Serviio server on WD My Book Live
thejazzman
Post Fri May 24, 2013 5:40 am
Re: Serviio server on WD My Book Live
busterdan wrote:I've now managed to get as far as the FFMPEG installation....
Basically this failed, I was mainly using Double T's instructions but have since started using JazzMan's guide...
I've updated the sources file with the entries from Double T's post viewtopic.php?p=53013#p53013 and then followed his instructions again, but all I get now are these lib errors.
MyBookLive:/usr/local/serviio/serviio-0.6.2/bin# apt-get install ffmpeg
Reading package lists... Done
Building dependency tree
Reading state information... Done
You might want to run `apt-get -f install' to correct these:
The following packages have unmet dependencies:
ffmpeg: Depends: libavcodec52 (>= 5:0.7.13) but 4:0.5.1-3 is to be installed
Depends: libavdevice52 (>= 5:0.7.13) but 4:0.5.1-3 is to be installed
Depends: libavfilter1 (>= 5:0.7.13) but it is not going to be installed
Depends: libavformat52 (>= 5:0.7.13) but 4:0.5.1-3 is to be installed
Depends: libavutil50 (>= 5:0.7.13) but it is not going to be installed
Depends: libpostproc51 (>= 5:0.7.13) but 4:0.5.1-3 is to be installed
Depends: libswscale0 (>= 5:0.7.13) but 4:0.5.1-3 is to be installed
libc6-ppc64: Depends: libc6 (= 2.11.3-4) but 2.11.2-2 is to be installed
E: Unmet dependencies. Try 'apt-get -f install' with no packages (or specify a solution).
Coming out of retirement, tried to check on updating my ffmpeg and broke it then started to get the above errors. I figured it out.
Solution
change the reference of this line in the file /etc/apt/sources.list
deb http://www.debian-multimedia.org stable main
to this
deb http://www.deb-multimedia.org oldstable main
They changed their domain name recently, plus the version of FFMPEG on stable I'm guessing is incompatible with our version of Debian. Going to OldStable has a compatible version. Good luck.
busterdan
Post Fri May 24, 2013 6:06 pm
So are you now fully up and running with Serviio?
busterdan
Post Fri May 24, 2013 6:49 pm
Decided to give it another try... now stuck on the Java install again (can't remember how I got around this before)....
/$ apt-get install openjdk-6-jdk
Building dependency tree...
aptitude-common: Breaks: aptitude (< 0.6.8-1) but 0.4.11.11-1~lenny1 is to be installed
openjdk-6-jdk: Depends: openjdk-6-jre (= 6b27-1.12.5-1) but it is not going to be installed
Recommends: libxt-dev but it is not going to be installed
thejazzman
Post Fri May 24, 2013 11:51 pm
what does your /etc/apt/sources.list look like? I think this might be where the issue is.
Then run apt-get update. Then can you run the following commands and share the results, might give another indicator.
apt-cache policy aptitude
and
apt-cache policy aptitude-common
and
apt-cache policy openjdk-6-jdk
thejazzman
Post Sat May 25, 2013 12:00 am
busterdan wrote:So are you now fully up and running with Serviio?
Yeah, but I had only removed ffmpeg in an attempt to upgrade to see if it would resolve a video stuttering issue, didn't have to go through the full install instructions.
Once I got it up and running a year and a half ago, it's something I didn't want to touch with all of my original issues(reinstalled at least 3 times, bricked my device once, etc), skipping firmware updates, even hesitant on trying the new versions of serviio. If it ain't broke, don't fix it. While it doesn't play all of the files I find, I usually can get alternate versions that work.
busterdan
Post Sat May 25, 2013 9:51 am
Yeah totally agree... I have managed to get it running but I have had to mess about a fair bit... I'm now trying to copy back 900GB of data :( :( :(
Yesterday I started by upgrading the MBL to the latest firmware... I then tried following your guide again... and got stuck at the Java install. I looked around and found a different site with instructions... basically copy over Java to the MBL and then use a chmod command??? (I'm no Linux expert!!)... anyway that didn't work. I tried to update all the dependencies... that didn't work either.. I tried changing the sources list, at this point I didn't really know what I was doing but c'est la vie I thought....
I then found this... http://liushuiblog.appspot.com/2012/04/ ... l-software
And this managed to get Java to install.. :D
But when I checked the Java version it referred to the version I had tried to install early using chmod???
I decided to wipe the whole thing at that point... and go back to the previous firmware by following this... I tried guides 1 and 2 - http://community.wdc.com/t5/My-Book-Liv ... d-p/481588
Anyway they sort of worked although I still have the same Source.list and despite downgrading the MBL still shows the latest firmware in the web GUI.
I then checked the Java version and to my surprise it was showing the correct version... so I then started to follow SL06's guide viewtopic.php?f=14&t=9515
Pretty much everything went fine and I managed to install Serviio 1.2.1, I was then able to connect to the server with ServiiDroid to configure the server, add the licence etc using my phone. I was then able to connect to the Server and play some sample files, music, video and pictures using ServiiGo and also my C Series Samsung TV (not tried Playstation).... everything worked fine, all the Metadata was available.... bit slow but at least it's working.
As I say at the moment I am just in the process of copying all my data back as it was wiped when I did the apparent firmware downgrade, unfortunately the Server seems to have crashed and I can't seem to restart it... a MBL reboot is in order but that will have to wait another 8 hours or so :(
thejazzman
Post Sat May 25, 2013 2:09 pm
I'm still curious to what your source list contains as I think that might be part of the issue you had with java and ffmpeg. As I check the policy command on some of those services on my device, it's showing that the versions I currently have installed are the ones that would be installed if I tried to again.
busterdan wrote:I then checked the Java version and to my surprise it was showing the correct version... so I then started to follow SL06's guide viewtopic.php?f=14&t=9515
Looking at his guide, looks like he's pointing out the differences between the guide I helped with to get to the current version of serviio. Item I see as a potential issue with his comments is the part about skipping ffmpeg. He shows that he has version 0.5.1 of ffmpeg running. Personally I've found that I can not run half of my video library if using that default version. The version that I just got installed the other day is 0.7.x and has a lot more codex integrated. Back when I tried to compile ffmpeg myself to have the different codex I ran out of room, and with additional room I still couldn't get it to work properly so I'm hesitant in trying again.
busterdan wrote:As I say at the moment I am just in the process of copying all my data back as it was wiped when I did the apparent firmware downgrade, unfortunately the Server seems to have crashed and I can't seem to restart it... a MBL reboot is in order but that will have to wait another 8 hours or so :(
Yeah, those downgrade instructions seem to mirror what I had to do when it bricked, and I remember it wiped the public folder as part of restoring the drive to original. Maybe if you had other shares created in the dashboard they would have still been there, not sure?
So I think you may want to get ffmpeg updated if it's not, so if you can run the command
ffmpeg
so that we can see the current version, then share the contents of your source.list, as well as the output of
apt-cache policy ffmpeg
, we might be able to get to the bottom of everything. apt-cache policy command shows information about the install package indicated, current version installed, the version it wants to install and all version available to the servers you have indicated in the source.list. So we can see if a bad version is coming into play.
busterdan
Post Sat May 25, 2013 3:30 pm
Thanks for the reply... I'm still copying 10mb/sec argh!!!!
Its about to finish then i am going to move MBL away from my main PC and copy the remain stuff by USB..at 30/mb with a 1000 mob lan laptop.... still so slow though.....
Seems to be a problem though Serviio isn't starting... not properly looked yet though... however after a restart i thought it would auto start?... I'll run those commands when I am up and also post my sources... i might update ffmeg as well as you have
busterdan
Post Sat May 25, 2013 3:53 pm
Here is my Sources...
deb http://archive.debian.org/debian-archive/debian/ lenny main contrib non-free
deb-src http://archive.debian.org/debian-archive/debian/ lenny main contrib non-free
deb http://archive.debian.org/debian-archiv ... -security/ lenny/updates main
deb-src http://archive.debian.org/debian-archiv ... -security/ lenny/updates main
deb http://ftp.us.debian.org/debian/ squeeze main contrib non-free
deb http://archive.debian.org/debian lenny main non-free contrib
deb-src http://archive.debian.org/debian lenny main non-free contrib
#deb http://ftp.us.debian.org/debian/ sid main
#deb http://ftp.us.debian.org/debian/ experimental main
Result of the ffmeg command...
/etc/apt$ ffmpeg
FFmpeg version SVN-r0.5.1-4:0.5.1-3, Copyright (c) 2000-2009 Fabrice Bellard, et al.
configuration: --disable-encoder=h263 --disable-encoder=h263p --disable-encoder=mpeg2video --disable-encoder=mpeg4 --disable-encoder=msmpeg4v1 --disable-encoder=msmpeg4v2 --disable-encoder=msmpeg4v3 --extra-version=4:0.5.1-3 --prefix=/usr --enable-avfilter --enable-avfilter-lavf --enable-vdpau --enable-bzlib --enable-libdirac --enable-libgsm --enable-libopenjpeg --enable-libschroedinger --enable-libspeex --enable-libtheora --enable-libvorbis --enable-pthreads --enable-zlib --disable-stripping --disable-vhook --enable-runtime-cpudetect --enable-gpl --enable-postproc --enable-swscale --enable-x11grab --enable-libfaad --enable-libdc1394 --disable-altivec --enable-shared --disable-static
libavutil 49.15. 0 / 49.15. 0
libavcodec 52.20. 1 / 52.20. 1
libavformat 52.31. 0 / 52.31. 0
libavdevice 52. 1. 0 / 52. 1. 0
libavfilter 0. 4. 0 / 0. 4. 0
libswscale 0. 7. 1 / 0. 7. 1
built on Mar 12 2010 22:49:34, gcc: 4.4.3
and the apt-cache command...
MyBookLive:~# apt-cache policy ffmpeg
ffmpeg:
Installed: 4:0.5.1-3
Candidate: 5:0.7.15-dmo1
Version table:
5:0.7.15-dmo1 0
500 http://www.deb-multimedia.org oldstable/main Packages
4:0.5.10-1 0
500 http://ftp.us.debian.org squeeze/main Packages
*** 4:0.5.1-3 0
100 /var/lib/dpkg/status
MyBookLive:~#
busterdan
Post Sat May 25, 2013 4:11 pm
OK... not sure what is going on now... trying to connect with Serviidroid... the connect gets to about 80% then fails with "The connection initially succeeded but not all the data could be loaded"... not sure if it is a bandwidth issue?.. as I'm dumping another 400 gb onto the MBL
ServiioGO... does connect though... very slow however... correction just crashed hmmmmm!! :x
thejazzman
Post Sat May 25, 2013 5:13 pm
first, if you are coping a lot of files, i would probably turn off the updating of the library every x minutes so that it's not trying to process all of the files at the same time as the coping, or just turn off the serviio server until the coping is done.
For comparison, this is what ffmpeg would look like if you can get the higher version installed
ffmpeg version 0.7.15, Copyright (c) 2000-2013 the FFmpeg developers
  built on Feb 22 2013 10:33:49 with gcc 4.4.5
  configuration: --enable-libdc1394 --prefix=/usr --extra-cflags='-Wall -g -fPIC -DPIC' --cc='ccache cc' --enable-shared --enable-libmp3lame --enable-gpl --enable-libvorbis --enable-pthreads --enable-libfaac --enable-libxvid --enable-postproc --enable-x11grab --enable-libgsm --enable-libtheora --enable-libopencore-amrnb --enable-libopencore-amrwb --enable-libx264 --enable-libspeex --enable-nonfree --disable-stripping --enable-avfilter --enable-libdirac --disable-decoder=libdirac --enable-libfreetype --enable-libschroedinger --disable-encoder=libschroedinger --enable-version3 --enable-libopenjpeg --enable-libvpx --enable-librtmp --extra-libs=-lgcrypt --disable-altivec --disable-armv5te --disable-armv6 --disable-vis
  libavutil    50. 43. 0 / 50. 43. 0
  libavcodec   52.123. 0 / 52.123. 0
  libavformat  52.111. 0 / 52.111. 0
  libavdevice  52.  5. 0 / 52.  5. 0
  libavfilter   1. 80. 0 /  1. 80. 0
  libswscale    0. 14. 1 /  0. 14. 1
You do have a lot of servers specified with a lot of options, so that could be where the issue with java and ffmpeg is/was coming from. Mine is very short, I would recommend that you # out most of your servers leaving just the two I have not pounded. The # sign in this case is an indicator to ignore that listing. Save the changes and run "apt-get update" to update the listings, then try installing ffmpeg again.
busterdan
Post Sun May 26, 2013 8:00 am
Cheers I will do that in a minute...
My server is running and shares are added but the library doesn't seem to be updating at the moment whereas the other day there were no issues with that....
busterdan
Post Sun May 26, 2013 8:53 am
OK here is the log having updated Sources.list and the running Apt-get update... then attempting to reinstall FFMPEG.
Seems like it has unistalled but there was a problem with the multimedia "old stable " repository... now running the FFMPEG command I get nothing so it looks like it isn't installed now...
login as: root
root@192.168.0.10's password:
Linux MyBookLive 2.6.32.11-svn70860 #1 Thu May 17 13:32:51 PDT 2012 ppc
Disclaimer: SSH provides access to the network device and all its
content, only users with advanced computer networking and Linux experience
should enable it. Failure to understand the Linux command line interface
can result in rendering your network device inoperable, as well as allowing
unauthorized users access to your network. If you enable SSH, do not share
the root password with anyone you do not want to have direct access to all
the content on your network device.
MyBookLive:~# apt-get update
Get:1 http://www.deb-multimedia.org oldstable Release.gpg [198B]
Hit http://www.deb-multimedia.org oldstable Release
Hit http://ftp.us.debian.org squeeze Release.gpg
Err http://www.deb-multimedia.org oldstable Release
Get:2 http://www.deb-multimedia.org oldstable Release [19.1kB]
Ign http://www.deb-multimedia.org oldstable Release
Ign http://www.deb-multimedia.org oldstable/main Packages/DiffIndex
Hit http://www.deb-multimedia.org oldstable/main Packages
Ign http://ftp.us.debian.org squeeze/main Packages/DiffIndex
Hit http://ftp.us.debian.org squeeze/main Packages
Fetched 19.3kB in 0s (21.4kB/s)
W: GPG error: http://www.deb-multimedia.org oldstable Release: The following signatures couldn't be verified because the public key is not available: NO_PUBKEY 07DC563D1F41B907
W: You may want to run apt-get update to correct these problems
MyBookLive:~#
MyBookLive:~# apt-get remove ffmpeg x264 libx264-dev libvpx-dev librtmp0 librtmp-dev
Package x264 is not installed, so not removed
Package libx264-dev is not installed, so not removed
Package libvpx-dev is not installed, so not removed
Package librtmp0 is not installed, so not removed
Package librtmp-dev is not installed, so not removed
The following packages were automatically installed and are no longer required:
webui libplist1 libtalloc2 apache-php-webdav strings smbclient
libantlr3c-3.2-0 libtagc0 libtdb1 netatalk smbfs openssl-blacklist strace
networking-general libnetaddr-ip-perl admin-rest-api date-time afp
nas-safepoint bmon samba-common-bin apm-zermatt wd-lib sysstat
libtag1-vanilla wd-nas php-apc libpam-winbind alerts
libapache2-mod-xsendfile upnp-nas multiarch-support liblzo2-2 samba
libpkcs11-helper1 vft itunes orion-resources libunistring0 cifs-utils
libtag1c2a samba-common bonjour openvpn winbind sqlite3 libnet-upnp-perl
mdadm openvpn-blacklist forked-daapd
Use 'apt-get autoremove' to remove them.
The following packages will be REMOVED:
ffmpeg
0 upgraded, 0 newly installed, 1 to remove and 245 not upgraded.
After this operation, 811kB disk space will be freed.
Do you want to continue [Y/n]? Y
(Reading database ...
dpkg: warning: files list file for package `ramlog' missing, assuming package has no files currently installed.
dpkg: warning: files list file for package `libparted0' missing, assuming package has no files currently installed.
(Reading database ... 22357 files and directories currently installed.)
Removing ffmpeg ...
MyBookLive:~# apt-get install ffmpeg
The following extra packages will be installed:
binutils liba52-0.7.4 liba52-0.7.4-dev libavcodec-dev libavcodec52
libavdevice52 libavfilter1 libavformat-dev libavformat52 libavutil-dev
libavutil50 libc-bin libc-dev-bin libc6 libc6-dev libc6-ppc64 libdc1394-22
libdc1394-22-dev libdirac-decoder0 libdirac-dev libfaac-dev libfaac0
libfaad-dev libfaad2 libgsm1-dev libjack-jackd2-0 libmp3lame-dev libmp3lame0
libogg-dev libogg0 libopencore-amrnb-dev libopencore-amrnb0
libopencore-amrwb-dev libopencore-amrwb0 liborc-0.4-0 liborc-0.4-dev
libpostproc51 libraw1394-11 libraw1394-dev librtmp0 libschroedinger-dev
libswscale0 libtheora-dev libtheora0 libusb-1.0-0 libvorbis-dev libvorbis0a
libvorbisenc2 libvorbisfile3 libvpx0 libx264-118 libx264-dev libxvidcore4
libxvidcore4-dev linux-libc-dev pkg-config zlib1g zlib1g-dev
Suggested packages:
binutils-doc glibc-doc jackd2 liborc-0.4-doc libraw1394-doc
Recommended packages:
manpages-dev gcc c-compiler
libavfilter0
The following NEW packages will be installed:
ffmpeg liba52-0.7.4 liba52-0.7.4-dev libavfilter1 libavutil50 libc-dev-bin
libc6-dev libdc1394-22-dev libdirac-decoder0 libdirac-dev libfaac-dev
libfaac0 libfaad-dev libgsm1-dev libjack-jackd2-0 libmp3lame-dev libmp3lame0
libogg-dev libopencore-amrnb-dev libopencore-amrnb0 libopencore-amrwb-dev
libopencore-amrwb0 liborc-0.4-dev libraw1394-dev librtmp0
libschroedinger-dev libtheora-dev libvorbis-dev libvorbisfile3 libvpx0
libx264-118 libx264-dev libxvidcore4 libxvidcore4-dev linux-libc-dev
pkg-config zlib1g-dev
The following packages will be upgraded:
binutils libavcodec-dev libavcodec52 libavdevice52 libavformat-dev
libavformat52 libavutil-dev libc-bin libc6 libc6-ppc64 libdc1394-22 libfaad2
libogg0 liborc-0.4-0 libpostproc51 libraw1394-11 libswscale0 libtheora0
libusb-1.0-0 libvorbis0a libvorbisenc2 zlib1g
22 upgraded, 37 newly installed, 1 to remove and 222 not upgraded.
Need to get 33.7MB of archives.
After this operation, 45.9MB of additional disk space will be used.
WARNING: The following packages cannot be authenticated!
libavutil50 libavdevice52 libavformat-dev libavformat52 libfaac0 libfaac-dev
libx264-118 libx264-dev libavcodec-dev libavutil-dev libmp3lame0
libmp3lame-dev libxvidcore4 libxvidcore4-dev libvpx0 libavcodec52
libswscale0 libavfilter1 libpostproc51 ffmpeg
Install these packages without verification [y/N]? y
Get:1 http://www.deb-multimedia.org oldstable/main libavutil50 5:0.7.15-dmo1 [80.9kB]
Get:2 http://www.deb-multimedia.org oldstable/main libavdevice52 5:0.7.15-dmo1 [43.2kB]
Get:3 http://www.deb-multimedia.org oldstable/main libavformat-dev 5:0.7.15-dmo1 [482kB]
Get:4 http://ftp.us.debian.org squeeze/main libc6-ppc64 2.11.3-4 [4467kB]
Get:5 http://www.deb-multimedia.org oldstable/main libavformat52 5:0.7.15-dmo1 [594kB]
Get:6 http://www.deb-multimedia.org oldstable/main libfaac0 1.28-0.3 [46.9kB]
Get:7 http://www.deb-multimedia.org oldstable/main libfaac-dev 1.28-0.3 [50.0kB]
Get:8 http://www.deb-multimedia.org oldstable/main libx264-118 3:0.118.2085+git8a62835-0.1+1 [569kB]
Get:9 http://www.deb-multimedia.org oldstable/main libx264-dev 3:0.118.2085+git8a62835-0.1+1 [586kB]
Get:10 http://www.deb-multimedia.org oldstable/main libavcodec-dev 5:0.7.15-dmo1 [2482kB]
Get:11 http://www.deb-multimedia.org oldstable/main libavutil-dev 5:0.7.15-dmo1 [92.3kB]
Get:12 http://www.deb-multimedia.org oldstable/main libmp3lame0 3.98.4-0.0 [271kB]
Get:13 http://ftp.us.debian.org squeeze/main libc-bin 2.11.3-4 [765kB]
Get:14 http://www.deb-multimedia.org oldstable/main libmp3lame-dev 3.98.4-0.0 [304kB]
Get:15 http://www.deb-multimedia.org oldstable/main libxvidcore4 2:1.2.2-0.1 [270kB]
Get:16 http://ftp.us.debian.org squeeze/main libc6 2.11.3-4 [4461kB]
Get:17 http://www.deb-multimedia.org oldstable/main libxvidcore4-dev 2:1.2.2-0.1 [306kB]
Get:18 http://www.deb-multimedia.org oldstable/main libvpx0 0.9.7.p1-2.squeeze2 [273kB]
Get:19 http://www.deb-multimedia.org oldstable/main libavcodec52 5:0.7.15-dmo1 [3462kB]
Get:20 http://ftp.us.debian.org squeeze/main zlib1g 1:1.2.3.4.dfsg-3 [78.3kB]
Get:21 http://ftp.us.debian.org squeeze/main binutils 2.20.1-16 [4109kB]
Get:22 http://www.deb-multimedia.org oldstable/main libswscale0 5:0.7.15-dmo1 [104kB]
Get:23 http://www.deb-multimedia.org oldstable/main libavfilter1 5:0.7.15-dmo1 [256kB]
Get:24 http://www.deb-multimedia.org oldstable/main libpostproc51 5:0.7.15-dmo1 [60.9kB]
Get:25 http://www.deb-multimedia.org oldstable/main ffmpeg 5:0.7.15-dmo1 [275kB]
Get:26 http://ftp.us.debian.org squeeze/main libraw1394-11 2.0.5-2 [54.2kB]
Get:27 http://ftp.us.debian.org squeeze/main libusb-1.0-0 2:1.0.8-2 [33.7kB]
Get:28 http://ftp.us.debian.org squeeze/main libdc1394-22 2.1.2-3 [121kB]
Get:29 http://ftp.us.debian.org squeeze/main libjack-jackd2-0 1.9.6~dfsg.1-2 [158kB]
Get:30 http://ftp.us.debian.org squeeze/main libraw1394-dev 2.0.5-2 [79.3kB]
Get:31 http://ftp.us.debian.org squeeze/main librtmp0 2.3-2 [55.7kB]
Get:32 http://ftp.us.debian.org squeeze/main libogg0 1.2.0~dfsg-1 [16.7kB]
Get:33 http://ftp.us.debian.org squeeze/main libogg-dev 1.2.0~dfsg-1 [68.5kB]
Get:34 http://ftp.us.debian.org squeeze/main libvorbis0a 1.3.1-1+squeeze1 [111kB]
Get:35 http://ftp.us.debian.org squeeze/main libvorbisenc2 1.3.1-1+squeeze1 [123kB]
Get:36 http://ftp.us.debian.org squeeze/main libvorbisfile3 1.3.1-1+squeeze1 [25.3kB]
Get:37 http://ftp.us.debian.org squeeze/main libvorbis-dev 1.3.1-1+squeeze1 [470kB]
Get:38 http://ftp.us.debian.org squeeze/main liba52-0.7.4 0.7.4-14 [31.1kB]
Get:39 http://ftp.us.debian.org squeeze/main liba52-0.7.4-dev 0.7.4-14 [50.7kB]
Get:40 http://ftp.us.debian.org squeeze/main libc-dev-bin 2.11.3-4 [208kB]
Get:41 http://ftp.us.debian.org squeeze/main linux-libc-dev 2.6.32-48 [844kB]
Get:42 http://ftp.us.debian.org squeeze/main libc6-dev 2.11.3-4 [2900kB]
Get:43 http://ftp.us.debian.org squeeze/main zlib1g-dev 1:1.2.3.4.dfsg-3 [190kB]
Get:44 http://ftp.us.debian.org squeeze/main libtheora0 1.1.1+dfsg.1-3 [430kB]
Get:45 http://ftp.us.debian.org squeeze/main libtheora-dev 1.1.1+dfsg.1-3 [479kB]
Get:46 http://ftp.us.debian.org squeeze/main libgsm1-dev 1.0.13-3 [39.8kB]
Get:47 http://ftp.us.debian.org squeeze/main libfaad2 2.7-6 [177kB]
Get:48 http://ftp.us.debian.org squeeze/main libfaad-dev 2.7-6 [193kB]
Get:49 http://ftp.us.debian.org squeeze/main libdc1394-22-dev 2.1.2-3 [165kB]
Get:50 http://ftp.us.debian.org squeeze/main libdirac-decoder0 1.0.2-3 [329kB]
Get:51 http://ftp.us.debian.org squeeze/main libdirac-dev 1.0.2-3 [744kB]
Get:52 http://ftp.us.debian.org squeeze/main liborc-0.4-0 1:0.4.6-2 [135kB]
Get:53 http://ftp.us.debian.org squeeze/main liborc-0.4-dev 1:0.4.6-2 [215kB]
Get:54 http://ftp.us.debian.org squeeze/main pkg-config 0.25-1.1 [58.7kB]
Get:55 http://ftp.us.debian.org squeeze/main libschroedinger-dev 1.0.9-2 [337kB]
Get:56 http://ftp.us.debian.org squeeze/main libopencore-amrnb0 0.1.2-1 [101kB]
Get:57 http://ftp.us.debian.org squeeze/main libopencore-amrnb-dev 0.1.2-1 [121kB]
Get:58 http://ftp.us.debian.org squeeze/main libopencore-amrwb0 0.1.2-1 [52.3kB]
Get:59 http://ftp.us.debian.org squeeze/main libopencore-amrwb-dev 0.1.2-1 [58.1kB]
Fetched 33.7MB in 8s (3935kB/s)
debconf: delaying package configuration, since apt-utils is not installed
(Reading database ... 22328 files and directories currently installed.)
Removing libavfilter0 ...
(Reading database ... 22315 files and directories currently installed.)
Preparing to replace libc6-ppc64 2.11.2-2 (using .../libc6-ppc64_2.11.3-4_powerpc.deb) ...
Unpacking replacement libc6-ppc64 ...
Preparing to replace libc-bin 2.11.2-2 (using .../libc-bin_2.11.3-4_powerpc.deb) ...
Unpacking replacement libc-bin ...
dpkg: error processing /var/cache/apt/archives/libc-bin_2.11.3-4_powerpc.deb (--unpack):
trying to overwrite '/etc/ld.so.conf.d/libc.conf', which is also in package wd-lib 01.04.01-81092
Processing triggers for man-db ...
Errors were encountered while processing:
E: Sub-process /usr/bin/dpkg returned an error code (1)
MyBookLive:~# ffmeg version
-bash: ffmeg: command not found
MyBookLive:~# ffmpeg
-bash: ffmpeg: command not found
MyBookLive:~#
busterdan
Post Sun May 26, 2013 9:56 am
Bit stuck now... returning to my original sources list.. an apt-get update seems to result in lots of errors, including Key errors... I haven't got a clue where to go from here.. oh well :?
login as: root
Hit http://archive.debian.org lenny Release.gpg
Ign http://archive.debian.org ... Release.gpg
Ign http://archive.debian.org .../-security/ Packages
Ign http://archive.debian.org .../lenny/updates Packages
Ign http://archive.debian.org .../main Packages
Ign http://archive.debian.org .../-security/ Sources
Ign http://archive.debian.org .../lenny/updates Sources
Ign http://archive.debian.org .../main Sources
Err http://archive.debian.org .../-security/ Packages
404 Not Found [IP: 193.62.202.28 80]
Err http://archive.debian.org .../lenny/updates Packages
Err http://archive.debian.org .../main Packages
Err http://archive.debian.org .../-security/ Sources
Err http://archive.debian.org .../lenny/updates Sources
Err http://archive.debian.org .../main Sources
Ign http://archive.debian.org lenny/main Packages/DiffIndex
Ign http://archive.debian.org lenny/contrib Packages/DiffIndex
Ign http://archive.debian.org lenny/non-free Packages/DiffIndex
Ign http://archive.debian.org lenny/main Sources/DiffIndex
Ign http://archive.debian.org lenny/contrib Sources/DiffIndex
Ign http://archive.debian.org lenny/non-free Sources/DiffIndex
Hit http://archive.debian.org lenny/main Packages
Hit http://archive.debian.org lenny/contrib Packages
Hit http://archive.debian.org lenny/non-free Packages
Hit http://archive.debian.org lenny/main Sources
Hit http://archive.debian.org lenny/contrib Sources
Hit http://archive.debian.org lenny/non-free Sources
Ign http://ftp.us.debian.org squeeze/contrib Packages/DiffIndex
Ign http://ftp.us.debian.org squeeze/non-free Packages/DiffIndex
Hit http://ftp.us.debian.org squeeze/contrib Packages
Hit http://ftp.us.debian.org squeeze/non-free Packages
Fetched 19.3kB in 5s (3460B/s)
W: GPG error: http://www.deb-multimedia.org oldstable Release: The following sig natures couldn't be verified because the public key is not available: NO_PUBKEY 07DC563D1F41B907
W: Failed to fetch http://archive.debian.org/debian-archiv ... security// binary-powerpc/Packages 404 Not Found [IP: 193.62.202.28 80]
W: Failed to fetch http://archive.debian.org/debian-archiv ... enny/updat es/binary-powerpc/Packages 404 Not Found [IP: 193.62.202.28 80]
W: Failed to fetch http://archive.debian.org/debian-archiv ... ain/binary -powerpc/Packages 404 Not Found [IP: 193.62.202.28 80]
W: Failed to fetch http://archive.debian.org/debian-archiv ... security// source/Sources 404 Not Found [IP: 193.62.202.28 80]
W: Failed to fetch http://archive.debian.org/debian-archiv ... enny/updat es/source/Sources 404 Not Found [IP: 193.62.202.28 80]
W: Failed to fetch http://archive.debian.org/debian-archiv ... ain/source /Sources 404 Not Found [IP: 193.62.202.28 80]
E: Some index files failed to download, they have been ignored, or old ones used instead.
MyBookLive:~#
thejazzman
Post Sun May 26, 2013 1:39 pm
For that key error, go back to the short list and run the following
apt-get install --allow-unauthenticated deb-multimedia-keyring
apt-get update
if that first line doesn't work, then try this one instead.
apt-get -y --force-yes install deb-multimedia-keyring
let me know which works.
busterdan
Post Sun May 26, 2013 4:52 pm
Unfortunately neither work...
MyBookLive:~# apt-get -y --force-yes install deb-multimedia-keyring
thejazzman
Post Mon May 27, 2013 1:22 am
busterdan wrote:Unfortunately neither work...
That is odd as the debian.org server for squeeze should be pushing 2.11.3-4 for you. Did the first command give the same output as the second one above? Try
apt-cache policy libc6
If the candidate for install is 2.11.3-4 then I would do the apt-get install libc6
then try the keyring commands again.
If 3-4 is not the candidate, provided the output for both apt-cache policy libc6-ppc64 and apt-cache policy libc6
busterdan
Post Mon May 27, 2013 4:59 pm
Jazzman, thanks for your help on this... I'm no further forward but at least you seem to know what you are doing :D I think part of the problem for me is that I have run so many commands etc... I have no idea what I've actually done..
The Serviio server is running but it wont build the library and obviously FFMPEG isn't installed. I might stick the latest version of Twonky back on... does that use a shared version ffmpeg though (if so then obviously I am going to have issues there).
Anyway here is the latest output..
MyBookLive:~# apt-cache policy libc6
libc6:
Installed: 2.11.3-4
Candidate: 2.11.3-4
Version table:
*** 2.11.3-4 0
MyBookLive:~# apt-get install libc6
libc6 is already the newest version.
libc6: Depends: libc-bin (= 2.11.3-4) but 2.11.2-2 is to be installed
MyBookLive:~#
thejazzman
Post Mon May 27, 2013 8:26 pm
Yeah, I get what you are saying. And I have at least half a clue what's to do, but I just don't get this one. According to what you just posted, it would want to install the proper version of libc, so I don't know why it's trying to install the older version.
For the building the library issue, if you followed the wiki and created a serviio user account, then try running
chown serviio -R /usr/local/serviio
I've found that after running the server additional files are created for the library and the serviio user doesn't have rights to those files. This should resolve. I would stop the server first, run the command, start the server, then do the tail command to watch the server, after it loads the profiles you will hopefully see it start to process all of the files.
Still baffled by the libc6 issue, since you had the candidate already installed, so I don't know why it's trying to install an older version.
So one suggestion, # out deb-multimedia in the source list , apt-get update, and try my first command I provided for the key change a couple posts back. If that doesn't work, then un# deb-multimedia, change oldstable to stable, save and apt-get update, then try that first key command once again(try the second as well if it doesn't work). If that works change the source back to oldstable, apt-get update, then try ffmpeg install.
Second suggestion, first run the apt-cache policy libc-bin. if the candidate is the 3-4, then try
apt-get install libc6-ppc64 libc6 libc-bin
If works, try the key command again.
busterdan
Post Mon May 27, 2013 8:58 pm
Nice one... might get time this evening to try... (not sure where you are... it's 10pm here in the UK)
