Samsung UE43NU7400 not working
ArDo
Post Wed Jul 11, 2018 12:17 pm
I'm having problems connecting Serviio 1.9.2 (Mac OS) to my Samsung UE43NU7400, the TV appears in "Connected Devices" under the "Status" tab in Serviio Console, but when i change the input source on the TV Serviio does not appear.
not sure if i'm doing something wrong or if my TV is yet to be supported.
Any help you could provide me with would be greatly appreciated.
Thx in ArDvance. :)
Post Wed Jul 11, 2018 12:38 pm
Re: Samsung UE43NU7400 not working
I've never been thrilled with the Samsung DLNA player, but it should see Serviio without an issue if Serviio is running correctly. Can anything else on your network see Serviio? Just want to make sure Serviio is functioning correctly. The next thing to check is the profile assigned to the TV in the Serviio console. There's not a Samsung N profile, but the J or later should work just as well, unless Samsung has changed the media support for the N model. But again, even using the generic profile your TV should still see Serviio.
ArDo
Post Thu Jul 12, 2018 7:40 am
thanks for the quick response, my issue has been resolved, a clean install did the trick. :D
Post Thu Jul 12, 2018 1:06 pm
Perfect, thanks for the update!
Users browsing this forum: Google [Bot] and 6 guests
