Sun Dec 29, 2013 12:08 am by pteeson
I turned on DEBUG in both the Server and the Console.
From my reading of the logs it's related to the UPNP device not being available. (copied from below log extracts)
2013-12-28 18:38:07,782 DEBUG [DiscoveryManager] UPNP device b417b37c-4030-3c89-bb6e-b5e8798e235b (192.168.2.10) is unavailable
But that device is my Mac at en0 IP 192.168.2.10 (a.k.a. Gandalf). The TV is at 192.168.2.15. Both of these are the same addresses as before.
What to do next? Log extracts follow.
Peter
There are 3 server logs listed in date/time created and named serviio.log.2, serviio.log.1, and serviio.log.
If I understand them correctly the issue is the related to these extracts from the logs:
From log 2
2013-12-28 18:32:41,978 INFO [DiscoveryAdvertisementNotifier] Starting DiscoveryAdvertisementNotifier
2013-12-28 18:32:41,982 INFO [RendererExpirationChecker] Starting RendererExpirationChecker
2013-12-28 18:32:41,982 INFO [RendererSearchSender] Searching for Renderer devices
2013-12-28 18:32:41,983 INFO [DiscoverySSDPMessageListener] Starting DiscoverySSDPMessageListener using interface en0 (en0) and address 192.168.2.10, timeout = 0
2013-12-28 18:32:41,984 DEBUG [RendererSearchSender$RendererSearchWorker] Multicasting SSDP M-SEARCH using interface en0 (en0) and address 192.168.2.10, timeout = 0
2013-12-28 18:32:41,995 DEBUG [RendererSearchSender$RendererSearchWorker] Sending 1 'm-search' messages
2013-12-28 18:32:41,995 DEBUG [DiscoveryAdvertisementNotifier] Multicasting SSDP alive using interface en0 (en0) and address 192.168.2.10, timeout = 0
2013-12-28 18:32:41,996 DEBUG [DiscoveryAdvertisementNotifier] Sending 6 'alive' messages describing device b417b37c-4030-3c89-bb6e-b5e8798e235b
2013-12-28 18:32:43,818 DEBUG [DiscoveryAdvertisementNotifier] Will advertise again in 00:00:08 (advertisement duration is 1800 sec.)
2013-12-28 18:32:47,997 DEBUG [RendererSearchSender] Finished searching for Renderer devices
2013-12-28 18:32:51,998 DEBUG [DiscoveryAdvertisementNotifier] Multicasting SSDP alive using interface en0 (en0) and address 192.168.2.10, timeout = 0
2013-12-28 18:32:51,999 DEBUG [DiscoveryAdvertisementNotifier] Sending 6 'alive' messages describing device b417b37c-4030-3c89-bb6e-b5e8798e235b
2013-12-28 18:32:53,818 DEBUG [DiscoveryAdvertisementNotifier] Will advertise again in 00:00:08 (advertisement duration is 1800 sec.)
2013-12-28 18:33:01,999 DEBUG [DiscoveryAdvertisementNotifier] Multicasting SSDP alive using interface en0 (en0) and address 192.168.2.10, timeout = 0
2013-12-28 18:33:02,000 DEBUG [DiscoveryAdvertisementNotifier] Sending 6 'alive' messages describing device b417b37c-4030-3c89-bb6e-b5e8798e235b
2013-12-28 18:33:03,820 DEBUG [DiscoveryAdvertisementNotifier] Will advertise again in 00:03:24 (advertisement duration is 1800 sec.)
and from the last log
also
2013-12-28 18:38:07,782 DEBUG [WebServer] Socket closed
2013-12-28 18:38:07,783 INFO [WebServer] WebServer shutting down
2013-12-28 18:38:07,783 INFO [DiscoveryAdvertisementNotifier] Leaving DiscoveryAdvertisementNotifier
and finally
2013-12-28 18:38:07,784 DEBUG [DiscoveryAdvertisementNotifier] Multicasting SSDP byebye using interface en0 (en0) and address 192.168.2.10, timeout = 0
Mac Pro OS X Yosemite, Toshiba 55SL500U
