referrer for ffmpeg?
programmer
Post Sat Sep 17, 2016 9:14 am
Is it possible to specify http referrer in ContentURLContainer or in any other way that ffmpeg should use?
The following radio sites require referrer to work:
http://www.radiotunes.com/
http://www.di.fm/
Post Sat Sep 17, 2016 6:50 pm
Re: referrer for ffmpeg?
If it's used to get http responses in the plugin itself, you can use
String openURL(URL url, String userAgent, String referer, Map<String, String> cookies)
But you're asking for FFmpeg - no it's not possible. Only user-Agent. If you need Referer, raise a bitbucket ticket.
programmer
Post Fri Sep 23, 2016 1:04 pm
Return to Plugin development
