Sweflix - Movies in HD (not US/UK)
stefana888
Post Tue Sep 02, 2014 4:25 am
Movies in HD! :D
Sweflix.to plugin
Webresource
Sample URLs:
http://sweflix.to/genre/senaste/ (Latest added movies)
http://sweflix.to/genre/action/ (Action category movies)
http://sweflix.to/genre/drama/ (Drama category movies)
http://sweflix.to/?q=2014&act=query (Search for "2014")
Updates:
150824 Fixed plugin, working again (https -> http)
150719 Fixed plugin, working again
141023 Fixed plugin, working again
tagsoup-1.2.1.zip
1) Needed file in zip, extract (jar) to .../Serviio/lib/
(85.89 KiB) Downloaded 1446 times
Sweflix.groovy
2) Put in .../Serviio/plugins/
(2.38 KiB) Downloaded 936 times
Subtitle support will be added when Issue #536 and Issue #805 is implemented in Serviio.
comegen
Post Tue Sep 09, 2014 1:31 am
Re: Sweflix
Buenoas noches
me podria decir como se instala
gracias.
d2freak
Post Sun Sep 14, 2014 12:23 pm
Re: Sweflix
Thanks a lot for this plugin.
stefana888
Post Thu Oct 23, 2014 9:35 am
Re: Sweflix
Plugin is fixed and working again!
stefana888
Post Sat Nov 08, 2014 5:07 pm
Re: Sweflix
Premium content are beeing available to the plugin as the site Sweflix now is completely free.
jermiii
Post Mon Nov 10, 2014 1:35 pm
Re: Sweflix
I am using even better site for HD movies, it contain new movies and sources
enjoy :P
http://ontap.se/
stefana888
Post Mon Nov 10, 2014 7:04 pm
Re: Sweflix (HD movies)
Really, we want Serviio DLNA plugins here and your site is not suitable for a plugin.
cubiclecrusher
Post Tue Nov 11, 2014 7:19 pm
New plug-in user. I seem to have gotten something wrong with the config/use of this plug-in. I got the yahoo plugin to work, but I can't get this one to work.
I downloaded the groovy and put it in my plugins folder
I downloaded the ZIP file and extracted it - the tagsoup-1.2.1.jar file ended up in the LIB directory.
I added an online web resource using the links provided
(example: https://sweflix.net/index.php?act=genre)
When I went to the video's on my Panasonic BD rederer, and choose the online videos, I only saw the youtube resource, and not my SweFlix resource.
I'm not familar with JAR files. The directions said to unzip the JAR file itself, so I did. I extracted the JAR file into the LIB directory. This created META-INF and ORG sub-directories under the LIB folder.
I then stopped and restarted the service. But when I got to online videos, I still only have the choice for YouTube.
Did I do something wrong?
stefana888
Post Tue Nov 11, 2014 8:54 pm
Yes, don't unzip the content of the jar file. Leave it as 'tagsoup-1.2.1.jar'.
ottomatic
cubiclecrusher wrote:I'm not familar with JAR files. The directions said to unzip the JAR file itself, so I did. I extracted the JAR file into the LIB directory. This created META-INF and ORG sub-directories under the LIB folder.
A jar is compiled Java code packaged in a way that the Java virtual machine understands.
So, you should just unzip the zip file (to get the jar file), but not the jar file itself.
And the jar file should go into the lib folder, along with the jars that are distributed with the Serviio installation.
Regards
/ O
Post Tue Nov 11, 2014 10:27 pm
I get a connection error:
Server returned HTTP response code: 403 for URL: https://sweflix.net/index.php?genre=sci-fi&sv=Sci-Fi&act=genre
All settings as described and setup per instructions. When I first went to the web site, I encountered a Captcha dialog. Looks like they don't want people connecting to the web site this way. :cry:
stefana888
Post Wed Nov 12, 2014 1:54 am
atc98092 wrote:I get a connection error:
The plugin html parsing isn't troubled by the captcha dialog. It should work with a valid not redirected url. I just checked it.
Post Wed Nov 12, 2014 2:51 am
I don't doubt you :D . Using this URL (https://sweflix.net/index.php?act=pop) I get error 403. Tried this one too (https://sweflix.net/index.php?genre=drama&act=genre), same result.
As I said, when I browse to the web page from a fresh browser window, I get the captcha page first. Could that be something country specific? As in USA IP addresses are getting redirected to the captcha page?
stefana888
Post Wed Nov 12, 2014 7:43 am
The captcha is in order, everybody gets it first time. But I don't understand the 403 error. Can post you post he full log? Are you using the latest plugin version?
Jools
Post Wed Nov 12, 2014 6:24 pm
I put the .groove in Serviio/plugins folder and unzipped the .jar file to Serviio/lib folder. I get this error in the log:
C:\Program Files\Serviio\plugins\Sweflix.groovy: 29: unable to resolve class Parser
 @ line 29, column 35.
           def root = new XmlSlurper(new Parser()).parseText(conn.getInputStream().getText())
I'm not in Sweden but I can use that site through my web browser so it should not be that.
stefana888
Post Wed Nov 12, 2014 6:39 pm
Jools wrote:I put the .groove in Serviio/plugins
Did you put 'tagsoup-1.2.1.jar' in the lib folder as one file?
stefana888
Post Wed Nov 12, 2014 6:45 pm
Modified the instruction now for easier understanding:
Hope it helps!
cubiclecrusher
Post Wed Nov 12, 2014 7:10 pm
Well, I removed the subfolders created when I extracted the JAR file, and I left the tagsoup-1.2.1.jar file in the LIB folder.
I rebooted the PC, restarted the service.
However, the SweFlix links are not available on the Serviio online video section (but my YouTube links show-up).
Below is the log info from my attempt last night. I set up several entries for several of the Sweflix links, I get a "FeedUpdaterThread" error for each link. I've included only the info related to the "pop" link (https://sweflix.net/index.php?act=pop)
2014-11-11 18:43:20,875 INFO  [PluginCompilerThread] Added Web Resouce plugin SweFlix (Sweflix.groovy), version: 1
2014-11-11 18:43:47,437 WARN  [FeedUpdaterThread] An error occured while parsing the online resource https://sweflix.net/index.php?act=pop, will try again soon: Unexpected error while invoking plugin (SweFlix): Server returned HTTP response code: 403 for URL: https://sweflix.net/index.php?act=pop
org.serviio.library.online.metadata.OnlineResourceParseException: Unexpected error while invoking plugin (SweFlix): Server returned HTTP response code: 403 for URL: https://sweflix.net/index.php?act=pop
   at org.serviio.library.online.WebResourceParser.parse(WebResourceParser.java:78)
   at org.serviio.library.online.OnlineLibraryManager.findResource(OnlineLibraryManager.java:181)
   at org.serviio.library.online.OnlineLibraryManager.findResourceInCacheOrParse(OnlineLibraryManager.java:198)
   at org.serviio.library.online.metadata.FeedUpdaterThread.getOnlineItems(FeedUpdaterThread.java:185)
   at org.serviio.library.online.metadata.FeedUpdaterThread.run(FeedUpdaterThread.java:108)
Caused by: java.io.IOException: Server returned HTTP response code: 403 for URL: https://sweflix.net/index.php?act=pop
   at sun.net.www.protocol.http.HttpURLConnection.getInputStream(Unknown Source)
   at sun.net.www.protocol.https.HttpsURLConnectionImpl.getInputStream(Unknown Source)
   at sun.net.www.protocol.https.HttpsURLConnectionImpl$getInputStream.call(Unknown Source)
   at org.codehaus.groovy.runtime.callsite.CallSiteArray.defaultCall(CallSiteArray.java:42)
   at org.codehaus.groovy.runtime.callsite.AbstractCallSite.call(AbstractCallSite.java:108)
   at org.codehaus.groovy.runtime.callsite.AbstractCallSite.call(AbstractCallSite.java:112)
   at SweFlix.extractItems(Sweflix.groovy:29)
   at org.serviio.library.online.WebResourceUrlExtractor$1.executePluginMethod(WebResourceUrlExtractor.java:32)
   at org.serviio.library.online.WebResourceUrlExtractor$1.executePluginMethod(WebResourceUrlExtractor.java:29)
   at org.serviio.library.online.PluginExecutionProcessor$1.call(PluginExecutionProcessor.java:50)
   at java.util.concurrent.FutureTask$Sync.innerRun(Unknown Source)
   at java.util.concurrent.FutureTask.run(Unknown Source)
   at java.util.concurrent.ThreadPoolExecutor$Worker.runTask(Unknown Source)
   at java.util.concurrent.ThreadPoolExecutor$Worker.run(Unknown Source)
   at java.lang.Thread.run(Unknown Source)
stefana888
Post Wed Nov 12, 2014 7:45 pm
cubiclecrusher wrote:Well, I removed the subfolders
If your webbrowser is able to open the same link then it should also be able to open it from Serviio. Did you check with your browser first?
stefana888
Post Wed Nov 12, 2014 8:12 pm
UPDATE. I checked the site from http://httpstatus.io in USA and I guess the site is geoblocked for you and possibly for other countries as well.
Return to Available plugins
