Mon Sep 08, 2014 2:46 pm by Pleblo
Will thanks for the update. So with chromecast I had some issues. What I have noticed is the app connects to the chromecast fine. When you click on any show or movie you want to watch chromecast just spins on my phone and on the screen I see the default picture with the loading bar. Ive waited up to 5 mins before the app on my phone says disconnected and when it does my chromecast is frozen up and can't use it till I unplug it even have to close out Serviigo to get it to open back up the chromecast button.
Also I don't know if you have ever used BubbleUPnP but they also have chromecast support. They have a render selection where you can select what chromecast or what DLNA device you want. Is there any way to make it so it can use other then Chromecast? I notice that yours will only find my chromecast but won't find any other devices that can steam the shows.
Keep up the good work.
Pleblo
