ILIVE - A Video Livestreams Server Collection
Post Wed May 01, 2013 3:17 am
Re: ILIVE - A Video Livestreams Server Collection
It may be that Ilive is varying their html page. I thought I had handled this but I see the code in the plugin was incorrect, so I have posted V14 with the fix.
_SDK_
Post Wed May 01, 2013 1:31 pm
Many thanks for your hard work.
I truly appreciate it.
Regards
_SDK_
Post Tue May 14, 2013 4:31 am
Haven't been able to get iLive plug working for a while now. Everything that failed before is working, iLive webpage, etc. (unlike before where I was locked out for having a virus) All other things Serviio (plugs, videos) working perfectly at this time. I have deleted and re-added, re-ordered, in the library many times over the last week or so... same result. Posting a bit of the log FWIW.
Regards...
[DiscoveryAdvertisementNotifier] Sending 6 'alive' messages describing device 6abd6656-330d-34bc-8480-58290724adb1
2013-05-13 23:22:44,818 DEBUG [FeedItemUrlExtractor] ILive: Parsing with ILive V14
2013-05-13 23:22:46,590 DEBUG [DiscoveryAdvertisementNotifier] Will advertise again in 00:03:24 (advertisement duration is 1800 sec.)
2013-05-13 23:22:48,894 WARN [FeedUpdaterThread] An error occured while scanning for online item information, will continue
java.io.IOException: Unexpected error while invoking plugin (ILive): index is out of range 0..-1 (index = 0)
at org.serviio.library.online.WebResourceParser.parse(WebResourceParser.java:58)
at org.serviio.library.online.OnlineLibraryManager.findResource(OnlineLibraryManager.java:171)
Caused by: java.lang.IndexOutOfBoundsException: index is out of range 0..-1 (index = 0)
at org.codehaus.groovy.runtime.DefaultGroovyMethods.getAt(DefaultGroovyMethods.java:6202)
at org.codehaus.groovy.runtime.dgm$310.invoke(Unknown Source)
at org.codehaus.groovy.runtime.callsite.PojoMetaMethodSite$PojoMetaMethodSiteNoUnwrapNoCoerce.invoke(PojoMetaMethodSite.java:271)
at org.codehaus.groovy.runtime.callsite.PojoMetaMethodSite.call(PojoMetaMethodSite.java:53)
at org.codehaus.groovy.runtime.callsite.CallSiteArray.defaultCall(CallSiteArray.java:42)
at org.codehaus.groovy.runtime.callsite.AbstractCallSite.call(AbstractCallSite.java:108)
at org.codehaus.groovy.runtime.callsite.AbstractCallSite.call(AbstractCallSite.java:116)
at ILive.extractItems(ILive.groovy:268)
at org.serviio.library.online.WebResourceUrlExtractor$1.executePluginMethod(WebResourceUrlExtractor.java:32)
at org.serviio.library.online.WebResourceUrlExtractor$1.executePluginMethod(WebResourceUrlExtractor.java:29)
at org.serviio.library.online.PluginExecutionProcessor$1.call(PluginExecutionProcessor.java:50)
at java.util.concurrent.FutureTask$Sync.innerRun(FutureTask.java:303)
at java.util.concurrent.FutureTask.run(FutureTask.java:138)
at java.util.concurrent.ThreadPoolExecutor$Worker.runTask(ThreadPoolExecutor.java:895)
at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:918)
at java.lang.Thread.run(Thread.java:680)
2013-05-13 23:22:48,895 DEBUG [OnlineRepositoryDAOImpl] Reading an OnlineRepository (id = 17)
2013-05-13 23:22:48,896 DEBUG [OnlineLibraryManager] Resource http://www.skysports.plus/ not in cache yet, loading it
2013-05-13 23:22:48,896 DEBUG [WebResourceParser] Parsing web resource 'http://www.skysports.plus/'
2013-05-13 23:22:48,896 DEBUG [WebResourceParser] Found matching url extractor (skysportsplus) for resource http://www.skysports.plus/
2013-05-13 23:22:48,896 DEBUG [FeedItemUrlExtractor] skysportsplus: Starting parsing resource: http://www.skysports.plus/
2013-05-13 23:22:48,896 DEBUG [FeedItemUrlExtractor] skysportsplus: Parsing with SkysportsPlus V24
Post Tue May 14, 2013 1:03 pm
Thanks for posting. Yes they changed their site. Version 15 now posted with that fix and a number of improvements. The default sort is now by Title, and terms may be specified to limit the streams displayed. See the description in the first post for updated details.
Lincsguy
Post Thu May 23, 2013 12:13 am
Hi, Im having some trouble loading the content for this, here is a portion of my log.
2013-05-23 01:08:26,046 DEBUG [OnlineLibraryManager] Resource http://www.ilive.to/channels/general not in cache yet, loading it
2013-05-23 01:08:26,046 DEBUG [WebResourceParser] Parsing web resource 'http://www.ilive.to/channels/general'
2013-05-23 01:08:26,046 DEBUG [WebResourceParser] Found matching url extractor (ILive) for resource http://www.ilive.to/channels/general
2013-05-23 01:08:26,046 DEBUG [FeedItemUrlExtractor] ILive: Starting parsing resource: http://www.ilive.to/channels/general
2013-05-23 01:08:26,046 DEBUG [FeedItemUrlExtractor] ILive: Parsing with ILive V15
2013-05-23 01:08:26,593 WARN [FeedUpdaterThread] An error occured while scanning for online item information, will continue
java.io.IOException: Unexpected error while invoking plugin (ILive): No such property: count for class: java.lang.String
Caused by: groovy.lang.MissingPropertyException: No such property: count for class: java.lang.String
at org.codehaus.groovy.runtime.ScriptBytecodeAdapter.unwrap(ScriptBytecodeAdapter.java:50)
at org.codehaus.groovy.runtime.callsite.GetEffectivePojoPropertySite.getProperty(GetEffectivePojoPropertySite.java:63)
at org.codehaus.groovy.runtime.callsite.AbstractCallSite.callGetProperty(AbstractCallSite.java:227)
at ILive.extractItems(ILive.groovy:271)
at java.util.concurrent.FutureTask$Sync.innerRun(Unknown Source)
at java.util.concurrent.FutureTask.run(Unknown Source)
at java.util.concurrent.ThreadPoolExecutor.runWorker(Unknown Source)
at java.util.concurrent.ThreadPoolExecutor$Worker.run(Unknown Source)
at java.lang.Thread.run(Unknown Source)
2013-05-23 01:08:26,593 DEBUG [OnlineRepositoryDAOImpl] Reading an OnlineRepository (id = 79)
2013-05-23 01:08:26,609 DEBUG [OnlineLibraryManager] Resource http://www.ilive.to/channels/sport not in cache yet, loading it
2013-05-23 01:08:26,609 DEBUG [WebResourceParser] Parsing web resource 'http://www.ilive.to/channels/sport'
2013-05-23 01:08:26,609 DEBUG [WebResourceParser] Found matching url extractor (ILive) for resource http://www.ilive.to/channels/sport
2013-05-23 01:08:26,609 DEBUG [FeedItemUrlExtractor] ILive: Starting parsing resource: http://www.ilive.to/channels/sport
2013-05-23 01:08:26,609 DEBUG [FeedItemUrlExtractor] ILive: Parsing with ILive V15
2013-05-23 01:08:27,093 WARN [FeedUpdaterThread] An error occured while scanning for online item information, will continue
2013-05-23 01:08:27,093 DEBUG [OnlineRepositoryDAOImpl] Reading an OnlineRepository (id = 80)
2013-05-23 01:08:27,109 DEBUG [OnlineLibraryManager] Resource http://www.ilive.to/channels/music not in cache yet, loading it
2013-05-23 01:08:27,109 DEBUG [WebResourceParser] Parsing web resource 'http://www.ilive.to/channels/music'
2013-05-23 01:08:27,109 DEBUG [WebResourceParser] Found matching url extractor (ILive) for resource http://www.ilive.to/channels/music
2013-05-23 01:08:27,109 DEBUG [FeedItemUrlExtractor] ILive: Starting parsing resource: http://www.ilive.to/channels/music
2013-05-23 01:08:27,109 DEBUG [FeedItemUrlExtractor] ILive: Parsing with ILive V15
2013-05-23 01:08:27,640 WARN [FeedUpdaterThread] An error occured while scanning for online item information, will continue
Any help would be appreciated.
Post Thu May 23, 2013 3:21 am
@lincsguy I see no reason for this. Mine works correctly. Try redownloading the plugin. I assume you are using latest Serviio 1.2
Lincsguy
Post Thu May 23, 2013 10:56 am
jhb50 wrote:@lincsguy I see no reason for this. Mine works correctly. Try redownloading the plugin. I assume you are using latest Serviio 1.2
Thanks for the reply.
Yes, Version 1.2.1.
I have just deleted the plugin, shutdown Serviio and re-installed Ilive.groovy from viewtopic.php?f=20&t=6086#p43887. Here is a copy of the log regarding plugins being added:
2013-05-23 11:42:07,843 INFO [RendererSearchSender] Searching for Renderer devices
2013-05-23 11:42:11,843 INFO [PluginCompilerThread] Added Web Resouce plugin 4OD (UK only) (Channel4od.groovy), version: 1
2013-05-23 11:42:12,765 INFO [PluginCompilerThread] Added Web Resouce plugin cricfree.tv (CricFreeTV.groovy), version: 1
2013-05-23 11:42:13,437 INFO [PluginCompilerThread] Added Web Resouce plugin ILive (ILive.groovy), version: 15
2013-05-23 11:42:14,421 INFO [Messages] Loaded console message bundle for locale: en
2013-05-23 11:42:17,359 INFO [PluginCompilerThread] Added Feed plugin BBC iPlayer (UK only) (IPlayer.groovy), version: 1
2013-05-23 11:42:20,546 INFO [ContentDirectoryDefinitionParser] Parsing ContentDirectory definition
2013-05-23 11:42:23,562 INFO [BrowsingCategoriesMessages] Loaded browsing categories message bundle for locale: en
2013-05-23 11:42:25,734 INFO [PluginCompilerThread] Added Web Resouce plugin ITVPlayer (UK only) (ITVPlayer.groovy), version: 3
2013-05-23 11:42:25,859 INFO [PluginCompilerThread] Added Feed plugin LiveFeeds (LiveFeeds.groovy), version: 1
2013-05-23 11:42:27,093 INFO [PluginCompilerThread] Added Web Resouce plugin skysportsplus (SkysportsPlus.groovy), version: 24
2013-05-23 11:42:28,640 INFO [PluginCompilerThread] Added Web Resouce plugin Stopstream (Stopstream.groovy), version: 30
2013-05-23 11:42:33,890 INFO [FeedUpdaterThread] Started looking for information about online resources
Here is a copy regarding Plugins:
2013-05-23 11:45:34,421 WARN [FeedUpdaterThread] An error occured while scanning for online item information, will continue
2013-05-23 11:46:39,781 WARN [FeedUpdaterThread] An error occured while scanning for online item information, will continue
java.io.IOException: Unexpected error while invoking plugin (Stopstream): The operation took more than 60000 ms and has been cancelled.
Caused by: java.lang.RuntimeException: The operation took more than 60000 ms and has been cancelled.
at org.serviio.library.online.PluginExecutionProcessor.execute(PluginExecutionProcessor.java:64)
at org.serviio.library.online.WebResourceUrlExtractor.parseWebResource(WebResourceUrlExtractor.java:29)
at org.serviio.library.online.WebResourceParser.parse(WebResourceParser.java:56)
... 4 more
2013-05-23 11:47:44,343 WARN [FeedUpdaterThread] An error occured while scanning for online item information, will continue
2013-05-23 11:48:54,781 WARN [FeedUpdaterThread] An error occured while scanning for online item information, will continue
... 4 more
2013-05-23 11:49:21,796 INFO [RendererManager] Stored a new renderer: uuid='df707e86-ce6d-46c5-841f-63499565d45b', name = 'Unrecognized device', ipAddress='192.168.1.64', profile = '1'
2013-05-23 11:49:55,593 WARN [FeedUpdaterThread] An error occured while scanning for online item information, will continue
Have I got another plugin in the list that may be conflicting? I have re-installed Serviio three times now and each time I seem to be getting this same problem.
What does 'No such property: count for class: java.lang.String' mean exactly?
Post Fri May 24, 2013 1:52 am
Try the attached groovy. Its a very subtle change but perhaps your java is different than my V7-21. If it works I will update the released plugin.
Lincsguy
Post Fri May 24, 2013 10:57 am
LEGEND..!!!
This works perfectly, thnk you very much :D
Socratez
Post Fri May 24, 2013 12:36 pm
Super. Thank you very much.
Post Tue May 28, 2013 11:30 am
Version 16 posted
siriusblack
Post Tue Jun 25, 2013 8:08 pm
HI
Just wondering if ilive is working for anyone
It stopped working for me today
However the thumbnails are still showing up but not loading
Here is my log
ilive.txt
(1.51 KiB) Downloaded 1598 times
Beta Tester
Post Wed Jun 26, 2013 12:55 pm
Works for me. You did not show all of the ilive parse, but perhaps your bad eigttrack is screwing things up. Why not get rid of it.
siriusblack
Post Wed Jun 26, 2013 1:53 pm
HI jhb50
Hope this helps
ilive.txt
(33.33 KiB) Downloaded 1580 times
If I need to get rid of eigttrack how do you do that please
Beta Tester
flojo
Post Wed Jun 26, 2013 5:30 pm
jhb50 wrote:Works for me. You did not show all of the ilive parse, but perhaps your bad eigttrack is screwing things up. Why not get rid of it.
Yeah Ilive looks poked.
@JHB50. What do you have as a Webresource?
Post Wed Jun 26, 2013 7:15 pm
They have changed to a redirected url which will require some new tricks. I'm working on them and will likely release with Serviio 1.3.
Post Wed Jun 26, 2013 7:17 pm
siriusblack wrote:If I need to get rid of eigttrack how do you do that please
You installed it so just reverse the process.
siriusblack
Post Thu Jun 27, 2013 11:04 am
HI jhb50
For some reason its on the laptop and I didn't install it manually
I tried to go to a old restore didn't fix it, I also tried doing a full uninstall of serviio
which also didn't fix it
any advice would be appreciated
Beta Tester
Post Thu Jun 27, 2013 1:01 pm
Pretty self explanatory "plugin matching (EightTracks)"
It says you have a plugin matching (EightTracks)
siriusblack
Post Thu Jun 27, 2013 2:30 pm
Thanks jhb50
Sorry if I don't understand
This is all new to me
we're do I dealete the eight track please
Beta Tester
Return to Available plugins
