macOS 26 Tahoe and 2.5
kaoskinkae
Post Mon Jun 08, 2026 4:53 pm
Version 2.4 works perfectly on macOS 26 Tahoe. However, once version 2.5 is installed, there is no network connection and the application menus do not appear, even though the latest available Java version is installed.
zman
Post Wed Jun 10, 2026 10:26 am
Re: macOS 26 Tahoe and 2.5
I've got the same problem. Java up-to-date, security settings, disk access, network settings allow Serviio. Firewall settings checked. Even if firewall is off, doesn't work at all. No sign of Serviio. One thing of interest: UMS doesn't work either. I really have no ideas. Latest Tahoe version.
One addition: commandline says I/O error when launching using
sudo launchctl load -F /Library/LaunchDaemons/org.serviio.server.plist
Load failed: 5: Input/output error
Hope anyone has the final solution... I give up.
Return to General discussion
Users browsing this forum: zman and 26 guests
