Bad IP TV Binding with unknown IP adress
Venere
Post Thu Oct 10, 2013 7:01 pm
For a few days ago, i've a strange behavior :
Usually my IP TV is 192.168.0.36 (permanent from my DHCP server). My TV profile is SAMSUNG C,D,E,F series.
When i start Serviio all is ok and i can read on my TV all kind of videos (mkv, avi, ...).
On the Serviio Console all is ok : 192.168.0.36 (my IP TV) is correctly bound with the Samsung Profile.
But after about 5mn. (this delay corresponds to my libraries updates) i cant' read anymore mkv videos only : Format unsupported. All others : avi, flv, vob are readable.
So when i look my Serviio Console my TV adress as disappears and a new adress 192.168.27.14 appears with the samsmung profile. This new adress is not pingable and i don't know where it come from. And even if my TV IP is not shown on the console i can read all kind of files but not mkv videos.
This behavior is very disturbing : I must put off/on my TV, same thing for Serviio Server and once again after 5mn. the problem reappears.
I put the debug log in attachement (cut for size) but sufficiently comprehensible.
Any idea would be greatly appreciate.
serviio.venere.log
(169.97 KiB) Downloaded 1072 times
Serviio 1.4 - TV Samsung UE40ES6710 - DELL XPS8500, Windows 8.1, Ram 8 Go, CPU 3,40 Ghz
Post Fri Oct 11, 2013 1:59 am
Re: Bad IP TV Binding with unknown IP adress
See
viewtopic.php?f=10&t=7783&p=61753
viewtopic.php?f=11&t=6030&p=75258&hilit=freebox#p75258
it appears as if the router is providing two IP addresses to the TV. Its almost like the router is acting in a pseudo bridge mode.
Given this has only just started happening, perhaps something changed in the router config - you may want to look at (these may or may not be relevant - sorry):
http://en.kioskea.net/faq/9942-freebox- ... outer-mode
http://forum.ubuntu-fr.org/viewtopic.php?id=234369
If you do come across the fix, please share with others as I couldn't find any resolution of this issue in my quick search in this forum.
Post Fri Oct 11, 2013 3:44 pm
I think I have a fix for this in 1.4
Venere
Post Fri Oct 11, 2013 4:14 pm
Thanks denyAll for your response.
It seems that my problem is the same as http://forum.serviio.org/viewtopic.php?f=10&t=7783&p=61753. I use the same router : freebox v6.
The strange thing for me is that i use Serviio with the same configuration for more than one year ago and the problem came only a few days ago, for others it's one or many years ago.
Hi Zip,
Where or when can i find 1.4 ?
Post Sun Oct 13, 2013 12:40 am
1.4 is not in beta yet, it'll take some time still.
Venere
Post Mon Oct 21, 2013 10:44 am
HI everybody,
I think i've resoled my problem but what is comic is that i can't explain exactly how.
Here 's what i did :
- Disable Teredo interface
- Disable ISATAP interface
- Activate bridge mode on my router
Actually I've not anymore my IP TV replaced with another (ie : 192.168.27.14) .
For those who use freebox router i read that 192.168.27.x is a special VLAN for the freebox components.
192.168.27.1 for the HD box
192.168.27.14 (the IP which was replacing my IP TV) for the ADSL router.
I'll do further tests and i'll post the results, but i think rather it's the bridge mode of the router who is responsible.
Venere
Post Sat Jan 04, 2014 1:27 pm
first, happy new year to everyone.
As said by Zip in a previous post, I confirm the 1.4 release resolves the IP adress conflict that i've mentionned in this thread (extract from 1.4 realease notes : fixed duplicate renderer registering caused by some routers)
I've turned off the bridge mode of my router and turn on again the Teredo and ISATAP interfaces as it was originally configured and after one month using the 1.4 i never encounter the problem again.
So thank you again Zip for your great work.
sabar
Post Thu Feb 17, 2022 10:04 am
Hallo everyone nice posts. i agree but my question is What is binding IP address I hope my question to Answer...
Best Regards.
sabar.GBWhatsapp Apk
Post Thu Feb 17, 2022 4:31 pm
sabar wrote:Hallo everyone nice posts. i agree but my question is What is binding IP address I hope my question to Answer...
This is an extremely old thread, and not likely valid for the current Serviio version. Can you be more specific about what you're asking? And I removed your spam link, if that's all you were trying to do.
Users browsing this forum: Bing [Bot] and 23 guests
