mp3 transcoding?
CandyCorn
Post Sun Nov 03, 2013 4:29 pm
mp3 transcoding?
Is it possible to create a profile to transcode .mp3 files to a lower bitrate/file size for streaming over 3g? I'm new to this, but this is what I attempted:
<Profile id="AndroidPhone" name="AndroidPhone" extendsProfileId="1">
<Detection>
<HttpHeaders>
<User-Agent>.*AndroidPhone.*</User-Agent>
</HttpHeaders>
</Detection>
<Audio targetContainer="mp3" aBitrate="64">
<Matches container="mp3" />
</Audio>
<ThumbnailsResolution>HD</ThumbnailsResolution>
I was able to assign the profile to my device, but serviio did not transcode any of the files. I am using the serviigo app for android.
Post Sun Nov 03, 2013 4:44 pm
Re: mp3 transcoding?
CandyCorn wrote:Is it possible to create a profile to transcode .mp3 files to a lower bitrate/file size for streaming over 3g? I'm new to this, but this is what I attempted:
<Detection>
<HttpHeaders>
</HttpHeaders>
</Detection>
</Audio>
ServiiGo doesn't use DLNA and doesn't use profiles set in the console (as that wouldn't work when over 3G).
You will want to instead make those changes to the serviigo_standard profile in the application-profiles.xml file.
I.e. change the audio transcoding block from
   <!-- Transcode non .mp3 audio for the Media Player -->
<Audio targetContainer="mp3" forceInheritance="true" >
<Matches container="mp4" />
<Matches container="asf" />
<Matches container="lpcm" />
<Matches container="flac" />
<Matches container="ogg" />
<Matches container="flv" />
<Matches container="rtp" />
<Matches container="rtsp" />
<Matches container="adts" />
<Matches container="wavpack" />
<Matches container="mpc" />
<Matches container="ape" />
</Audio>
to something like
   <!-- Transcode everything to mp3 at 64Kbit/s for the Media Player -->
<Audio targetContainer="mp3" forceInheritance="true" aBitrate="64">
<Matches container="*" />
</Audio>
CandyCorn
Post Sun Nov 03, 2013 6:02 pm
That worked perfectly, Thanks!
