select subtitles and change audio file
bengio
Post Fri Apr 25, 2014 6:39 pm
Hi.
I cannot select subtitles or change audio format (from Dolby to DTS) on my bluray player BDP S-590 on mkv file (that inside has the subtitles and DTS and Dolby Audio files).
I push "Options" button but it shows nothing. With Server Media of Synology i can select subtitles and audio format.
How can i select on Serviio?
I installaed serviio on my NAS Synology DS213J
ServiiGo beta tester
Post Sat Apr 26, 2014 1:39 am
Re: select subtitles and change audio file
What profile are you using? My BDP-S3100 allows me to do both. I am using the "Sony BDP-Sx100 (2013)" profile. I'm not certain exactly which profile works best for yours. Since it appears your player supports the native file, I'd suggest experimenting with different Sony profiles.
bengio
Post Sat Apr 26, 2014 5:23 am
atc98092 wrote:What profile are you using? My BDP-S3100 allows me to do both. I am using the "Sony BDP-Sx100 (2013)" profile. I'm not certain exactly which profile works best for yours. Since it appears your player supports the native file, I'd suggest experimenting with different Sony profiles.
Thanks Atc.
Now with Sony BDP sx-90(2012) function subtitles and audio formats but doesn't function >> (fast forward) and <<. If I press these buttons go to the next film.... I tried different profile but fast forward function only with BDP - sx70/smp-n100(2010) profile. It's a bug?
Post Sun Apr 27, 2014 11:20 pm
Thanks Atc.
I can't say if it's a bug, since I am not familiar with the sx-x90 series of players and don't know what they are supposed to be capable of. I still have a couple of SMP-N200 players that work fine, but they don't support MKV files without transcoding, so I've never been able to select audio or CC with them. That was the big reason I moved to the BDP-S3100.
Going to have to wait for Illico to chime in on this. He's the expert on the Sony profiles.
patters
Post Mon Apr 28, 2014 11:17 pm
I have updated the Readme for BDP devices, and I have collated some links to threads with info about fixing MKV files that dont allow seeking during native playback:
viewtopic.php?f=11&t=2004&p=10965#p10965
bengio
Post Tue Apr 29, 2014 6:22 am
patters wrote:I have updated the Readme for BDP devices, and I have collated some links to threads with info about fixing MKV files that dont allow seeking during native playback:
Thanks Patters for the replay,
but i don't understood if can i something to solve this problem?
Bye
patters
Post Tue Apr 29, 2014 6:58 pm
Specifically look at these threads:
viewtopic.php?f=11&t=11181
viewtopic.php?f=11&t=16085
You should be able to fix the MKV files you are having difficulty with, but the solution is a bit technical.
