SONY 32W706B
Speed
Post Mon Feb 02, 2015 8:56 am
SONY 32W706B
I have bought Sony 32W706b and i have install serviio 1.5 to my pc . I have problem with the external subtitles . When i check all the subtitles the options then the tv is not playing the video ,when i uncheck the subtitles the files playing normally but without subtitles . I believe that it is not a pc hardware problem cause it is i7 with 16 gb memory . Can anyone help me about ???
Post Mon Feb 02, 2015 10:51 am
Re: SONY 32W706B
Could you provide information about your file (see signature links) ?
Do you store your file on local disk (serviio server install disk) or a remote disk ?
