Cannot resolve DLNA format profile
scrambler
Post Mon Dec 27, 2010 7:35 pm
I am getting “Cannot resolve DLNA format profile of the original file: I Am Love (2009).m2ts” On a Blu ray rip which format is detailed below.
Can you tell what is not DLNA compliant in there
Complete name : F:\BLU-RAYs\I Am Love (2009) [Io sono l'amore]\I Am Love (2009).m2ts
Format : BDAV
Format/Info : Blu-ray Video
File size : 31.3 GiB
Duration : 1h 59mn
Overall bit rate : 37.6 Mbps
Maximum Overall bit rate : 48.0 Mbps
Menu ID : 1 (0x1)
Format : AVC
Format profile : High@L4.1
Format settings, CABAC : Yes
Format settings, ReFrames : 4 frames
Duration : 1h 59mn
Width : 1 920 pixels
Height : 1 080 pixels
Display aspect ratio : 16/9
Frame rate : 23.976 fps
Resolution : 24 bits
Colorimetry : 4:2:0
Scan type : Progressive
Audio #1
Menu ID : 1 (0x1)
Format : DTS
Format profile : MA
Duration : 1h 59mn
Bit rate mode : Variable
Channel(s) : 6 channels
Channel positions : Front: L C R, Surround: L R, LFE
Sampling rate : 48.0 KHz
Audio #2
Menu ID : 1 (0x1)
Format : AC-3
Format/Info : Audio Coding 3
Duration : 1h 59mn
Bit rate mode : Constant
Bit rate : 224 Kbps
Channel(s) : 2 channels
Channel positions : L R
Stream size : 191 MiB (1%)
Text #1
Menu ID : 1 (0x1)
Format : PGS
Text #2
Menu ID : 1 (0x1)
Format : PGS
Video delay : 2s 252ms
Text #3
Menu ID : 1 (0x1)
Format : PGS
Post Tue Dec 28, 2010 10:06 am
Re: Cannot resolve DLNA format profile
can you post ffmpeg -i <file> of this file?
scrambler
Post Tue Dec 28, 2010 6:50 pm
C:\Program Files\Serviio\lib>ffmpeg -i "F:\BLU-RAYs\I Am Love (2009) [Io sono l'
amore]\I Am Love (2009).m2ts"
FFmpeg version SVN-r25870-Sherpya, Copyright (c) 2000-2010 the FFmpeg developers
built on Dec 4 2010 05:23:23 with gcc 4.2.5 20090330 (prerelease) [Sherpya]
libavutil 50.33. 0 / 50.33. 0
libavcore 0.14. 0 / 0.14. 0
libavcodec 52.97. 2 / 52.97. 2
libavformat 52.87. 1 / 52.87. 1
libavdevice 52. 2. 2 / 52. 2. 2
libavfilter 1.67. 0 / 1.67. 0
libswscale 0.12. 0 / 0.12. 0
[mpegts @ 01a7d0d0] max_analyze_duration reached
[NULL @ 01b64ac0] start time is not set in av_estimate_timings_from_pts
[NULL @ 01b7d6d0] start time is not set in av_estimate_timings_from_pts
Input #0, mpegts, from 'F:\BLU-RAYs\I Am Love (2009) [Io sono l'amore]\I Am Love
(2009).m2ts':
Duration: 01:59:26.72, start: 4198.958300, bitrate: 37574 kb/s
Program 1
Stream #0.0[0x1011]: Video: h264, yuv420p, 1920x1080 [PAR 1:1 DAR 16:9], 23.
98 fps, 23.98 tbr, 90k tbn, 47.95 tbc
Stream #0.1[0x1100]: Audio: dca, 48000 Hz, 5.1, s16, 1536 kb/s
Stream #0.2[0x1101]: Audio: ac3, 48000 Hz, stereo, s16, 224 kb/s
Stream #0.3[0x1200]: Subtitle: pgssub
Stream #0.4[0x1201]: Subtitle: pgssub
Stream #0.5[0x1202]: Subtitle: pgssub
I see it says Max analysed duration reached, could it be it is not reading the whole file? The file is 33Gb.
One other interesting thing, is I ripped another Blu Ray which was also an h264 AVC in an m2ts container, and had the same dlna error, I then re did the Rip of the same h264 AVC stream but into an mkv container, and it does not give the error.
Post Wed Dec 29, 2010 10:23 am
this file type will be supported in 0.5
