m4a files?
dougri
Post Sat Feb 12, 2011 12:19 am
m4a files?
It seems no one has had luck playing m4a files from itunes, but the format is supported as part of a video. What happens if you package the audio alongside an empty/null video? No idea how to even test this... what would I change in the profile to test this?
Post Sat Feb 12, 2011 11:37 am
Re: m4a files?
Audio transcoding is coming in 0.5.1. ATM Serviio can play those only natively - ie only if your renderer supports it.
dougri
Post Sat Feb 12, 2011 5:03 pm
Re: m4a files?
Thanks... I thought that to be the case, but had no idea what the s370 would do if it received only the audio portion of a video.
Users browsing this forum: Majestic-12 [Bot] and 48 guests
