MKV fails to play
kdp99
Post Thu Apr 14, 2011 7:15 pm
MKV fails to play
On Samsung C5500, some other info in the post below,
viewtopic.php?f=10&t=2234
output from ffmpeg:
686-mingw32-
libavutil 50.36. 0 / 50.36. 0
libavcore 0.16. 0 / 0.16. 0
libavfilter 1.72. 0 / 1.72. 0
libswscale 0.12. 0 / 0.12. 0
[matroska,webm @ 015ed050] max_analyze_duration reached
[matroska,webm @ 015ed050] Estimating duration from bitrate, this may be inaccur
ate
Seems stream 0 codec frame rate differs from container frame rate: 47.95 (200000
00/417083) -> 23.98 (20000000/834166)
Input #0, matroska,webm, from 'c:\bad1.mkv':
Duration: 02:26:05.29, start: 0.000000, bitrate: 1536 kb/s
Stream #0.0(eng): Video: h264, yuv420p, 1280x536 [PAR 1:1 DAR 160:67], 23.98
fps, 23.98 tbr, 1k tbn, 47.95 tbc
title : twiz-hp7part1-720p
Stream #0.1(eng): Audio: dca, 48000 Hz, 5.1, s16, 1536 kb/s
Stream #0.2: Subtitle: [0][0][0][0] / 0x0000
Post Thu Apr 14, 2011 7:44 pm
Re: MKV fails to play
That could depend on:
- h264 profile and level used
- h264 coder used and encoding options used
- library used to create mkv (mkvmerge v4.4.0) sometime due to header compression not supported by some devices.
Could you provide MediaInfo result of your file ?
kdp99
Post Thu Apr 14, 2011 9:24 pm
Here is the info for the file in question, and for another that fails
Unique ID : 210420541185349088435597614139736765874 (0x9E4D85A98B8CA5A4976C01B82AAEB5B2)
Complete name : C:\bad1.mkv
Format : Matroska
File size : 6.55 GiB
Duration : 2h 26mn
Overall bit rate : 6 423 Kbps
Encoded date : UTC 2011-03-31 15:13:28
Writing application : mkvmerge v4.4.0 ('Die Wiederkehr') built on Oct 31 2010 21:52:48
Writing library : libebml v1.0.0 + libmatroska v1.0.0
Format : AVC
Format profile : High@L4.1
Format settings, CABAC : Yes
Muxing mode : Header stripping
Codec ID : V_MPEG4/ISO/AVC
Duration : 2h 26mn
Bit rate : 4 915 Kbps
Width : 1 280 pixels
Height : 536 pixels
Display aspect ratio : 2.35:1
Frame rate : 23.976 fps
Color space : YUV
Chroma subsampling : 4:2:0
Bit depth : 8 bits
Scan type : Progressive
Bits/(Pixel*Frame) : 0.299
Stream size : 4.88 GiB (75%)
Title : twiz-hp7part1-720p
Writing library : x264 core 114 r1924 08d04a4
Encoding settings : cabac=1 / ref=5 / deblock=1:0:0 / analyse=0x3:0x133 / me=hex / subme=7 / psy=1 / psy_rd=1.00:0.00 / mixed_ref=1 / me_range=16 / chroma_me=1 / trellis=1 / 8x8dct=1 / cqm=0 / deadzone=21,11 / fast_pskip=0 / chroma_qp_offset=-2 / threads=12 / sliced_threads=0 / nr=0 / decimate=0 / interlaced=0 / constrained_intra=0 / bframes=3 / b_pyramid=2 / b_adapt=1 / b_bias=0 / direct=1 / weightb=1 / open_gop=1 / weightp=2 / keyint=250 / keyint_min=23 / scenecut=40 / intra_refresh=0 / rc_lookahead=40 / rc=2pass / mbtree=1 / bitrate=4915 / ratetol=1.0 / qcomp=0.60 / qpmin=0 / qpmax=51 / qpstep=4 / cplxblur=20.0 / qblur=0.5 / ip_ratio=1.40 / aq=1:1.00
Language : English
Format : DTS
Codec ID : A_DTS
Duration : 2h 26mn
Bit rate mode : Constant
Bit rate : 1 510 Kbps
Channel(s) : 6 channels
Sampling rate : 48.0 KHz
Bit depth : 24 bits
Compression mode : Lossy
Delay relative to video : 11ms
Stream size : 1.54 GiB (24%)
Language : English
Text
Format : UTF-8
Codec ID : S_TEXT/UTF8
Codec ID/Info : UTF-8 Plain Text
Second file info
Unique ID : 187268454421190557716331143340609285250 (0x8CE297A795AB2633A84BF4373690AC82)
Complete name : D:\video\kennedys\The.Kennedys.Part.III.720p.WEB-DL.AAC2.0.H.264-RANDi.mkv
Format : Matroska
File size : 1.30 GiB
Duration : 44mn 31s
Overall bit rate : 4 186 Kbps
Encoded date : UTC 2011-04-06 09:52:55
Format : AVC
Format profile : High@L3.1
Format settings, CABAC : No
Format settings, ReFrames : 2 frames
Format settings, GOP : M=2, N=32
Duration : 44mn 31s
Bit rate mode : Variable
Height : 720 pixels
Display aspect ratio : 16:9
Color space : YUV
Bit depth : 8 bits
Language : English
Color primaries : BT.709-5, BT.1361, IEC 61966-2-4, SMPTE RP177
Transfer characteristics : BT.709-5, BT.1361
Matrix coefficients : BT.709-5, BT.1361, IEC 61966-2-4 709, SMPTE RP177
Users browsing this forum: Baidu [Spider] and 15 guests
