IE9 And Media Browser
scottyboy235
Post Thu Nov 29, 2012 6:58 pm
I have the Pro edition of Serviio (v1.0.1) and am experiencing difficulties trying to play movies in the media browser. The movie thumbnails are displayed OK but when I try to play the movies nothing happens - a spinning arrow appears and stays that way. My PC is a 64 bit Intel i7 core running IE9
I can view the movies with no problem using the following methods:
- VLC when connected to Serviio
- Smart TV when connectd to Serviio
- when connected direct to website i.e bypassing Serviio
Now if I change my browser to Chrome, then I CAN view the movies from within the Serviio media browser.
I have attached a copy of the log file for reference - nothing of any note but a few entries relating to ffmpeg - is this something to do with the IE9/media browser problem? There seems to be other threads outlining similar sounding problems
Serviio log - Partial Cop.txt
(1.17 KiB) Downloaded 528 times
Post Fri Nov 30, 2012 9:46 am
Re: IE9 And Media Browser
It looks like a problem with the Flash plugin in IE. Do you have the latest? Also do you have RealPlayer installed? It's known to interfere with certain Flash versions.
scottyboy235
Post Fri Nov 30, 2012 10:21 pm
Realplayer is not installed. I assume you are asking about the Adobe flashplayer setting, if so its: 11.5.502.110 i.e. the latest. Serviio Pro has been running on the PC for about ~1week
One thing I don't understand is where flowplayer fits into this. Is it embedded within serviio? Is it clashing with something in IE?
Other than this issue, serviio works fine for me - nice and easy to use/navigate. Folder structure for the libraries is a bit simple but I understand it will be enhanced for the next serviio release.
