Re: Web UI in PHP (revised)
I really like that log tab idea. I would pick it up and implement it as part of the next pull request?!
1. View Log
2. View Installed Plugins with version Install (too bad not all plug dev following version numbering)
3. Update/Install Plugins - [i have a semi working version of this feature - pic below]
4. View basic server resource usage - CPU, Memory as well as processes Java and ffmpeg (i use webmin for now)
5. Reboot the server
6. Also, mediabrowser in the webconsole with iframe but with an option to launch separate session with a click
IndividualLover wrote:Hello;
I have fixed and added some functions to Serviio 1.3. The list of works are below
- Added "Enable access for new devices" option
- Added "Default Access group" option
- Changed "No_Restriction" and "Limited_Access" to "No Restriction" and "Limited Access" under access groups
- Re-Added Log File viewing
- Added "Subtitle character encoding" option
- Fixed MediaBrowser link under Remote tab
- Fixed Library Section issues
- Added Log file select option under "Logs"
- Bugfixes
* "Log file select" writing and calling log file path informations from "logfile.txt" placed under root of serviioweb folder. Linux users don't forgot give permission 777 to this file. Also don't forgot give permission serviio log folder for access to this folder.
Download Link : https://github.com/IndividualLover/Serv ... master.zip
Regards;
Xmantium wrote:Im not sure if its been merged with Marks/Swoops git to compare and merged
jive_turkey wrote:I just cloned https://github.com/IndividualLover/Serviio-Web-UI.git
[Tue Sep 10 17:29:40.033944 2013] [:error] [pid 15773] [client 192.168.1.60:50646] PHP Notice: Undefined index: ip in /var/www/html/serviio
web/view/status.php on line 137, referer: http://sirius/serviioweb/
[Tue Sep 10 17:29:48.205252 2013] [:error] [pid 19553] [client 192.168.1.60:50647] PHP Notice: Undefined variable: maxOnlineFeeds in /var/w
ww/html/serviioweb/view/library.php on line 228, referer: http://sirius/serviioweb/
[Tue Sep 10 17:29:48.205278 2013] [:error] [pid 19553] [client 192.168.1.60:50647] PHP Warning: Invalid argument supplied for foreach() in
/var/www/html/serviioweb/view/library.php on line 228, referer: http://sirius/serviioweb/
[Tue Sep 10 17:29:48.449676 2013] [:error] [pid 19553] [client 192.168.1.60:50647] PHP Warning: scandir(/lost+found): failed to open dir: P
ermission denied in /var/www/html/serviioweb/tree/jquery_folder_tree/jquery.foldertree.php on line 40, referer: http://sirius/serviioweb/
[Tue Sep 10 17:29:48.449708 2013] [:error] [pid 19553] [client 192.168.1.60:50647] PHP Warning: scandir(): (errno 13): Permission denied in
[Tue Sep 10 17:29:48.485251 2013] [:error] [pid 19553] [client 192.168.1.60:50647] PHP Warning: scandir(/root): failed to open dir: Permiss
[Tue Sep 10 17:29:48.485271 2013] [:error] [pid 19553] [client 192.168.1.60:50647] PHP Warning: scandir(): (errno 13): Permission denied in
[Tue Sep 10 17:29:51.550845 2013] [:error] [pid 19553] [client 192.168.1.60:50647] PHP Warning: scandir(/lost+found): failed to open dir: P
[Tue Sep 10 17:29:51.550872 2013] [:error] [pid 19553] [client 192.168.1.60:50647] PHP Warning: scandir(): (errno 13): Permission denied in
[Tue Sep 10 17:29:51.551257 2013] [:error] [pid 19553] [client 192.168.1.60:50647] PHP Warning: scandir(/root): failed to open dir: Permiss
[Tue Sep 10 17:29:51.551268 2013] [:error] [pid 19553] [client 192.168.1.60:50647] PHP Warning: scandir(): (errno 13): Permission denied in
[Tue Sep 10 17:29:56.864024 2013] [:error] [pid 19553] [client 192.168.1.60:50647] PHP Warning: fopen(logfile.txt): failed to open stream:
No such file or directory in /var/www/html/serviioweb/config.php on line 12, referer: http://sirius/serviioweb/
[Tue Sep 10 17:29:56.864055 2013] [:error] [pid 19553] [client 192.168.1.60:50647] PHP Warning: filesize(): stat failed for logfile.txt in
/var/www/html/serviioweb/config.php on line 13, referer: http://sirius/serviioweb/
[Tue Sep 10 17:29:56.864080 2013] [:error] [pid 19553] [client 192.168.1.60:50647] PHP Warning: fread() expects parameter 1 to be resource,
boolean given in /var/www/html/serviioweb/config.php on line 13, referer: http://sirius/serviioweb/
[Tue Sep 10 17:29:56.864091 2013] [:error] [pid 19553] [client 192.168.1.60:50647] PHP Warning: fclose() expects parameter 1 to be resource
, boolean given in /var/www/html/serviioweb/config.php on line 18, referer: http://sirius/serviioweb/
[Tue Sep 10 17:29:57.442436 2013] [:error] [pid 19553] [client 192.168.1.60:50647] PHP Warning: scandir(/lost+found): failed to open dir: P
[Tue Sep 10 17:29:57.442463 2013] [:error] [pid 19553] [client 192.168.1.60:50647] PHP Warning: scandir(): (errno 13): Permission denied in
[Tue Sep 10 17:29:57.442859 2013] [:error] [pid 19553] [client 192.168.1.60:50647] PHP Warning: scandir(/root): failed to open dir: Permiss
[Tue Sep 10 17:29:57.442871 2013] [:error] [pid 19553] [client 192.168.1.60:50647] PHP Warning: scandir(): (errno 13): Permission denied in
[Tue Sep 10 17:30:05.954893 2013] [:error] [pid 19553] [client 192.168.1.60:50647] PHP Warning: fopen(README.txt\n): failed to open stream:
No such file or directory in /var/www/html/serviioweb/view/logs.php on line 13, referer: http://sirius/serviioweb/
[Tue Sep 10 17:31:41.278794 2013] [:error] [pid 19553] [client 192.168.1.60:50647] PHP Warning: fopen(logfile.txt): failed to open stream:
[Tue Sep 10 17:31:41.278825 2013] [:error] [pid 19553] [client 192.168.1.60:50647] PHP Warning: filesize(): stat failed for logfile.txt in
[Tue Sep 10 17:31:41.278838 2013] [:error] [pid 19553] [client 192.168.1.60:50647] PHP Warning: fread() expects parameter 1 to be resource,
[Tue Sep 10 17:31:41.278849 2013] [:error] [pid 19553] [client 192.168.1.60:50647] PHP Warning: fclose() expects parameter 1 to be resource
[Tue Sep 10 17:38:24.164635 2013] [:error] [pid 15773] [client 192.168.1.60:51772] PHP Warning: scandir(/lost+found): failed to open dir: P
[Tue Sep 10 17:38:24.164670 2013] [:error] [pid 15773] [client 192.168.1.60:51772] PHP Warning: scandir(): (errno 13): Permission denied in
[Tue Sep 10 17:38:24.165185 2013] [:error] [pid 15773] [client 192.168.1.60:51772] PHP Warning: scandir(/root): failed to open dir: Permiss
[Tue Sep 10 17:38:24.165201 2013] [:error] [pid 15773] [client 192.168.1.60:51772] PHP Warning: scandir(): (errno 13): Permission denied in
[Tue Sep 10 17:44:12.920522 2013] [:error] [pid 12993] [client 192.168.1.60:52188] PHP Warning: scandir(/lost+found): failed to open dir: P
[Tue Sep 10 17:44:12.920562 2013] [:error] [pid 12993] [client 192.168.1.60:52188] PHP Warning: scandir(): (errno 13): Permission denied in
[Tue Sep 10 17:44:12.920957 2013] [:error] [pid 12993] [client 192.168.1.60:52188] PHP Warning: scandir(/root): failed to open dir: Permiss
[Tue Sep 10 17:44:12.920970 2013] [:error] [pid 12993] [client 192.168.1.60:52188] PHP Warning: scandir(): (errno 13): Permission denied in
[Tue Sep 10 17:44:31.467460 2013] [:error] [pid 12993] [client 192.168.1.60:52188] PHP Notice: Undefined variable: maxOnlineFeeds in /var/w
ww/html/serviioweb/view/library.php on line 221, referer: http://sirius/serviioweb/
[Tue Sep 10 17:44:31.467485 2013] [:error] [pid 12993] [client 192.168.1.60:52188] PHP Warning: Invalid argument supplied for foreach() in
/var/www/html/serviioweb/view/library.php on line 221, referer: http://sirius/serviioweb/
[Tue Sep 10 17:44:31.623378 2013] [:error] [pid 12993] [client 192.168.1.60:52188] PHP Warning: scandir(/lost+found): failed to open dir: P
[Tue Sep 10 17:44:31.623406 2013] [:error] [pid 12993] [client 192.168.1.60:52188] PHP Warning: scandir(): (errno 13): Permission denied in
[Tue Sep 10 17:44:31.623799 2013] [:error] [pid 12993] [client 192.168.1.60:52188] PHP Warning: scandir(/root): failed to open dir: Permiss
[Tue Sep 10 17:44:31.623811 2013] [:error] [pid 12993] [client 192.168.1.60:52188] PHP Warning: scandir(): (errno 13): Permission denied in
[Tue Sep 10 17:45:19.173858 2013] [:error] [pid 12993] [client 192.168.1.60:52188] PHP Warning: scandir(/lost+found): failed to open dir: P
[Tue Sep 10 17:45:19.173890 2013] [:error] [pid 12993] [client 192.168.1.60:52188] PHP Warning: scandir(): (errno 13): Permission denied in
[Tue Sep 10 17:45:19.174283 2013] [:error] [pid 12993] [client 192.168.1.60:52188] PHP Warning: scandir(/root): failed to open dir: Permiss
[Tue Sep 10 17:45:19.174295 2013] [:error] [pid 12993] [client 192.168.1.60:52188] PHP Warning: scandir(): (errno 13): Permission denied in
[Tue Sep 10 17:53:58.577715 2013] [:error] [pid 15770] [client 192.168.1.60:52732] PHP Warning: scandir(/lost+found): failed to open dir: P
[Tue Sep 10 17:53:58.577751 2013] [:error] [pid 15770] [client 192.168.1.60:52732] PHP Warning: scandir(): (errno 13): Permission denied in
[Tue Sep 10 17:53:58.578144 2013] [:error] [pid 15770] [client 192.168.1.60:52732] PHP Warning: scandir(/root): failed to open dir: Permiss
[Tue Sep 10 17:53:58.578165 2013] [:error] [pid 15770] [client 192.168.1.60:52732] PHP Warning: scandir(): (errno 13): Permission denied in
[Tue Sep 10 17:54:14.581486 2013] [:error] [pid 15770] [client 192.168.1.60:52732] PHP Warning: scandir(/lost+found): failed to open dir: P
[Tue Sep 10 17:54:14.581519 2013] [:error] [pid 15770] [client 192.168.1.60:52732] PHP Warning: scandir(): (errno 13): Permission denied in
[Tue Sep 10 17:54:14.582007 2013] [:error] [pid 15770] [client 192.168.1.60:52732] PHP Warning: scandir(/root): failed to open dir: Permiss
[Tue Sep 10 17:54:14.582024 2013] [:error] [pid 15770] [client 192.168.1.60:52732] PHP Warning: scandir(): (errno 13): Permission denied in
[Tue Sep 10 17:54:41.759671 2013] [:error] [pid 15770] [client 192.168.1.60:52732] PHP Notice: Undefined variable: maxOnlineFeeds in /var/w
[Tue Sep 10 17:54:41.759702 2013] [:error] [pid 15770] [client 192.168.1.60:52732] PHP Warning: Invalid argument supplied for foreach() in
[Tue Sep 10 17:54:41.941793 2013] [:error] [pid 15770] [client 192.168.1.60:52732] PHP Warning: scandir(/lost+found): failed to open dir: P
[Tue Sep 10 17:54:41.941820 2013] [:error] [pid 15770] [client 192.168.1.60:52732] PHP Warning: scandir(): (errno 13): Permission denied in
[Tue Sep 10 17:54:41.942205 2013] [:error] [pid 15770] [client 192.168.1.60:52732] PHP Warning: scandir(/root): failed to open dir: Permiss
[Tue Sep 10 17:54:41.942217 2013] [:error] [pid 15770] [client 192.168.1.60:52732] PHP Warning: scandir(): (errno 13): Permission denied in
[Tue Sep 10 17:54:43.104251 2013] [:error] [pid 15770] [client 192.168.1.60:52732] PHP Warning: scandir(/lost+found): failed to open dir: P
[Tue Sep 10 17:54:43.104280 2013] [:error] [pid 15770] [client 192.168.1.60:52732] PHP Warning: scandir(): (errno 13): Permission denied in
[Tue Sep 10 17:54:43.104674 2013] [:error] [pid 15770] [client 192.168.1.60:52732] PHP Warning: scandir(/root): failed to open dir: Permiss
[Tue Sep 10 17:54:43.104687 2013] [:error] [pid 15770] [client 192.168.1.60:52732] PHP Warning: scandir(): (errno 13): Permission denied in
