Identically Named Titles in themoviedb.org
bdushok
Post Mon Dec 14, 2015 12:05 am
I have a video file on my Serviio server which matches two titles in themoviedb.org. Serviio has selected the wrong metadata. Is there a way to indicate to Serviio which data to use?
Thanks,
Bob
Post Mon Dec 14, 2015 3:51 am
Re: Identically Named Titles in themoviedb.org
Yes, easily done - use the IMDB ID in the file name - see http://wiki.serviio.org/doku.php?id=imb ... ata_naming
(alternatively, if the movies are different years, include the year in the file name - eg. "Avengers (2012).avi")
bdushok
Post Mon Dec 14, 2015 12:18 pm
Thank you! I've added the year to the filename and the problem is solved.
Bob
Post Mon Dec 14, 2015 1:21 pm
bdushok wrote:Thank you! I've added the year to the filename and the problem is solved.
Bob
It really does work best to include the year. But what DenyAll suggested also removes all doubt which title it should be.
If you haven't seen the Filebot file naming software, I suggest looking at it. Makes naming your files easy and consistent.
