Walla Videos plugin
iplem
Post Wed Apr 25, 2012 10:58 am
Walla Videos plugin
Hi All,
Does anyone can help me creating a plugin to use with walla videos sites. I checked some groovy scripts like the cbs, but I must admit I'm a little struggle in understanding the logic behind it since I'm not aware of java/groovy programming. Any help is appreciated in creating such a plugin
Some Links Example:
Avatar Nickelodeon full episodes: http://nick.walla.co.il/?w=//1688271
Jimmy Neutron full episodes: http://nick.walla.co.il/?w=//1688220
I found in the web someone that did a plugin for xbmc, that might help
Walla: http://ilvideo.googlecode.com/svn/trunk ... New.video/
Others: http://ilvideo.googlecode.com/svn/trunk/
Post Fri Apr 27, 2012 12:47 pm
Re: Walla Videos plugin
Sorry, videos can only be watched from Israel.
iplem
Post Tue May 15, 2012 7:28 pm
I was able to develop the plugin (attached) which works well for nick and nickjr walla but I do have some issues with the Hebrew characters.
Interesting, the youtube plugin does show the Hebrew characters with no problem on the television.
Does anyone have any idea how to fix it?
Walla.groovy
(5.22 KiB) Downloaded 817 times
olli
Post Sun Jul 01, 2012 5:53 pm
iplem wrote:I was able to develop the plugin (attached) which works well for nick and nickjr walla but I do have some issues with the Hebrew characters.
Hi Iplem
Very nice plugin (although I don't understand any Hebrew ;) ) I've been interested in the Hebrew characters problem and have modified your plugin. Now it displays the right characters. But I'm not shure about the sequence of the words. At my (german language) TV they are displayed in the wrong direction (left to rigth), though are displayed rigth to left in Serviio's log files. Perhaps it's ok at a Hebrew language TV?
Greetings,
Olli
Edit: You should post your plugin in the Available Plugins forum! The world should know it :lol:
Walla.groovy
version 2 01/07/2012
(5.32 KiB) Downloaded 792 times
iplem
Post Tue Jul 03, 2012 8:40 am
Hi Olli,
Thanks a lot for the fix (and also for the code revamp :-) and yes it does show perfect on a hebrew enabled TV. I'll publish it, but first I need to check why it stop showing the items for some of the links that does before.
Iplem
olli
Post Tue Jul 03, 2012 4:26 pm
iplem wrote:Hi Olli,
Iplem
I've just tested the 2 links you have posted before. I've slightly modified the matcher patterns. Perhaps this is the problem? E.g. perhaps some series are marked by an alphanumeric code after the '?w=' inside the link? (instead of numeric code as I presumed)
Olli
iplem
Post Wed Jul 04, 2012 2:30 am
Yep, I changed the HTML_SECTION to '(?s)</h1\\s?>(.*?)wp-0-b footerNav' and now they seems to be back.
The links I tested:
http://nickjr.walla.co.il/?w=//1724551
http://nickjr.walla.co.il/?w=//2518214
http://nickjr.walla.co.il/?w=//1688299
http://nick.walla.co.il/?w=//1688134
Return to Plugin requests
