How to set a Philips 40PFL7606D?
Elvis79
Post Thu Sep 13, 2012 3:59 am
Hi!
Serviio works good on my Philips TV, but I can watch any movie with subtitles.
I´m reading that maybe with a Philips profile it can fix it.
Th TV is not recognized, is just "Unrecognized device" / "generic DLNA device".
How can I fix it? I just want to watch the movies with .srt subtitles.
Thanks!
Post Thu Sep 13, 2012 7:28 am
Re: How to set a Philips 40PFL7606D?
Elvis79
Post Thu Sep 13, 2012 9:19 pm
Thank you for the link.
This is the info from the UpnP:
http-get:*:audio/mpeg:DLNA.ORG_PN=MP3,
http-get:*:audio/L16;rate=44100;channels=2:DLNA.ORG_PN=LPCM,
http-get:*:audio/L16;rate=44100;channels=1:DLNA.ORG_PN=LPCM,
http-get:*:audio/L16;rate=48000;channels=2:DLNA.ORG_PN=LPCM,
http-get:*:audio/L16;rate=48000;channels=1:DLNA.ORG_PN=LPCM,
http-get:*:image/jpeg:DLNA.ORG_PN=JPEG_SM,
http-get:*:image/jpeg:DLNA.ORG_PN=JPEG_MED,
http-get:*:image/jpeg:DLNA.ORG_PN=JPEG_LRG,
http-get:*:image/jpeg:DLNA.ORG_PN=JPEG_SM_ICO,
http-get:*:image/jpeg:DLNA.ORG_PN=JPEG_LRG_ICO,
http-get:*:image/jpeg:DLNA.ORG_PN=JPEG_TN,
http-get:*:video/mpeg:DLNA.ORG_PN=MPEG_PS_NTSC,
http-get:*:video/mpeg:DLNA.ORG_PN=MPEG_PS_PAL,
http-get:*:video/vnd.dlna.mpeg-tts:DLNA.ORG_PN=MPEG_TS_SD_EU,
http-get:*:video/mpeg:DLNA.ORG_PN=MPEG_TS_SD_EU_ISO,
http-get:*:video/vnd.dlna.mpeg-tts:DLNA.ORG_PN=MPEG_TS_SD_EU_T,
http-get:*:audio/x-ms-asf:*,
http-get:*:audio/wav:*,
http-get:*:audio/x-ms-wma:*,
http-get:*:audio/vnd.dlna.adts:*,
http-get:*:audio/mp4:*,
http-get:*:video/x-matroska:*,
http-get:*:video/x-ms-asf:*,
http-get:*:video/x-ms-asf-plugin:*,
http-get:*:video/mpeg4:*,
http-get:*:video/avi:*,
http-get:*:video/x-ms-avi:*,
http-get:*:video/msvideo:*,
http-get:*:video/x-msvideo:*,
http-get:*:video/h264:*,
http-get:*:video/x-ms-wmv:*
What can I do now?
Thanks!
yaro
Post Fri Sep 14, 2012 1:32 am
Look again. There is already a Philips profile.
Post Fri Sep 14, 2012 9:48 am
Elvis79 wrote:This is the info from the UpnP:
Thanks, so your Philips model use the same ProtocoInfo that this one: http://wiki.serviio.org/doku.php?id=dev ... at_support
With Upnp tool, could you provide the device description xml ?
When you select Philips profile on serviio console, does it works ?
Elvis79
Post Fri Sep 14, 2012 11:36 am
Hi.
Thanks for the reply.
Now, I´m using "Philips" on profile but the subtitles does not work either.
On "Device name" is "NMR". What is this?
When I play a movie using the USB on the TV the subtitles work perfect.
Post Fri Sep 14, 2012 12:39 pm
Elvis79 wrote:When I play a movie using the USB on the TV the subtitles work perfect.
USB and DLNA are two different systems.
Elvis79
Post Fri Sep 14, 2012 5:00 pm
Thank you for the info.
So is not prossible to play movies with subtitles using DLNA on my Philips tv?
Elvis79
Post Fri Oct 26, 2012 5:06 pm
There is any option to "paste" the SRT subtitles to any movie when I'm sending the videos to my Philips Led TV with Serviio?
Thank you!
Post Sat Oct 27, 2012 12:22 pm
Elvis79 wrote:So is not prossible to play movies with subtitles using DLNA on my Philips tv?
Not sure, try to ask Philips support.
Return to Philips
