Some video files ar not detected
I´m using Serviio 1.4 with a Synology DS213 an Serviio Console on my Windows 8 PC.
Some Video files are detected and I can view them on my DLNA-TV, but not all video files.
Only video files are detected (scanned), that have a lower path depth. If there´s a deeper
path depth, serviio can´t find the video file. If I copy the same video file to a less deeper
path position, it will be scanned!
Is there a solution for this problem? Thanks!
Heaven
Heaven
