Serviio Console
tommytomato
Post Wed Oct 29, 2025 10:23 am
Serviio Console
G'day all
First off been using Serviio for many years with sharing across my network watched many videos using Serviio from Play station 4 to Xbox 360 and a Pi unit as well
I've just got access to larger drives 5TB and Im rebuilding a PC tower up, going to clone my system to a NvME drive and run it in the new tower
I'm planning in buying serviio this time as well, but I cant seem to access serviio from my command line or via the desktop like I use too, thou many updates have been done since to Ubuntu
my file paths are
this is what I did some time ago and got my info the bash file
sudo wget http://download.serviio.org/releases/serviio-2.1-linux.tar.gz
sudo tar zxvf serviio-2.1-linux.tar.gz
sudo ln -s serviio-2.1 serviio
sudo chown -R root:root /opt
sudo /opt/serviio/bin/serviio.sh
ifconfig
sudo rm serviio-2.1-linux.tar.gz
sudo vi /lib/systemd/system/serviio.service
sudo systemctl daemon-reload
sudo systemctl enable serviio.service
sudo systemctl start serviio.service
files are sitting in
/opt/serviio/bin/
and
/opt/serviio-2.1/bin/
Serviio works but I want to be able to access the Console again from the desktop to check things out before transfering to the new tower, or is it better to reinsall it ?
my errors are
Smegmedia:/opt/serviio/bin$ ./serviio.sh
log4j:ERROR setFile(null,true) call failed.
java.io.FileNotFoundException: /opt/serviio/log/serviio.log (Permission denied)
   at java.base/java.io.FileOutputStream.open0(Native Method)
   at java.base/java.io.FileOutputStream.open(FileOutputStream.java:298)
   at java.base/java.io.FileOutputStream.<init>(FileOutputStream.java:237)
   at java.base/java.io.FileOutputStream.<init>(FileOutputStream.java:158)
   at org.apache.log4j.FileAppender.setFile(FileAppender.java:294)
   at org.apache.log4j.RollingFileAppender.setFile(RollingFileAppender.java:207)
   at org.apache.log4j.FileAppender.activateOptions(FileAppender.java:165)
   at org.apache.log4j.config.PropertySetter.activate(PropertySetter.java:307)
   at org.apache.log4j.xml.DOMConfigurator.parseAppender(DOMConfigurator.java:295)
   at org.apache.log4j.xml.DOMConfigurator.findAppenderByName(DOMConfigurator.java:176)
   at org.apache.log4j.xml.DOMConfigurator.findAppenderByReference(DOMConfigurator.java:191)
   at org.apache.log4j.xml.DOMConfigurator.parseChildrenOfLoggerElement(DOMConfigurator.java:523)
   at org.apache.log4j.xml.DOMConfigurator.parseRoot(DOMConfigurator.java:492)
   at org.apache.log4j.xml.DOMConfigurator.parse(DOMConfigurator.java:1001)
   at org.apache.log4j.xml.DOMConfigurator.doConfigure(DOMConfigurator.java:867)
   at org.apache.log4j.xml.DOMConfigurator.doConfigure(DOMConfigurator.java:773)
   at org.apache.log4j.helpers.OptionConverter.selectAndConfigure(OptionConverter.java:483)
   at org.apache.log4j.LogManager.<clinit>(LogManager.java:127)
   at org.slf4j.impl.Log4jLoggerFactory.getLogger(Log4jLoggerFactory.java:66)
   at org.slf4j.LoggerFactory.getLogger(LoggerFactory.java:277)
   at org.slf4j.LoggerFactory.getLogger(LoggerFactory.java:288)
   at org.serviio.MediaServer.<clinit>(MediaServer.java:87)
any help would be great
OS is Ubuntu 20.04.6 LTS
Post Wed Oct 29, 2025 10:21 pm
Re: Serviio Console
It's been years since I've played with Linux, so I tend to get lost sometimes in the details there.
As far as reaching the Serviio console, are you looking for a console app or just using a web browser? I'm not certain Linux builds have the console app, but even on Windows I just use the web interface. From any computer on your network just access http://[Serviio IP address]:23423/console. When you're on the Serviio computer itself, just use localhost instead of the IP address.
tommytomato
Post Wed Oct 29, 2025 11:08 pm
Re: Serviio Console
I can bring up the web browser link OK for serviio but I have forgotton my details to login, it says to edit user details to do via the Console
I cant look at this stage but I think thats what it said, I have the tower out now taking to work to image the drive and transfer to the NvME drive on the new tower
Post Wed Oct 29, 2025 11:13 pm
Re: Serviio Console
The console has no login, only the MediaBrowser. The URL is slightly different for the console and MediaBrowser:
console: http://[Serviio IP address]:23423/console
MB: http://[Serviio IP address]:23424/mediabrowser
Notice the different port number (the number after the colon).
tommytomato
Post Thu Oct 30, 2025 3:42 am
Re: Serviio Console
Well I got into the browser OK and the console came up OK, thanks for that I'm on version 2.1, is it worth upgrading ? and how is it done via the command line
I had some fun trying to clone or image the system over only to find out the NvME wasn't big enough and I couldn't shrink the Ubuntu system down, so I put the 6TB into the old tower, then I had to work out my mounting issues, as I said its been some time since I've done it, any ways the drive is now mounted and up and running in the shared drives
Post Thu Oct 30, 2025 4:21 am
Re: Serviio Console
I just have to point you to the release notes for you to decide if you want the latest version. Version 2.1 is now over 5 years old, and I'm pretty sure there's some worthwhile improvements in it. https://serviio.org/news
I can't remember exactly how you update Serviio on Linux. If I remember correctly you simply unzip the main file and then copy everything over the existing install. But I can't be sure of that, so check the website for more details.
tommytomato
Post Thu Oct 30, 2025 5:51 am
Re: Serviio Console
it seems to work OK, I don't really use for any ting else other than sharing across my home net work specially Red Dwarf shows LOL
I've been looking for the Serviio GUI for ubuntu as I stated before, I remember using it but had to install java to get it going, I can't seem to find any thing on it other than an image on what it used to looking like
but as you said 5 years that's how long since I've touch this Linux box lol, its all up to date now
Post Thu Oct 30, 2025 3:16 pm
Re: Serviio Console
It's been a long, long time since I've used the console app. The web version does everything and I don't need to worry about if it's on a specific computer. :D
cmakula
Post Sat Nov 01, 2025 6:39 am
Re: Serviio Console
I was able to update from 2.2 to 2.3 by just swapping out the bin and lib directories, but I wouldn't suggest it.
Installing 2.4 only takes a few minutes. Directions are here: https://wiki.serviio.org/doku.php?id=ho ... buntu18-04
:ugeek:
Serviio Server - Dell PowerEdge R420, Dual Xeon E5-2420, 4x120 GB SSD RAID 0, 64 GB RAM (Serviio running from RAMdisk), 4 NICs (aggregated to LAN), 10Gbe to NAS, Ubuntu Server 24.04.3
NFS File Server - Synology DS1517+, 20TB disk space (5x4TB), 4 NICs (aggregated to LAN), 10Gbe to Serviio Server
tommytomato
Post Sun Nov 02, 2025 1:15 am
Re: Serviio Console
cmakula wrote:I was able to update from 2.2 to 2.3 by just swapping out the bin and lib directories, but I wouldn't suggest it.
Thanks I'll give it ago soon
thanks again
Users browsing this forum: Google [Bot] and 31 guests
