Playable / unplayable m2ts files
pre
Post Mon Jan 24, 2011 7:27 pm
Any ideas for play some m2ts files?
I have few HD files in *.m2ts and some samples woking very well, some don't.
working samples:
hd_other_panasonic_nature.m2ts
hd_other_panasonic_rome_the_eternal_city.m2ts
hd_other_hdclub_the_gorgeous_ocean_world.m2ts
hd_other_lg_f1_monaco_2009.m2ts
hd_other_toshiba_new_zealand.m2ts
hd_other_philips_ultimate_sharpness.m2ts
hd_other_samsung_led_motion.m2ts
hd_other_samsung_modern_cityscapes_of_dubai.m2ts
hd_other_samsung_summer_holiday.m2ts
hd_other_samsung_the_beautiful_game.m2ts
hd_other_pioneer_bahama.m2ts
hd_other_pioneer_paris.m2ts
don't:
hd_other_panasonic_a_night_in_the_milky_way.m2ts
hd_other_panasonic_alaska_in_the_summer.m2ts
hd_other_panasonic_machu_picchu.m2ts
hd_other_panasonic_the_power_of_light.m2ts
hd_other_jvc_essence_of_sweets.m2ts
hd_other_jvc_new_york.m2ts
hd_other_jvc_football_dreams.m2ts
hd_other_philips_formula_1.m2ts
hd_other_pioneer_bateaux_mouches.m2ts
hd_other_pioneer_black_hole.m2ts
hd_other_pioneer_destination_island.m2ts
hd_other_hitachi_the_colors_of_the_planet.m2ts
hd_other_sony_foam_city.m2ts
hd_other_sony_hd_experiment.m2ts
hd_other_sony_seven_seasons.m2ts
hd_other_sony_sydney_sky_walk.m2ts
some samples with ffmpeg info:
WORK:
ffmpeg.exe -i "hd_other_lg_f1_monaco_2009.m2ts"
686-mingw32-
libavutil 50.36. 0 / 50.36. 0
libavcore 0.16. 0 / 0.16. 0
libavfilter 1.72. 0 / 1.72. 0
libswscale 0.12. 0 / 0.12. 0
[mpegts @ 0168bb90] max_analyze_duration reached
Input #0, mpegts, from 'hd_other_lg_f1_monaco_2009.m2ts':
Duration: 00:02:44.06, start: 599.966644, bitrate: 9463 kb/s
Program 1
Stream #0.0[0x1011]: Video: h264, yuv420p, 1920x1080 [PAR 1:1 DAR 16:9], 29.
97 fps, 29.97 tbr, 90k tbn, 59.94 tbc
Stream #0.1[0x1100](und): Audio: ac3, 48000 Hz, 5.1, s16, 640 kb/s
ffmpeg.exe -i "hd_other_panasonic_rome_the_eternal_city.m2ts"
686-mingw32-
[mpegts @ 0115bc80] max_analyze_duration reached
Input #0, mpegts, from 'hd_other_panasonic_rome_the_eternal_city.m2ts':
Duration: 00:02:38.56, start: 599.958300, bitrate: 9531 kb/s
Program 1
Stream #0.0[0x1011]: Video: h264, yuv420p, 1920x1080 [PAR 1:1 DAR 16:9], 23.
98 fps, 23.98 tbr, 90k tbn, 47.95 tbc
ffmpeg.exe -i "hd_other_toshiba_new_zealand.m2ts"
686-mingw32-
[mpegts @ 0112bba0] max_analyze_duration reached
Input #0, mpegts, from 'hd_other_toshiba_new_zealand.m2ts':
Duration: 00:06:34.40, start: 599.966644, bitrate: 8929 kb/s
Program 1
Stream #0.1[0x1100](und): Audio: ac3, 48000 Hz, stereo, s16, 256 kb/s
Not working:
ffmpeg.exe -i "hd_other_panasonic_a_night_in_the_milky_way.m2ts"
686-mingw32-
Input #0, mpegts, from 'hd_other_panasonic_a_night_in_the_milky_way.m2ts':
Duration: 00:03:36.25, start: 599.966644, bitrate: 8882 kb/s
Program 1
Stream #0.1[0x1100]: Audio: ac3, 48000 Hz, stereo, s16, 256 kb/s
ffmpeg.exe -i "hd_other_panasonic_machu_picchu.m2ts"
686-mingw32-
[mpegts @ 0164bba0] max_analyze_duration reached
Input #0, mpegts, from 'hd_other_panasonic_machu_picchu.m2ts':
Duration: 00:04:16.19, start: 599.960011, bitrate: 8846 kb/s
Program 1
Stream #0.0[0x1011]: Video: h264, yuv420p, 1920x1080 [PAR 1:1 DAR 16:9], 25
fps, 25 tbr, 90k tbn, 50 tbc
Its only parts working/unworking files
All files available on http://www.demo-world.eu/trailers/high- ... ailers.php
I'm using Serviio 0.5, Win7 64bit, Core2Duo 4GB, TV Panasonic P50V20E.
ps. fantastic job Serviio Team
Post Mon Jan 24, 2011 7:35 pm
Re: Playable / unplayable m2ts files
Could you check the h264 profile level of movies files with MediaInfo tools?
pre
Post Mon Jan 24, 2011 8:52 pm
what u mean h264 profile level?
i have that info, for example:
Complete name : hd_other_panasonic_a_night_in_the_milky_way.m2ts
Format : BDAV
Format/Info : Blu-ray Video
File size : 229 MiB
Duration : 3mn 36s
Overall bit rate : 8 884 Kbps
Maximum Overall bit rate : 35.5 Mbps
Menu ID : 1 (0x1)
Format : AVC
Format profile : High@L4.1
Format settings, CABAC : Yes
Format settings, ReFrames : 3 frames
Codec ID : 27
Duration : 3mn 36s
Bit rate mode : Variable
Bit rate : 8 220 Kbps
Maximum bit rate : 24.0 Mbps
Width : 1 920 pixels
Height : 1 080 pixels
Display aspect ratio : 16:9
Frame rate : 29.970 fps
Color space : YUV
Chroma subsampling : 4:2:0
Bit depth : 8 bits
Scan type : Progressive
Bits/(Pixel*Frame) : 0.132
Stream size : 213 MiB (93%)
Writing library : x264 core 61
Encoding settings : cabac=1 / ref=3 / deblock=1:0:0 / analyse=0x3:0x133 / me=umh / subme=6 / psy_rd=1.000000 / brdo=1 / mixed_ref=1 / me_range=16 / chroma_me=1 / trellis=0 / 8x8dct=1 / cqm=0 / deadzone=21,11 / chroma_qp_offset=0 / threads=3 / nr=0 / decimate=1 / mbaff=0 / bframes=3 / b_pyramid=1 / b_adapt=1 / b_bias=0 / direct=3 / wpredb=1 / bime=1 / keyint=250 / keyint_min=25 / scenecut=40(pre) / rc=2pass / bitrate=8220 / ratetol=1.0 / rceq='blurCplx^(1-qComp)' / qcomp=1.00 / qpmin=10 / qpmax=51 / qpstep=4 / cplxblur=20.0 / qblur=0.5 / vbv_maxrate=24000 / vbv_bufsize=9000 / ip_ratio=1.40 / pb_ratio=1.30 / aq=2:1.00
Menu ID : 1 (0x1)
Format : AC-3
Format/Info : Audio Coding 3
Codec ID : 129
Duration : 3mn 36s
Bit rate mode : Constant
Bit rate : 256 Kbps
Channel(s) : 2 channels
Sampling rate : 48.0 KHz
Bit depth : 16 bits
Compression mode : Lossy
Stream size : 6.60 MiB (3%)
Post Mon Jan 24, 2011 9:07 pm
pre wrote:what u mean h264 profile level?
Format : AVC
For example, High@L5.0: High profile Level 5.0 are not supported by Sony devices.So the truth is out ?!
Post Mon Jan 24, 2011 9:10 pm
This is probably due to the "8x8dct=1" Encoding option...
Could you compare with others files?
pre
Post Mon Jan 24, 2011 9:30 pm
OK, np
working:
Format : AVC
Format : AVC
Format : AVC
Format profile : High@L4.0
Format : AVC
unplayable:
Format : AVC
Format : AVC
Format : AVC
looks as the same.on serviio 0.4.2 the same problem.
0.5 using FFmpeg rev. 26303, incl. a patch
0.4.2 i dont know
patters
Post Tue Jan 25, 2011 10:11 am
What's your renderer device? Don't forget - assuming you're not transcoding, your renderer is decoding the file, not FFMPEG.
pre
Post Tue Jan 25, 2011 9:57 pm
ATI Mobility Radeon HD 4570 512MB, inside notebook Toshiba L505-110
All this file playing on computer without problems.
Who can test this unplayable files on own - similar machines?
patters
Post Wed Jan 26, 2011 1:24 am
By renderer I meant your DLNA client. TV? Bluray player?
pre
Post Wed Jan 26, 2011 12:54 pm
of course, it's PDP Panasonic TX-P50V20E, firmware 2.505
Post Wed Jan 26, 2011 1:06 pm
Please, could you compare "Encoding settings :" in MediaInfo tools result between Work Files and the others?
pre
Post Wed Jan 26, 2011 7:45 pm
hah its can be true
i see differences in Writing library - Encode Settings/String.
*.m2ts files with x264 core 61 not playing. x264 core 66, 77 working propertly.
*.mkv files with x264 core 65, 85, 88, 102, 107, 110 is OK, 50 have artefacts
Thereform, problem is (in my example) with older than 66 *version of codec core.
I dont know which cell in chains is fail. TV, serviio :-/
Post Thu Jan 27, 2011 8:40 am
pre wrote:hah its can be true
Great! interesting,
Serviio with FFMPEG simply stream the video in native format without change the video codec.
So it seems that your TV x264 decoder is sensitive to the source codec core version (<65).
If I get time, I will check with my Sony Bravia EX500 renderer.
pre
Post Thu Jan 27, 2011 12:48 pm
OK, i wait patiently.
edit:
i have confirmations from other users PDP V20.
His TV (42V20) have the same behaviour on this files like my.
Looks like Panasonic "features" :-/
dave
Post Wed Feb 09, 2011 6:40 pm
I have found the same with my TV, a Panasonic TX-P42G20B
As pre discovered, it depends on the "Writing library".
plays well :
hd_other_panasonic_rome_the_eternal_city.m2ts       x264 core 77 r1292kGIT e381f6d
hd_other_philips_ultimate_sharpness.m2ts            x264 core 66 r1114M a933a3e
hd_other_hdclub_the_gorgeous_ocean_world.m2ts       x264 core 77 r1292kGIT e381f6d
hd_other_lg_f1_monaco_2009.m2ts                     x264 core 77 r1292kGIT e381f6d
hd_other_pioneer_bahama.m2ts                        x264 core 77 r1292kGIT e381f6d
hd_other_pioneer_black_hole.m2ts                    x264 core 66 r1114M a933a3e
hd_other_samsung_led_motion.m2ts                    x264 core 77 r1292kGIT e381f6d
hd_other_samsung_modern_cityscapes_of_dubai.m2ts    x264 core 77 r1292kGIT e381f6d
hd_other_toshiba_new_zealand.m2ts                   x264 core 77 r1292kGIT e381f6d
plays with corruption :
hd_other_samsung_the_beautiful_game.m2ts            ?
hd_other_panasonic_nature.m2ts                      ?
hd_other_pioneer_paris.m2ts                         ?
hd_other_samsung_summer_holiday.m2ts                ?
(mediainfo doesn't show a "Writing library" field for these files)
won't play :
hd_other_panasonic_machu_picchu.m2ts                x264 core 61
hd_other_philips_formula_1.m2ts                     x264 core 61
hd_other_sony_foam_city.m2ts                        x264 core 61
hd_other_sony_seven_seasons.m2ts                    x264 core 61
hd_other_hitachi_the_colors_of_the_planet.m2ts      x264 core 61
hd_other_jvc_essence_of_sweets.m2ts                 x264 core 61
hd_other_jvc_football_dreams.m2ts                   x264 core 61
hd_other_jvc_new_york.m2ts                          x264 core 61
hd_other_panasonic_alaska_in_the_summer.m2ts        x264 core 61
hd_other_panasonic_a_night_in_the_milky_way.m2ts    x264 core 61
hd_other_panasonic_the_power_of_light.m2ts          x264 core 61
hd_other_pioneer_bateaux_mouches.m2ts               x264 core 61
hd_other_pioneer_destination_island.m2ts            x264 core 61
hd_other_sony_hd_experiment.m2ts                    x264 core 61
hd_other_sony_sydney_sky_walk.m2ts                  x264 core 61
Also I tried playing all these files from a USB stick plugged into the TV.
This gave the same results, confirming it's a feature of the TV, as expected.
Is there a way to convert these files (without losing any quality?) to a compatible format?
Return to Philips
