Same problem here… Just no luck with all the parameters.
I did set change the thumbnail size in the profile file from DLNA to HD, and I added a parameter to the startup parameters of the Serviio server:
-Dserviio.hdThumbnailResoultion=1200
I then went to remove all content from the server (moved the music file folder away, forced the server to refresh, restarted the server, restarted the Serviio Control app), then added all my music files back in… quite the procedure…
The results were disappointing.
I am using the Denon/Marantz HEOS app as my control point, which works quite well for me and is integrated with my receiver (which is also the renderer).
Here is a comparison from connecting to Minimserver:
- From Minimserver
- 75C1BE94-4745-4AD3-8BAE-74CF037C83FC.jpeg (77.78 KiB) Viewed 69039 times
And here is the same view, when using Serviio. I’m just looking at the white text at the bottom:
- From Serviio
- B92B2A6D-436B-4C29-B866-AF6784ADF2EF.jpeg (70.52 KiB) Viewed 69039 times
It’s easy to see that there is more potential (and, no, Minimserver does not require any configuration, it just happens - but the program has other problems…)
I wish we could be heard and Serviio updated with something that works as a “no-hands-involved” solution
