Only Empty folders on LG 42LE8500
vloemans
Post Mon Jan 10, 2011 6:48 pm
I just installed serviio on my macbook pro. In a wired network it is connected to my LG 42LE8500.
On my TV I see the standerd folder structure of Serviio, but they all contain empty folders.
I selected a folder in the library and ticked the box 'video's'.
I choosed several renderer profile and the IP field is blank, but all without succes.
Thanks in advance for help.
vloemans
Post Mon Jan 10, 2011 7:27 pm
Re: Only Empty folders on LG 42LE8500
I just found out that I was unpatient. It takes some time for the files to appear.
I do have problems with subtitles.
Post Mon Jan 10, 2011 7:42 pm
vloemans wrote:I do have problems with subtitles.
Like?
vloemans
Post Fri Feb 04, 2011 10:01 am
most recent LG software (tv = LG 42LE8500)
most recent serviio 0.5
same title for movie and .srt
no subtitles are displayed.
What could be the solutions?
Post Fri Feb 04, 2011 10:14 am
Are you using the LG profile?
vloemans
Post Fri Feb 04, 2011 12:23 pm
I used the generic dlna profile.
When I change this to LG BD profile, I got an error when loading the movies: file is unvalid.
Post Fri Feb 04, 2011 3:05 pm
can you post ffmpeg -i of the file?
vloemans
Post Fri Feb 04, 2011 4:58 pm
I am not sure what you mean with ffpmpeg -i.
I use evereything on a mac and the files are all .mkv files.
Wout
Post Fri Feb 04, 2011 5:23 pm
vloemans
Post Sun Feb 06, 2011 9:59 am
I try to get the info with ffmpeg, but my .mkv files are not recognized.
In the terminal the code ffmpeg -i does not give any result. Maybe I do not use the right syntax. I am not experienced with Terminal.
My os is osx 10.6.6
vloemans
Post Sun Feb 06, 2011 10:23 am
ffmpegx does not recognize my .mkv files.
Post Sun Feb 06, 2011 11:44 am
type
ffmpeg -i /path/to/your/movie.mkv
vloemans
Post Sun Feb 06, 2011 11:54 am
I installed ffmpegX with the requested binaries. In the terminal I still get this output, see picture:
Schermafbeelding 2011-02-06 om 12.52.00.png (34.44 KiB) Viewed 29340 times
Post Sun Feb 06, 2011 11:58 am
ffmpeg is distributed with Serviio, it's under Serviio.app
vloemans
Post Sun Feb 06, 2011 12:13 pm
Sorry that I don't get it.
I run ffmpeg. After that I restarted the ffmpeg command and still the message: command not found.
Schermafbeelding 2011-02-06 om 13.11.19.png (58.26 KiB) Viewed 29339 times
Post Sun Feb 06, 2011 12:16 pm
you don't use the file name as a parameter (there is ;exit in there instead)
vloemans
Post Sun Feb 06, 2011 12:34 pm
this is the total info:
built on Jan 12 2011 19:51:48 with gcc 4.0.1 (Apple Inc. build 5493)
configuration: --enable-static --disable-shared --bindir=/tmp/ffmpeg --disable-ffplay --disable-ffserver --enable-libmp3lame --enable-pthreads --disable-mmx --extra-ldflags=-L/tmp/static/lib --extra-cflags=-I/tmp/static/include
libavutil 50.36. 0 / 50.36. 0
libavcore 0.16. 0 / 0.16. 0
libavfilter 1.72. 0 / 1.72. 0
libswscale 0.12. 0 / 0.12. 0
[matroska,webm @ 0x1009600] Estimating duration from bitrate, this may be inaccurate
Seems stream 0 codec frame rate differs from container frame rate: 47.95 (48000/1001) -> 23.98 (48000/2002)
Input #0, matroska,webm, from '/Users/woutvloemans/Movies/network.mkv':
title : The Social Network (2010) 1080P.X264.NL.SUBBED.Bradje
Duration: 02:00:27.23, start: 0.000000, bitrate: 2176 kb/s
Chapter #0.0: start 0.000000, end 300.000000
title : Video Start
Chapter #0.1: start 300.000000, end 600.000000
title : Chapter 1 - 00 Hr 05 Min
Chapter #0.2: start 600.000000, end 900.000000
title : Chapter 2 - 00 Hr 10 Min
Chapter #0.3: start 900.000000, end 1200.000000
title : Chapter 3 - 00 Hr 15 Min
Chapter #0.4: start 1200.000000, end 1500.000000
title : Chapter 4 - 00 Hr 20 Min
Chapter #0.5: start 1500.000000, end 1800.000000
title : Chapter 5 - 00 Hr 25 Min
Chapter #0.6: start 1800.000000, end 2100.000000
title : Chapter 6 - 00 Hr 30 Min
Chapter #0.7: start 2100.000000, end 2400.000000
title : Chapter 7 - 00 Hr 35 Min
Chapter #0.8: start 2400.000000, end 2700.000000
title : Chapter 8 - 00 Hr 40 Min
Chapter #0.9: start 2700.000000, end 3000.000000
title : Chapter 9 - 00 Hr 45 Min
Chapter #0.10: start 3000.000000, end 3300.000000
title : Chapter 10 - 00 Hr 50 Min
Chapter #0.11: start 3300.000000, end 3600.000000
title : Chapter 11 - 00 Hr 55 Min
Chapter #0.12: start 3600.000000, end 3900.000000
title : Chapter 12 - 01 Hr 00 Min
Chapter #0.13: start 3900.000000, end 4200.000000
title : Chapter 13 - 01 Hr 05 Min
Chapter #0.14: start 4200.000000, end 4500.000000
title : Chapter 14 - 01 Hr 10 Min
Chapter #0.15: start 4500.000000, end 4800.000000
title : Chapter 15 - 01 Hr 15 Min
Chapter #0.16: start 4800.000000, end 5100.000000
title : Chapter 16 - 01 Hr 20 Min
Chapter #0.17: start 5100.000000, end 5400.000000
title : Chapter 17 - 01 Hr 25 Min
Chapter #0.18: start 5400.000000, end 5700.000000
title : Chapter 18 - 01 Hr 30 Min
Chapter #0.19: start 5700.000000, end 6000.000000
title : Chapter 19 - 01 Hr 35 Min
Chapter #0.20: start 6000.000000, end 6300.000000
title : Chapter 20 - 01 Hr 40 Min
Chapter #0.21: start 6300.000000, end 6600.000000
title : Chapter 21 - 01 Hr 45 Min
Chapter #0.22: start 6600.000000, end 6900.000000
title : Chapter 22 - 01 Hr 50 Min
Chapter #0.23: start 6900.000000, end 7200.000000
title : Chapter 23 - 01 Hr 55 Min
Chapter #0.24: start 7200.000000, end 7227.232000
title : Chapter 24 - 02 Hr 00 Min
Stream #0.0(eng): Video: h264, yuv420p, 1920x800, PAR 1:1 DAR 12:5, 23.98 fps, 23.98 tbr, 1k tbn, 47.95 tbc
title : x264
Stream #0.1(eng): Audio: ac3, 48000 Hz, 5.1, s16, 640 kb/s
title : AC3
Stream #0.2(eng): Audio: dca, 48000 Hz, 5.1, s16, 1536 kb/s
title : DTS
Stream #0.3(dut): Subtitle: [0][0][0][0] / 0x0000
title : Subtitles
Stream #0.4(eng): Subtitle: [0][0][0][0] / 0x0000
title : Subtitles
Post Sun Feb 06, 2011 7:23 pm
does the file play if you use Generic profile?
vloemans
Post Sun Feb 13, 2011 8:39 am
Yes, when I use generic profile, so far all my files play smoothly, but without subtitles.
With LG BD profile, files do not play.
Return to LG
