumber,dc:publisher,dc:language,dc:region,dc:description,upnp:toc,@childCount,upnp:albumArtURI@dlna:profileID,res@dlna:cleartextSize, startIndex = 0, count = 1, sortCriteria =
2012-01-05 22:17:25,125 DEBUG [ServiceControlRequestHandler] Returning OK SOAP message
2012-01-05 22:17:25,968 DEBUG [WebServer] Incoming connection from /192.168.1.126:55420
2012-01-05 22:17:25,968 DEBUG [ServiceControlRequestHandler] ServiceControl request received for action '"urn:schemas-upnp-org:service:ContentDirectory:1#GetSystemUpdateID"' from 192.168.1.126:
2012-01-05 22:17:25,968 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.1.126
2012-01-05 22:17:26,125 DEBUG [ServiceControlRequestHandler] Returning OK SOAP message
2012-01-05 22:17:26,125 DEBUG [WebServer] Incoming connection from /192.168.1.126:55419
2012-01-05 22:17:26,125 DEBUG [ServiceControlRequestHandler] ServiceControl request received for action '"urn:schemas-upnp-org:service:ContentDirectory:1#GetSystemUpdateID"' from 192.168.1.126:
2012-01-05 22:17:26,125 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.1.126
2012-01-05 22:17:26,328 DEBUG [ServiceControlRequestHandler] Returning OK SOAP message
2012-01-05 22:17:26,328 DEBUG [WebServer] Incoming connection from /192.168.1.126:55418
2012-01-05 22:17:26,328 DEBUG [ServiceControlRequestHandler] ServiceControl request received for action '"urn:schemas-upnp-org:service:ContentDirectory:1#Browse"' from 192.168.1.126:
2012-01-05 22:17:26,328 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.1.126
2012-01-05 22:17:26,531 DEBUG [ContentDirectory] Browse() called for renderer Playstation 3 (profile 4) with parameters: objectID = A_OF, browseFlag = BrowseMetadata, filter = @id,upnp:class,res,res@protocolInfo,res@av:authenticationUri,res@size,dc:title,upnp:albumArtURI,res@dlna:ifoFileURI,res@protection,res@bitrate,res@duration,res@sampleFrequency,res@bitsPerSample,res@nrAudioChannels,res@resolution,res@colorDepth,dc:date,av:dateTime,upnp:artist,upnp:album,upnp:genre,dc:contributer,upnp:storageFree,upnp:storageUsed,upnp:originalTrackNumber,dc:publisher,dc:language,dc:region,dc:description,upnp:toc,@childCount,upnp:albumArtURI@dlna:profileID,res@dlna:cleartextSize, startIndex = 0, count = 1, sortCriteria =
2012-01-05 22:17:26,531 DEBUG [OnlineRepositoryDAOImpl] Retrieving list of [FEED, WEB_RESOURCE] OnlineRepositories for AUDIO
2012-01-05 22:17:26,531 DEBUG [OnlineRepositoryDAOImpl] Retrieving list of [LIVE_STREAM] OnlineRepositories for AUDIO
2012-01-05 22:17:26,531 DEBUG [ServiceControlRequestHandler] Returning OK SOAP message
2012-01-05 22:17:26,531 DEBUG [WebServer] Incoming connection from /192.168.1.126:55417
2012-01-05 22:17:26,531 DEBUG [ServiceControlRequestHandler] ServiceControl request received for action '"urn:schemas-upnp-org:service:ContentDirectory:1#GetSystemUpdateID"' from 192.168.1.126:
2012-01-05 22:17:26,531 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.1.126
2012-01-05 22:17:26,718 DEBUG [ServiceControlRequestHandler] Returning OK SOAP message
2012-01-05 22:17:26,734 DEBUG [WebServer] Incoming connection from /192.168.1.126:55416
2012-01-05 22:17:26,734 DEBUG [ServiceControlRequestHandler] ServiceControl request received for action '"urn:schemas-upnp-org:service:ContentDirectory:1#Browse"' from 192.168.1.126:
2012-01-05 22:17:26,734 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.1.126
2012-01-05 22:17:26,921 DEBUG [ContentDirectory] Browse() called for renderer Playstation 3 (profile 4) with parameters: objectID = A_OF, browseFlag = BrowseMetadata, filter = @id,upnp:class,res,res@protocolInfo,res@av:authenticationUri,res@size,dc:title,upnp:albumArtURI,res@dlna:ifoFileURI,res@protection,res@bitrate,res@duration,res@sampleFrequency,res@bitsPerSample,res@nrAudioChannels,res@resolution,res@colorDepth,dc:date,av:dateTime,upnp:artist,upnp:album,upnp:genre,dc:contributer,upnp:storageFree,upnp:storageUsed,upnp:originalTrackNumber,dc:publisher,dc:language,dc:region,dc:description,upnp:toc,@childCount,upnp:albumArtURI@dlna:profileID,res@dlna:cleartextSize, startIndex = 0, count = 1, sortCriteria =
2012-01-05 22:17:26,921 DEBUG [OnlineRepositoryDAOImpl] Retrieving list of [FEED, WEB_RESOURCE] OnlineRepositories for AUDIO
2012-01-05 22:17:26,921 DEBUG [OnlineRepositoryDAOImpl] Retrieving list of [LIVE_STREAM] OnlineRepositories for AUDIO
2012-01-05 22:17:26,937 DEBUG [ServiceControlRequestHandler] Returning OK SOAP message
2012-01-05 22:17:37,921 DEBUG [DiscoveryAdvertisementNotifier] Multicasting SSDP alive using interface eth0 (Broadcom NetXtreme 57xx Gigabit Controller) and address 192.168.1.2, timeout = 0
2012-01-05 22:17:37,921 DEBUG [DiscoveryAdvertisementNotifier] Sending 6 'alive' messages describing device 83403509-60a4-3ac0-bae1-94340baf2344
2012-01-05 22:17:39,031 DEBUG [WebServer] Incoming connection from /192.168.1.126:55415
2012-01-05 22:17:39,031 DEBUG [DeviceDescriptionRequestHandler] DeviceDescription request received for device 83403509-60a4-3ac0-bae1-94340baf2344 from 192.168.1.126 (headers = [Host: 192.168.1.2:8895,Date: Fri, 06 Jan 2012 04:21:30 GMT,User-Agent: UPnP/1.0,X-AV-Client-Info: av=5.0; cn="Sony Computer Entertainment Inc."; mn="PLAYSTATION 3"; mv="1.0";])
2012-01-05 22:17:39,031 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.1.126
2012-01-05 22:17:39,031 DEBUG [RendererManager] Looking for a renderer profile for Http headers: [Host: 192.168.1.2:8895,Date: Fri, 06 Jan 2012 04:21:30 GMT,User-Agent: UPnP/1.0,X-AV-Client-Info: av=5.0; cn="Sony Computer Entertainment Inc."; mn="PLAYSTATION 3"; mv="1.0";]
2012-01-05 22:17:39,031 DEBUG [DeviceDescriptionRequestHandler] Sending DeviceDescription XML back using profile 'Playstation 3'
2012-01-05 22:17:39,734 DEBUG [DiscoveryAdvertisementNotifier] Will advertise again in 00:01:29
2012-01-05 22:17:57,406 DEBUG [FeedUpdaterThread] Checking for new and expired online resources
2012-01-05 22:17:57,406 DEBUG [OnlineRepositoryDAOImpl] Reading all OnlineRepositories
2012-01-05 22:17:57,406 DEBUG [OnlineRepositoryDAOImpl] Reading an OnlineRepository (id = 4)
2012-01-05 22:17:57,421 DEBUG [OnlineRepositoryDAOImpl] Reading an OnlineRepository (id = 5)
2012-01-05 22:17:57,421 DEBUG [OnlineRepositoryDAOImpl] Reading an OnlineRepository (id = 29)
2012-01-05 22:17:57,421 DEBUG [OnlineRepositoryDAOImpl] Reading an OnlineRepository (id = 36)
2012-01-05 22:17:57,437 DEBUG [OnlineRepositoryDAOImpl] Reading an OnlineRepository (id = 40)
2012-01-05 22:17:57,437 DEBUG [OnlineRepositoryDAOImpl] Reading an OnlineRepository (id = 43)
2012-01-05 22:17:57,437 DEBUG [OnlineRepositoryDAOImpl] Reading an OnlineRepository (id = 44)
2012-01-05 22:17:57,437 DEBUG [OnlineRepositoryDAOImpl] Reading an OnlineRepository (id = 45)
2012-01-05 22:17:57,437 DEBUG [OnlineRepositoryDAOImpl] Reading an OnlineRepository (id = 50)
2012-01-05 22:17:57,437 DEBUG [OnlineRepositoryDAOImpl] Reading an OnlineRepository (id = 51)
Help!
Xbox 360 - PlayStation 3 - Sony BDP-S370 - HTC Evo V & HP TouchPad running CM9 (Android) - serviio 1.0.1 - Windows 2003 Server Standard x64 Edition
Mugwump
Post Fri Jan 06, 2012 5:23 am
CigDangle wrote:After trying a handful, none of these seem to work for me. They work just fine on my Serviio server.
Help!
The only thing I can think of that you might have entered them as a web resource. They all need to be entered only as Live stream with these settings only. Hope this is all that is wrong :)
Regards Mugwump
See you are on .6.1 so I will try another train of thought..perhaps you are trying to add a url for the thumbnail? I do not even try I just leave it blank and the Samsung that I use just puts in the tired old sax player. That is why Zip setup the selection gui so that you could rename the stream url to make it more human readable on the player. The actual stream url is essentially hidden from the player so that the only data that needs to be displayed is the name of the station ...which you can set.
I have not had any luck at all getting meta data to work from an audio stream to the client device so I do not even try, this is the main reason why you can give the stream url a name. So letting Serviio just send out the received bits of the stream is the only way to make things work reliably. In fact many devices choke on meta data if it suddenly interrupts an audio stream.
Let us know if you are still having trouble with the ps3 and sony bd player, it should work as it seems from your DEBUG that you are using the correct profile for the ps3.
CigDangle
Post Fri Jan 06, 2012 1:59 pm
I have this all set correctly, but it seems to be an issue with Sony devices. My Android was able to connect to live audio streams correctly.
See this topic:
/viewtopic.php?f=4&t=4633
Mugwump
Post Fri Jan 06, 2012 9:22 pm
CigDangle wrote:I have this all set correctly, but it seems to be an issue with Sony devices. My Android was able to connect to live audio streams correctly.
See this topic:
Have you tried adjusting the DLNA settings on the PS3? Once when I did try using Serviio with a PS3 that my nephew owns I did have to force some settings on the PS3 for the PS3 to see online content.
With Samsungs it was necessary for Zip to send a fake file size info so that Allshare (the Samsung Upnp interface) thinks that the stream has a set duration file. In beta I saw no indication of online streaming audio problems with Sony devices...but this does not mean that some setups with the PS3 and Sony DLNA might not have problems. I will see if I can find someone with a PS3 and mess around to see if I can duplicate the problem.
Try a PM to Patters memberlist.php?mode=viewprofile&u=761 or Illico memberlist.php?mode=viewprofile&u=549 they are the gurus with Sony profiling. Someone must have noticed problems with Sony devices during beta for Online audio streams ...so to my way of thinking there is something in the network traffic methods causing the PS3 and your BD S370 to not index the stream items created by Serviio.
If it ain't broke....just let me have a crack at it!
Mugwump
Post Sat Jan 07, 2012 8:51 am
See this topic:
Try this interface setting so that Serviio will only display content that is put within a limited number of folders
limiting the number of possible displayed categories for online content to be displayed
As an after thought ...try setting the stream name field to the URL as well and see if Sony dlna accepts the url data from a different field. To my way of thinking just maybe the PS3 will automagically parse the other mp3 meta data without having to just think of a url as a single playlist item like a Samsung Allshare based device does. If I remember correctly the software that my brother uses with his PS3 (PS3 Media Server) will send meta data to the ps3 with a radio plugin...but he can no longer get the Windows only radio plugin to work with new releases of PMS from the Google guys.
Like I said I saw no indication that these urls were causing problems with the Sony beta testers, so I hope that there is simply something wrong with the way your network setup PS3 sees the data coming in from Serviio.
s44
Post Mon Feb 18, 2013 6:01 pm
This is great -- I knew most of these (WWFM used to be my local station!), but not the Swiss one.
But is there a particular reason Serviio wants to transcode all of these to 48k mp3, introducing some nasty artefacting in the process? Is it something in the generic device profile? The renderer is an Android device running Bubble UPNP, which *should* decode anything at any bitrate.
Mugwump
Post Mon Feb 18, 2013 10:00 pm
That is strange with a straight Linux install using ffmpeg it does not change bit rate or the stream if the device being streamed to is mp3 friendly, which most are. I cannot say what is going on I have not seen this behavior. The mp3 streams that I posted will be 44100 or 48000 depending upon source on my devices they are not transcoded.
However Petr had to spoof the duration of the file to give the stream a phoney duration to make streams work on most devices.
I my case the render profile is correct because the devices that I stream to are both Samsung C-D series devices which are well supported in Serviio.
I would post a question in another section with the specifics about your setup, sounds like your renderer does not need to have a transcode for mp3 same as most devices, if I remember bubble is just an Android port of Twonky Media so I have no idea what it expects to handshake for steam mp3, ogg, wma, aac, or flac settings.
Return to Audio streams
