Cannot connect to the server
CRIS5101
Post Wed Jul 22, 2026 1:30 pm
I have a 25“ iMac M1 running macOS Tahoe 26.5.2. After the initial installation of Servio, everything works fine. I shut down the computer, and when I open it and Servio, I get this message: ”Cannot Connect to the server, it doesn't seem to be running..."
I’ve looked into it but haven’t found a solution. What should I do? Thanks in advance for your help.
Christian
Post Wed Jul 22, 2026 9:50 pm
Re: Cannot connect to the server
The first thing to check is if the Serviio service is running. I can't tell you how to do that on a Mac. If the service is running, then you likely have a firewall issue. I'm assuming the MacOS has a default firewall like Windows does. Certain ports have to be open for Serviio to be visible on your network devices.
Return to User experiences
