Free Movie Fans
r-win
Post Mon Feb 04, 2013 6:49 am
Re: Free Movie Fans
atc98092 wrote:I also am having difficulty with this plug-in. It shows the available movies, but of the 8 or so that I've tried only one would play (Cowboys & Aliens).
Well, this is indeed strange. Everything looks alright, as far as I can tell. I can see that it takes a looong time to fetch all the items, but that shouldn't be a problem. I can see it failing to retrieve some items (like Repo Man), but it's retrying those as expected (and it still fails then btw). Can you try it with a much smaller set first (like 10?) to see if it's having any problem with the amount of movies you fetch? I have to admit that I only tried a few movies, but those all worked for me.
My kids have watched from the Animation category a lot of times, and I've never heard problems from them (also set to 50, but Serviio is running on a big-ass server).
Linksys WRT320N | Samsung PS-50C7700 | Microsoft XBOX 360 | Windows 8.1 | Linux Ubuntu 13.04
Post Mon Feb 04, 2013 1:49 pm
Re: Free Movie Fans
Interesting note. I left the TV on the "cannot play file" screen and was doing something in the kitchen. Suddenly I heard the audio start and looked up to see the movie begin. It seems that is just takes an extrordinary amount of time for the stream to begin.
I watched the complete Dark Shadows movie, but was disappointed with the picture quality. Was a little jerky and very soft. Went to my den and started The Avengers on my Sony SNP-N200 and was much more impressed. No jerkyness and the picture looked better (although a smaller 32" vs 53" screen may account for much of that). Will experiment further, but perhaps there was just a network issue with the web site the first time I tried it.
I'll try again tonight using the bedroom TV (another Sony box and 42" screen).
r-win
Post Mon Feb 04, 2013 1:51 pm
Re: Free Movie Fans
atc98092 wrote:I watched the complete Dark Shadows movie, but was disappointed with the picture quality.
Well, don't expect full hd. I think the movies are 640 x something, so the quality isn't that excellent. However, on my Samsung 50" they still look pretty decent.
jshg46
Post Mon Feb 04, 2013 6:06 pm
Re: Free Movie Fans
Works great now.
bikergrove
Post Mon Feb 04, 2013 8:13 pm
Re: Free Movie Fans
It was ok for me It giving me this now?
2013-02-04 20:09:23,979 WARN  [FeedUpdaterThread] An error occured while scanning for online item information, will continue
java.io.IOException: Unexpected error while invoking plugin (Free Movie Fan): Connection timed out: connect
   at org.serviio.library.online.WebResourceParser.parse(WebResourceParser.java:58)
   at org.serviio.library.online.OnlineLibraryManager.findResource(OnlineLibraryManager.java:171)
Caused by: java.net.ConnectException: Connection timed out: connect
   at java.net.PlainSocketImpl.socketConnect(Native Method)
   at java.net.PlainSocketImpl.doConnect(Unknown Source)
   at java.net.PlainSocketImpl.connectToAddress(Unknown Source)
   at java.net.PlainSocketImpl.connect(Unknown Source)
   at java.net.SocksSocketImpl.connect(Unknown Source)
   at java.net.Socket.connect(Unknown Source)
   at sun.net.NetworkClient.doConnect(Unknown Source)
   at sun.net.www.http.HttpClient.openServer(Unknown Source)
   at sun.net.www.http.HttpClient.<init>(Unknown Source)
   at sun.net.www.http.HttpClient.New(Unknown Source)
   at sun.net.www.protocol.http.HttpURLConnection.getNewHttpClient(Unknown Source)
   at sun.net.www.protocol.http.HttpURLConnection.plainConnect(Unknown Source)
   at sun.net.www.protocol.http.HttpURLConnection.connect(Unknown Source)
   at sun.net.www.protocol.http.HttpURLConnection.getInputStream(Unknown Source)
   at org.codehaus.groovy.runtime.DefaultGroovyMethods.configuredInputStream(DefaultGroovyMethods.java:16692)
   at org.codehaus.groovy.runtime.DefaultGroovyMethods.newReader(DefaultGroovyMethods.java:16760)
   at org.codehaus.groovy.runtime.DefaultGroovyMethods.getText(DefaultGroovyMethods.java:15130)
   at org.codehaus.groovy.runtime.DefaultGroovyMethods.getText(DefaultGroovyMethods.java:15102)
   at org.codehaus.groovy.runtime.dgm$375.invoke(Unknown Source)
   at org.codehaus.groovy.runtime.callsite.PojoMetaMethodSite$PojoMetaMethodSiteNoUnwrapNoCoerce.invoke(PojoMetaMethodSite.java:271)
   at org.codehaus.groovy.runtime.callsite.PojoMetaMethodSite.call(PojoMetaMethodSite.java:53)
   at org.codehaus.groovy.runtime.callsite.AbstractCallSite.call(AbstractCallSite.java:112)
   at FreeMovieFan.extractItems(FreeMovieFan.groovy:139)
   at org.serviio.library.online.WebResourceUrlExtractor$1.executePluginMethod(WebResourceUrlExtractor.java:32)
   at org.serviio.library.online.WebResourceUrlExtractor$1.executePluginMethod(WebResourceUrlExtractor.java:29)
   at org.serviio.library.online.PluginExecutionProcessor$1.call(PluginExecutionProcessor.java:50)
   at java.util.concurrent.FutureTask$Sync.innerRun(Unknown Source)
   at java.util.concurrent.FutureTask.run(Unknown Source)
   at java.util.concurrent.ThreadPoolExecutor$Worker.runTask(Unknown Source)
   at java.util.concurrent.ThreadPoolExecutor$Worker.run(Unknown Source)
   at java.lang.Thread.run(Unknown Source)
Post Tue Feb 05, 2013 1:18 am
Re: Free Movie Fans
Yeah, I knew it wouldn't be HD, and it wasn't the softness so much as the jerkiness. Like I said, There was no jerkiness when using the Sony box, but since it was with two different movies I don't know if it was the movie or the box that made the difference.
Now this evening I'm encountering the same issue as bikergrove:
2013-02-04 17:13:32,421 WARN [ProcessExecutor] Process cmd has a return code of 1! This is a possible error.
2013-02-04 17:14:18,421 WARN [ProcessExecutor] Process cmd has a return code of 1! This is a possible error.
2013-02-04 17:14:50,953 WARN [FeedUpdaterThread] An error occured while scanning for online item information, will continue
at java.net.TwoStacksPlainSocketImpl.socketConnect(Native Method)
at java.net.AbstractPlainSocketImpl.doConnect(Unknown Source)
at java.net.AbstractPlainSocketImpl.connectToAddress(Unknown Source)
at java.net.AbstractPlainSocketImpl.connect(Unknown Source)
at java.util.concurrent.ThreadPoolExecutor.runWorker(Unknown Source)
EDIT: it seems www.fmovief.com is offline. That would explain the timeouts! :shock:
r-win
Post Tue Feb 05, 2013 11:08 am
Re: Free Movie Fans
atc98092 wrote:EDIT: it seems http://www.fmovief.com is offline. That would explain the timeouts! :shock:
Actually, I don't think it's offline...it's working from another ip adress, so I suspect they've blocked the IP addresses. From their FAQ: "We only record your IP Address for abuse, we will block the IP Address from abuse". Serviio does a lot of calls to check for the video format, so I guess that tipped them off. For now, I'll take the plugin offline, until we know for sure.
Post Tue Feb 05, 2013 1:43 pm
Re: Free Movie Fans
Well, last night I could not open their web page in my browser, but this morning I can. I do believe at the time they were down, but I see what you mean about the potential block. I'll give it a shot tonight when I get home from work.
r-win
Post Tue Feb 05, 2013 1:46 pm
Re: Free Movie Fans
I could open it this morning from work, but not from home (openend a vpn connection to test). Let me know if it works for you again.
devil2
Post Tue Feb 05, 2013 2:19 pm
Re: Free Movie Fans
Is it possible to do something like you did to Free Movies to a portuguese site called http://www.wareztuga.tv/
gerryo
Post Tue Feb 05, 2013 7:54 pm
Re: Free Movie Fans
r-win wrote:I could open it this morning from work, but not from home (openend a vpn connection to test). Let me know if it works for you again.
Seeing a similar problem here, getting "400 for URL: http://www.fmovief.com/year/2012?p=1" in the log file.
It was last working for me on February 3rd 2013.
I see a redirect message when using Firefox.
It also says cookies must be enabled, & when these are disabled in Firefox the page wont load :(
Looks like cookies might need to be accepted before this site can be accessed.
Post Wed Feb 06, 2013 12:18 am
Re: Free Movie Fans
Looks like they consider us abusers. I could open their web page at work, but from home it still times out. Looks like I've been blocked. I'll recycle my DSL router later this evening and see if I can get a new IP address. Maybe I can contact them and ask for clarification on what they consider abuse. Perhaps we can get them to allow Serviio, but since they make money from the ads on their site, I'm not holding out for much.
slyguy42o
Post Wed Feb 06, 2013 12:53 am
Re: Free Movie Fans
yup blocked here too
gerryo
Post Wed Feb 06, 2013 9:02 am
Re: Free Movie Fans
atc98092 wrote:.....but since they make money from the ads on their site, I'm not holding out for much.
I guess this is the real reason why it's not working :cry:
There is an advert played just before the movie begins, you have to click an "X" to begin playing.
This looks like it would be very hard to workaround, they really want you to view these revenue generators.
Cookies need to be accepted before you get to view the home page.
If you could somehow get a listing, you might be able to generate thumbnails.
Even so, clicking on a movie in Serviio requires user input (click the"X") to begin playback.
Is all or any of that do-able in a groovy?
r-win
Post Wed Feb 06, 2013 10:07 am
Re: Free Movie Fans
All of that was covered, except for the cookie. They've added that like yesterday, or the day before that. Since I'm not able to connect to their site again (blocked ip, I suppose), I can't fix this anymore.
The [X] before playing has nothing to do with the actual video stream, which is easy to retrieve. The groovy didn't even need to access the movie information page. All you need is the movie id, and that's already available from the main page. With the movie id, you can call some php file, and it will give you the real movie url.
gerryo
Post Wed Feb 06, 2013 4:47 pm
Re: Free Movie Fans
r-win wrote:The [X] before playing has nothing to do with the actual video stream, which is easy to retrieve. The groovy didn't even need to access the movie information page. All you need is the movie id, and that's already available from the main page. With the movie id, you can call some php file, and it will give you the real movie url.
OK, thanks for getting back & explaining.
Is there anyway to accept cookies in Serviio, without doing this Serviio can't even reach the main page?
If you turn off cookies in Firefox you can see the browser looping forever, Serviio gives up with an error & then retries
later, getting the same error.
I expect they have added in the cookies message to comply with EU regulations, but it messed up what was working well.
r-win
Post Wed Feb 06, 2013 6:29 pm
Re: Free Movie Fans
gerryo wrote:I expect they have added in the cookies message to comply with EU regulations, but it messed up what was working well.
I expect they added the "judge.php" script to prevent this script from working, tbh. But getting cookies is easy enough. Just do a to the main page, fetch the headers, and get the header with the name Set-Cookie.
When doing a request, include the cookie, and you're done. But...I can't change the script anymore, since I can't test it...
Post Thu Feb 07, 2013 2:00 pm
Re: Free Movie Fans
I rebooted my DSL router last night to grab a new IP address, and I can again get to their web site. I can't find any kind of information page, although they do list an email address. I'm going to ask them what is considered abuse, since I can't find anything on the web site itself. I did find their single reference to abuse on the FAQ page, but nothing beyond that.
widewings
Post Fri Feb 08, 2013 11:48 pm
Re: Free Movie Fans
I have the same problem
2013-02-09 12:06:10,968 INFO  [PluginCompilerThread] Added Web Resouce plugin Free Movie Fan (FreeMovieFan.groovy), version: 12
2013-02-09 12:06:56,156 WARN  [FeedUpdaterThread] An error occured while scanning for online item information, will continue
java.io.IOException: Server returned HTTP response code: 400 for URL: http://www.fmovief.com/
   at org.serviio.util.HttpClient.retrieveBinaryFileFromURL(HttpClient.java:72)
   at org.serviio.library.online.feed.FeedParser.parseFeedStream(FeedParser.java:115)
   at org.serviio.library.online.feed.FeedParser.parse(FeedParser.java:90)
   at org.serviio.library.online.OnlineLibraryManager.findResource(OnlineLibraryManager.java:169)
2013-02-09 12:46:37,531 WARN  [FeedUpdaterThread] An error occured while scanning for online item information, will continue
java.io.IOException: Server returned HTTP response code: 400 for URL: http://www.fmovief.com/?maxItems=50
Suggestions please.....
Post Sat Feb 09, 2013 1:44 am
Re: Free Movie Fans
widewings wrote:I have the same problem
No suggestions to offer. Web browser code 400 means the browser (or in this case Serviio) cannot communicate with the web site. There is something at their server that considers the Serviio connection as abuse. It then blocks our home IP address, which results in no connection.
I have emailed the support staff in an attempt to find out why it is classified that way, and if there's anything we can modify in the groovy file to eliminate the issue. It's entirely possible they won't allow this sort of connection, since we will never see the ads on the web site that supports their operation. An understandable business viewpoint, unfortunately. :(
Return to Available plugins
