RMVB Support on LG TV
Asclus
Post Thu Jan 02, 2014 9:18 pm
Hi, first of all sorry for english.
I use serviio on my samsung led/plasma without any problems.
i buy a Tv LG 50ph4700 (2012 i think) plasma smart 3d and try to play my movies mkv/mp4/rmvb
installed the serviio 1.4.0
the problem are:
when i set to LG TV / PLAYER i can play all mkv and mp4/avi without problems with external subtitles working very well ,No rmvb/rm work in this mode, no thumbs for rmvb files are show on navigation on tv.
when i set to Samsung Tv Player (E/F) the serviio transcode the files rmvb well and i can see perfectly on tv BUT my mkv/avi dont show external subtitles only one movie show mkv emblended subtitle
i have tryed Philips / Others Samsung profiles, i try to edit profile to make serviio transcode the rmvb for my LG but no work.
Can anyone help me ?
Base URL http://192.168.1.220:1216/
Device icon None
Device URN urn:schemas-upnp-org:device:MediaRenderer:1
Embedded devices 0
Expiration timeout 1800
Friendly name [TV][LG]50PH4700-SD
Has presentation False
Interface to host 192.168.1.130
Manufacturer LG Electronics.
Manufacturer URL http://www.lge.com
Model description LG NetCast 4.0 DMRplus
Model name LG TV
Model number 4.0
Presentation URL
Product code
Proprietary type
Remote endpoint 192.168.1.220:1216
Serial number
Services 3
Standard type MediaRenderer
Unique device name e43002b5-2957-2002-c75d-205eaca83a41
Version 1.0
Post Mon Jan 06, 2014 8:39 am
Re: RMVB Support on LG TV
If I remember correctly, transcoding is commented out in the LG profile. Uncomment it and add rmvb matched, as per the Samsung profile.
Asclus
Post Tue Jan 07, 2014 4:37 pm
I try to change any line in this profile but it don´t work ,
i try to add subtitle of lg tv to samsung profiles but don´t work too
The part of LG TV are, if you can help me showing where i need to change.
<Profile id="8" name="LG TV / player" extendsProfileId="1">
<Detection>
<HttpHeaders>
<friendlyName.dlna.org>LG.*</friendlyName.dlna.org>
</HttpHeaders>
</Detection>
<!-- ResourceTransportProtocolHandler>org.serviio.upnp.protocol.http.transport.LGProtocolHandler</ResourceTransportProtocolHandler -->
<MediaFormatProfiles>
<MediaFormatProfile mime-type="video/mp4" name="">AVI</MediaFormatProfile>
</MediaFormatProfiles>
Transcoding doesn't seem to work and some files can be played natively:
viewtopic.php?f=12&t=3914#p26273
<Video targetContainer="mpegts" targetVCodec="mpeg2video" targetACodec="ac3" >
<Matches container="flv" />
<Matches container="asf" vCodec="wmv2"/>
<Matches container="rm" />
<Matches container="wtv" />
</Transcoding>-->
<HardSubsTranscoding>
<Video targetContainer="mpegts" targetVCodec="mpeg2video" targetACodec="ac3" />
</HardSubsTranscoding>
<Subtitles>
<SoftSubs mime-type="text/srt" />
</Subtitles>
Post Tue Jan 07, 2014 11:53 pm
I suggest using Notepad++ to remove the comments (Notepad++ colour codes xml files, making it easier to see where comments are). Try:
   <Detection>
      <HttpHeaders>
      </HttpHeaders>
   </Detection>
   http://forum.serviio.org/viewtopic.php?f=12&t=3914#p26273 -->
   <Subtitles>
   </Subtitles>
I haven't removed the comments on the <ResourceTransportProtocolHandler> - you may need to at some stage.
Asclus
Post Mon Mar 17, 2014 8:28 pm
DenyALL
I used the Notepad ++ and try to pasta the info that you copy here, after this the server start and stop in few seconds.
i try to copy the transcode part of profile of samsung but the same problem apear.
You have any other ideas ?
Asclus
Post Mon Mar 17, 2014 8:42 pm
Asclus wrote:DenyALL
Sorry Sorry really sorry, i tryed it today and work IT ARE WORKING FINE
my mistake, i have tryed in january but havent correct.
Thanks alot friend.
Getupsign
Post Mon Oct 24, 2016 7:34 am
Sometimes, you may encounter playback issue referring to video or audio codec.
I'm afraid you have to transcode rmvb to mp4, avi, mkv or other pop formats encoded by H.264/AAC.
Some freeware and online conversion service are recommended.
Return to LG
