Allow Last Viewed Folder to be global or per user
Moggwald
Post Sun Jan 05, 2020 8:30 am
In my house I have a few DLNA devices that all access the same Serviio server. When watching a series on one device and I want to continue watching the next I would like to be able to check this folder to see what the last episode I watched was, but I find that the last viewed folder is only for that device. It would be useful if you could put an option on the server to allow the last viewed its to be either done globally across all devices, or by user that is assigned to the device, and of course an option to keep it as it is now?
Post Sun Jan 12, 2020 8:49 pm
Re: Allow Last Viewed Folder to be global or per user
Currently is is per user. You can assign a user for each device (so then you get the effect of per device as well)
Moggwald
Post Tue Jan 14, 2020 8:40 pm
Brilliant thanks for that! I misunderstood how it works I see now.
Return to Feature requests
