Re: Web UI in PHP (revised)
NPuser
npuser wrote:I believe you can simply comment the line 126 per Mark... Here is previous post about the issue.http://forum.serviio.org/viewtopic.php?p=43658#p43658
NPuser
lmd wrote:npuser wrote:I believe you can simply comment the line 126 per Mark... Here is previous post about the issue.http://forum.serviio.org/viewtopic.php?p=43658#p43658
NPuser
Thanks for the suggestion - I'd searched but hadn't come across that post before.
I've now done as suggested, but am getting the following in the debug 'response' box:
I was just using http://www.google.com as the url this time as a test. The strange thing is, when I hit 'Add' nothing appears in the list. In the normal behaviour, does this appear before you hit the 'Save' button (like adding a local path - which works just fine on my set up)?
Thanks for the help!
Andy
mpemberton5 wrote:lmd wrote:npuser wrote:I believe you can simply comment the line 126 per Mark... Here is previous post about the issue.http://forum.serviio.org/viewtopic.php?p=43658#p43658
NPuser
Andy
Yep, an error code 0 states all was successful. Turn debugging off and you should be 100% now. Give it a whirl and let us know!
Timestamp: 22/05/2012 01:31:36
Warning: Use of getAttributeNode() is deprecated. Use getAttribute() instead.
Source File: http://mediabox/serviioweb/
Line: 0
Timestamp: 22/05/2012 01:31:40
Warning: Use of attributes' specified attribute is deprecated. It always returns true.
Line: 0
Timestamp: 22/05/2012 01:31:46
Warning: Key event not available on some keyboard layouts: key="c" modifiers="accel, alt"
Source File: chrome://browser/content/browser.xul
Line: 0
Warning: Key event not available on GTK2: key="u" modifiers="accel,shift"
Line: 0
Timestamp: 22/05/2012 01:31:51
Warning: Error in parsing value for 'background-repeat'. Declaration dropped.
Line: 0
Timestamp: 22/05/2012 01:32:24
Line: 0
[code]Timestamp: 27/05/2012 04:48:48
Warning: reference to undefined property j[d]
Source File: http://ajax.googleapis.com/ajax/libs/jquery/1.7.1/jquery.min.js
Line: 3
Warning: reference to undefined property i.nodeType
Source File: http://ajax.googleapis.com/ajax/libs/jqueryui/1.8.17/jquery-ui.min.js
Line: 14
Warning: reference to undefined property a.nodeType
Line: 3
Warning: reference to undefined property a.selector
Line: 2
Timestamp: 27/05/2012 04:48:10
Warning: reference to undefined property this.tools[name]
Source File: chrome://firebug/content/bti/inProcess/browser.js
Line: 315
Warning: reference to undefined property b[l[ka](c / 6)]
Source File: http://www.google-analytics.com/ga.js
Line: 22
Warning: reference to undefined property b.dh
Line: [/code]
Xmantium wrote:Hello Mark, have got a build ready for the upcoming v1.0?
zip has provided the documentation in the beta section
mpemberton5 wrote:So I found the issue. It was related to having a blank list and attempting to add the first entry. The HTML section the javascript code was attempting to add to was non-existent. So I added the section regardless if there were any entries or not. I failed to add that in my testing.
Please go to the wiki (link in signature line) to download the latest. This update also includes the known issue with the erroneous line described in some of the previous posts.
Cheers to all,
qoolbox wrote:Hi
Does the WebUI v1.0.2 fix the UTF-8 indexing issue ? directories and files with special caracter like éàè... are not indexed actually
thanks
qoolbox wrote:Bugs confirmed :
- UTF-8 FIles are not display on the DLNA Client (but WEBUI turned in french display well the éèà characters, and localdef is well set in the NAS Environnement)
- adding files by browsing in the Shared Folder TAB doesnt work because interface seems to add a "/" at the end of the Path removing it manually, make it works
