Serviio Settings and Library recreation after updates
Hi there,
first of all I would like to thank for this great application. I use Serviio now for a couple of month now and like it ever since.
The only problem I have is the issue that if I install the newest version of Serviio on my Mac, all the settings have to be renewed.
Also the amount of time to recreated the Library Status is just bugging me. To add about 1800 Items to the Library takes ages...
I read about other requests to separate some of the features to the user profile and would like to encourage you guys to find a solution for that, so any update will just work with the settings of the predecessor version, plus new features can just be added to those settings.
Do you think that would be something to check for future versions?
Thanks in advance
al
Thanks in advance
al
