UT50 not detecting serviio anymore
Gormur
Post Sun Dec 21, 2014 3:01 pm
I recently changed routers and since then my UT50 only detects serviio if I turn on the tv first, then my Win 7 PC running serviio and even then my TV only has serviio available for less than a minute after which it disappears.
Even after my tv "loses" serviio, the light next to the TV's ip address in the serviio console Status window is still green like it's recognizing the tv. However after I restart my computer that same light is red.
Things I've tried:
-The ip address on my tv was fluctuating wildly so I set a static one for it
-Disabled Windows media player
-Uninstalled serviio and downloaded the newest version and installed it, thereby recreating my video library
Post Sun Dec 21, 2014 11:47 pm
Re: UT50 not detecting serviio anymore
I recently changed routers....
Look for settings on your router related to IGMP proxy or snooping or any settings to do with multicasting and/or broadcasting.
If still no joy, send through the router model and I'll see what I can find. Did you change anything else (eg. going from wired to wireless?).
panasonic
Post Tue Feb 03, 2015 5:02 am
I am having the same problem.
I am useing a thomson router.
Post Tue Feb 03, 2015 11:36 am
Return to Panasonic
