Serviio service not starting
Elvis71
Post Wed Sep 26, 2012 7:55 pm
The serviio service refuses to start. I've had this problem several times. Reinstalled Java, worked for a while but now is back.
Log file with debug info on is attached.
Cheers.
(10.44 KiB) Downloaded 533 times
Post Thu Sep 27, 2012 12:27 pm
Re: Serviio service not starting
due o this
ERROR [MediaServer] cannot start web server, exiting
No more details. I'll have a look and add some more detail output for the next version, but currently you can try to change your Java version (not necessarily the latest, as you have)
Elvis71
Post Sat Sep 29, 2012 11:25 am
I have installed Java 1.6.35 as you suggested, same issue...
INFO [MediaServer] Java 1.6.0_35-Sun Microsystems Inc.
Any other ideas?
kappclark
Post Sat Sep 29, 2012 2:24 pm
I recommend uninstalling all versions of Java, restarting compuer, then re-install Java 6 (or Java 7 which seems to work fine in XP and Windows 7)
Post Sun Sep 30, 2012 12:04 pm
MIgt be that it cannot open port 8895 on your PC? Do you have some firewall running that might prevent this?
