Sat May 05, 2012 1:49 pm by smoce
The problem is that it does not load large files.
When loading movie a.avi after a while it reports an "devices are disconnected"
Try, the RSS feed and if you it makes too .. according to the log I see the problem: (
Thanks for the info...
- Code:
2012-05-05 15:34:38,837 INFO [MediaServer] ------------------------------------------------------------------------
2012-05-05 15:34:38,840 INFO [MediaServer] Serviio DLNA media streaming server v 0.6.2 (rev. aec3abd196d6+)
2012-05-05 15:34:38,841 INFO [MediaServer] Petr Nejedly 2009-2011
2012-05-05 15:34:38,841 INFO [MediaServer] http://www.serviio.org
2012-05-05 15:34:38,841 INFO [MediaServer] Java 1.6.0_29-Sun Microsystems Inc.
2012-05-05 15:34:38,841 INFO [MediaServer] OS Windows 7 x86 6.1
2012-05-05 15:34:38,842 INFO [MediaServer] File encoding: windows-1250
2012-05-05 15:34:38,843 INFO [MediaServer] Headless mode enabled: true
2012-05-05 15:34:38,844 INFO [MediaServer] User home dir: C:\
2012-05-05 15:34:38,844 INFO [MediaServer] Temp dir: C:\Windows\TEMP\
2012-05-05 15:34:38,844 INFO [MediaServer] ------------------------------------------------------------------------
2012-05-05 15:34:39,313 INFO [RestletServer] Starting Restlet server exposed on port 23423
2012-05-05 15:34:39,723 INFO [DBSchemaUpdateExecutor] Checking if DB schema needs to be updated
2012-05-05 15:34:46,891 INFO [ProfilesDefinitionParser] Parsing Profiles definition
2012-05-05 15:34:49,006 INFO [ProfilesDefinitionParser] Added profile 'Generic DLNA profile' (id=1)
2012-05-05 15:34:50,579 INFO [ProfilesDefinitionParser] Added profile 'Samsung TV (B-series)' (id=2)
2012-05-05 15:34:51,688 INFO [ProfilesDefinitionParser] Added profile 'Xbox 360' (id=3)
2012-05-05 15:34:52,280 INFO [ServiioConsole] Starting Serviio Console
2012-05-05 15:34:52,959 INFO [ServiioConsole] Connecting to Serviio REST on localhost:23423
2012-05-05 15:34:53,233 INFO [ProfilesDefinitionParser] Added profile 'Playstation 3' (id=4)
2012-05-05 15:34:53,999 INFO [ProfilesDefinitionParser] Added profile 'Samsung TV (A-series)' (id=5)
2012-05-05 15:34:54,457 INFO [ProfilesDefinitionParser] Added profile 'DirecTV HD-DVR' (id=6)
2012-05-05 15:34:57,953 INFO [ProfilesDefinitionParser] Added profile 'Samsung TV / player (C/D-series)' (id=7)
2012-05-05 15:34:58,275 INFO [ProfilesDefinitionParser] Added profile 'LG TV / player' (id=8)
2012-05-05 15:35:00,220 INFO [ProfilesDefinitionParser] Added profile 'Sony Bravia TV (2011)' (id=9)
2012-05-05 15:35:02,543 INFO [ProfilesDefinitionParser] Added profile 'Sony BD Player / SMP' (id=10)
2012-05-05 15:35:03,660 INFO [ProfilesDefinitionParser] Added profile 'Panasonic Viera' (id=12)
2012-05-05 15:35:04,595 INFO [ProfilesDefinitionParser] Added profile 'Toshiba REGZA' (id=13)
2012-05-05 15:35:05,190 INFO [ProfilesDefinitionParser] Added profile 'WDTV Live' (id=14)
2012-05-05 15:35:05,316 INFO [ProfilesDefinitionParser] Added profile 'LaCie LaCinema Media Player' (id=15)
2012-05-05 15:35:05,734 INFO [ProfilesDefinitionParser] Added profile 'Manta WIFI Centre' (id=16)
2012-05-05 15:35:05,934 INFO [ProfilesDefinitionParser] Added profile 'Pure Flow' (id=17)
2012-05-05 15:35:06,670 INFO [ProfilesDefinitionParser] Added profile 'Sharp Aquos' (id=18)
2012-05-05 15:35:07,075 INFO [ProfilesDefinitionParser] Added profile 'Sony Bravia TV (2010)' (id=19)
2012-05-05 15:35:07,960 INFO [ProfilesDefinitionParser] Added profile 'Philips' (id=20)
2012-05-05 15:35:08,504 INFO [ProfilesDefinitionParser] Added profile 'Sony Bravia TV (2009)' (id=21)
2012-05-05 15:35:10,774 INFO [WebServer] Socket buffer set to 65535 bytes
2012-05-05 15:35:10,776 INFO [Device] Created UPnP Device with UUID: b860b956-69d7-3c30-a31c-beb5ca5db24c, bound address: 192.168.99.250
2012-05-05 15:35:10,852 INFO [PluginCompilerThread] Looking for plugins at C:\Program Files\Serviio\bin\..\plugins
2012-05-05 15:35:10,854 INFO [PluginCompilerThread] Started looking for plugins
2012-05-05 15:35:11,489 INFO [AbstractTranscodingDeliveryEngine] Cleaning transcode engine and its data
2012-05-05 15:35:11,624 INFO [WebServer] WebServer starting on port 8895
2012-05-05 15:35:11,659 INFO [EventDispatcher] Starting EventDispatcher
2012-05-05 15:35:11,667 INFO [DiscoveryAdvertisementNotifier] Starting DiscoveryAdvertisementNotifier
2012-05-05 15:35:11,670 INFO [EventSubscriptionExpirationChecker] Starting EventSubscriptionExpirationChecker
2012-05-05 15:35:11,685 INFO [RendererExpirationChecker] Starting RendererExpirationChecker
2012-05-05 15:35:11,685 INFO [RendererSearchSender] Searching for Renderer devices
2012-05-05 15:35:11,878 INFO [DiscoverySSDPMessageListener] Starting DiscoverySSDPMessageListener using interface eth3 (Atheros AR8132 PCI-E Fast Ethernet Controller (NDIS 6.20)) and address 192.168.99.250, timeout = 0
2012-05-05 15:35:14,468 INFO [RendererManager] Stored a new renderer: uuid='c8e4b92d-e675-4266-9f02-e64370260eea', name = 'LG TV / player', ipAddress='192.168.99.251', profile = '8'
2012-05-05 15:35:15,728 INFO [RendererManager] Stored a new renderer: uuid='70064f90-1dd2-11b2-9d7b-db63be6ce7cf', name = 'MediaRenderer', ipAddress='192.168.99.251', profile = '1'
2012-05-05 15:35:19,875 INFO [Messages] Loaded console message bundle for locale: en
2012-05-05 15:35:19,905 INFO [UpdateChecker] Checking if a new version is available
2012-05-05 15:35:21,522 INFO [ContentDirectoryDefinitionParser] Parsing ContentDirectory definition
2012-05-05 15:35:24,182 INFO [BrowsingCategoriesMessages] Loaded browsing categories message bundle for locale: en
2012-05-05 15:35:39,560 INFO [LibraryAdditionsCheckerThread] Started looking for newly added files
2012-05-05 15:35:39,568 INFO [FeedUpdaterThread] Started looking for information about online resources
2012-05-05 15:35:39,585 INFO [LibraryUpdatesCheckerThread] Started looking for updates to currently shared files
2012-05-05 15:36:21,770 INFO [LibraryAdditionsCheckerThread] Finished looking for newly added files
2012-05-05 15:36:21,870 INFO [LibraryUpdatesCheckerThread] Finished looking for updates to currently shared files
2012-05-05 15:36:21,974 INFO [LibraryAdditionsCheckerThread] Started looking for newly added files
2012-05-05 15:36:21,974 INFO [LibraryUpdatesCheckerThread] Started looking for updates to currently shared files
RSS File:http://lgtv.smoce.net/lgtv/a.avi - 700Mb movie
ERRORb.mp4 - 8Mb movie
OK
I am from Czech and apologize for any errors in language.
