Transcode to a Sony SMP-N100
pfer10
Post Sat Aug 13, 2011 10:56 pm
I have several movies that will play video fine on the Sony Media Player SMP-N100 but the audio isn't there. I am using the stock sony BD profile. I tried to edit the bd profile to add acc to matches container under audio target but that made the Serviio service not start. Edit was like below:
<Matches container="mp4" />
<Matches container="flac" />
<Matches container="ogg" />
<Matches container="aac" />
</Audio>
I think I just don't understand the transcoding setup yet in the profiles. Here is MediaInfo output from the file that plays video fine but no audio at all:
Complete name : \\Aspirehome\videos\THE_TOURIST.mp4
Format : MPEG-4
Format profile : Base Media / Version 2
Codec ID : mp42
File size : 456 MiB
Duration : 1h 43mn
Overall bit rate : 616 Kbps
Encoded date : UTC 2011-08-13 13:35:37
Tagged date : UTC 2011-08-13 13:38:18
Writing application : mp4creator 1.6.1d
Format : MPEG-4 Visual
Format profile : Simple@L1
Format settings, BVOP : No
Format settings, QPel : No
Format settings, GMC : No warppoints
Codec ID : 20
Duration : 1h 43mn
Bit rate mode : Variable
Bit rate : 488 Kbps
Maximum bit rate : 3 722 Kbps
Width : 480 pixels
Height : 272 pixels
Display aspect ratio : 16:9
Frame rate mode : Constant
Frame rate : 18.000 fps
Color space : YUV
Chroma subsampling : 4:2:0
Bit depth : 8 bits
Scan type : Progressive
Compression mode : Lossy
Bits/(Pixel*Frame) : 0.208
Stream size : 362 MiB (79%)
Language : English
Tagged date : UTC 2011-08-13 13:38:12
Material_Duration : 6209945
Material_StreamSize : 379137994
Material_FrameCount : 111779
Format : AAC
Format profile : LC
Codec ID : 40
Duration : 1h 43mn
Bit rate : 125 Kbps
Maximum bit rate : 253 Kbps
Channel(s) : 2 channels
Sampling rate : 44.1 KHz
Stream size : 92.8 MiB (20%)
Language : English
Encoded date : UTC 2011-08-13 13:38:12
Material_Duration : 6209922
Material_StreamSize : 97286085
Post Sun Aug 14, 2011 3:50 pm
Re: Transcode to a Sony SMP-N100
Audio transcode section is for AUDIO files and not video for them you need to edit the Video transcode section :)
