Does Serviio Support my Sony Bravia KDl-40X3100
Dasha
Post Tue Mar 19, 2013 12:32 am
Hi :D I am a "newbie" learning about DLNA. I have Registered with the Serviio forum as I intend using it. I have a Topfield TRF 2400 Masterpiece (2011) connected via "Ethernet- LAN" to my 2010 Sony Bravia 40XBR - KDL-40X3100. My question was, is my Sony supported by Serviio?
I have searched through all of your listed Serviio supported Sony Bravia's" and cannot find mine Listed anywhere. My Sony had an in home "Re call upgrade" by Sony about a Year ago" what ever that was? Can someone please advise me if Serviio is Okay for me Dasha :?
Post Tue Mar 19, 2013 8:08 am
Re: Does Serviio Support my Sony Bravia KDl-40X3100
Could you provide information about format supported by this device model ? see my signature links.
Is it an australian model ?
Dasha
Post Tue Mar 19, 2013 8:51 am
Dasha wrote:Hi :D I am a "newbie" learning about DLNA. I have Registered with the Serviio forum as I intend using it. I have a Topfield TRF 2400 Masterpiece (2011) connected via "Ethernet- LAN" to my 2010 Sony Bravia 40XBR - KDL-40X3100. My question was, is my Sony supported by Serviio?
Thanks Illico, I installed the Developer Tools for UPnP Technologies v0.0.64 but i don't understand it' or how it works" I don't have the Sony TV and Topfield TRF 2400 Masterpiece (2011)connected to my PC (Dell Desktop yet)? I was just making sure I could use Serviio for DNLP before proceeding with it all. I figured that if the Bravia was not DNLP compatible it would be a wast of time to try and set up my stuff with Serviio. I hope I haven't misled you!
The TV is an Australian purchased 2010 Sony Bravia 40XBR - KDL-40X3100 is this any help I have Device spy installed but Don't know what you want me to do with it ? Thanks for your help Dasha :oops:
Post Tue Mar 19, 2013 1:27 pm
I looked at dlna.org http://www.dlna.org/consumer-home/look- ... uct-search, but this model KDL-40X3100 was not found.
http://www.sony.com.au/support/product/KDL-40X3100
I looked at the user-manual, is there a RJ45 ethernet network connection on your KDL-40X3100 model ?
Dasha
Post Wed Mar 20, 2013 2:26 am
Illico wrote:I looked at dlna.org http://www.dlna.org/consumer-home/look- ... uct-search, but this model KDL-40X3100 was not found.
No illico There is everything but RJ45 ethernet network connection? So I guess that I am out of Luck! Strange that you couldn't find the Model listed, it was top of the range back then here is Australia :? Dasha :)
Edited add-on 0743 21-03-2013 : illico I was just wondering I can connect the Topfield 2400 Masterpiece by a Network feature Via ethenet RJ145 and that's hooked up to the Bravia would that work Dasha :D
