VLC as DLNA player
It quite easy, just choose View --> Playlist -->Local Network -->Universal Plug’n Play., then you will find the Servio Server and all your folders.
A picture is worth a thousand words:
Regards / 73
serviio-buddy wrote:This works great except it doesn't seem to play any live video streams.
abubin wrote:if you are going to play movies through PC/mac, why not use network shares? That is much faster and will support any format that your media player supports?
The only reason I can think of for using DLNA player through a Pc/mac is for testing purposes?
jhb50 wrote:VLC is slow to get the info. Just click on Serviio and wait a few minutes. The list of folders should appear.
jhb50 wrote:Why don't you try it?
