Playback issues on Synology and Sony Bravia
seta_sou
Post Sat Jun 08, 2013 2:49 pm
Hi, I am fairly new to Serviio and have no knowledge of codes.
I recently upgraded to 1.2.1 on my Synology DS212j. Subtitles have been enabled but the playback is extremely jerky (impossible at all to watch) - I am playing it through my Sony Bravia televisions. This is not down to my internet connection because when I try to play the same fie using the DS media server, they play perfectly fine. I am using Serviio because my Sony TVs do not show the subtitles when using the DS media server.
For certain of the files, I get the message "Temporarily cannot access the server. Please retry." Again, these files play absolutely fine through the DS media server.
I'd very much like to play my files properly through Serviio because the subtitles to me are very important. Log files attached. Grateful for any help on this. Thanks very much.
All messages.rtf
(12.04 KiB) Downloaded 465 times
Serviio.log.rtf
(3.5 KiB) Downloaded 483 times
NX3
Post Sat Jun 08, 2013 8:09 pm
Re: Playback issues on Synology and Sony Bravia
It sounds like your getting your videos transcoded and your synology has CPU isn't up to it. Most nas have a relatively weak CPU, great as a new, not really up to transcoding.
Sent from my Nexus 7 using Tapatalk 2
amk221
Post Mon Jun 10, 2013 10:36 am
I too have this issue, but on a DS213j
It is capable of transcoding, however I think Serviio sometimes does other stuff in the background like search for artwork. Once this happens, then transcoding falters.
Post Mon Jun 10, 2013 11:52 am
amk221 wrote:I too have this issue, but on a DS213j
You can disable library refresh process on console. And only enable it when you add some new files.
patters
Post Tue Jun 11, 2013 6:58 am
Hi, out of curiosity - when the NAS is not doing other stuff, can the DS213j keep up with realtime video transcoding with burning in subtitles? Since it's an ARMv7 with FPU I was hoping it would have the power to do so (thinking about upgrading to the DS114 when it comes out, which will have the same CPU). If yes, can it manage transcoding an HD stream?
