Stepashka.com (Web Resource)
qanatoz
Post Tue Feb 21, 2012 5:53 pm
Stepashka.com Web Resource plugin
Source type: Web Resource
Media type: Video
Version: 4
Allows playing online movies and series from Stepashka.com forum
Changes in version 1.3
  • Fixed resource title extraction
  • Fixed extraction of links in new format
Changes in version 1.4
  • Added play lists content decryption for series
Changes in version 1.4.1
  • Fixed bug of title extraction
Changes in version 2.0
  • Added support for new title format
  • Added fix with try\catch from @ditr
  • Added versioning support
Changes in version 3.0
  • Added URL redirect support
Changes in version 4.0
  • Added support for new type series playlists
Online movie example:
Online series example:
*Note: The URL’s must be configured as a Web Resource.
Stepashka.groovy
Stepashka.com Web Resource plugin v 4.0
(8.33 KiB) Downloaded 1549 times
qanatoz
Post Sat Nov 17, 2012 11:40 pm
Re: Stepashka.com (Web Resource)
The plugin updated
qanatoz
Post Wed Nov 28, 2012 10:56 pm
The plugin updated
snexus
Post Sat Jan 12, 2013 10:14 am
Thank you for this useful plugin...However, it doesn't work for me:
Details from the log file
2013-01-12 18:10:28,043 WARN  [FeedUpdaterThread] An error occured while scanning for online item information, will continue
java.io.IOException: Unexpected error while invoking plugin (Stepashka): index is out of range 0..-1 (index = 0)
   at org.serviio.library.online.WebResourceParser.parse(WebResourceParser.java:58)
   at org.serviio.library.online.OnlineLibraryManager.findResource(OnlineLibraryManager.java:171)
Caused by: java.lang.IndexOutOfBoundsException: index is out of range 0..-1 (index = 0)
   at org.codehaus.groovy.runtime.DefaultGroovyMethods.getAt(DefaultGroovyMethods.java:6202)
   at org.codehaus.groovy.runtime.dgm$310.invoke(Unknown Source)
   at org.codehaus.groovy.runtime.callsite.PojoMetaMethodSite$PojoMetaMethodSiteNoUnwrapNoCoerce.invoke(PojoMetaMethodSite.java:271)
   at org.codehaus.groovy.runtime.callsite.PojoMetaMethodSite.call(PojoMetaMethodSite.java:53)
   at org.codehaus.groovy.runtime.callsite.AbstractCallSite.call(AbstractCallSite.java:116)
   at Stepashka.extractItems(Stepashka.groovy:37)
   at org.serviio.library.online.WebResourceUrlExtractor$1.executePluginMethod(WebResourceUrlExtractor.java:32)
   at org.serviio.library.online.WebResourceUrlExtractor$1.executePluginMethod(WebResourceUrlExtractor.java:29)
   at org.serviio.library.online.PluginExecutionProcessor$1.call(PluginExecutionProcessor.java:50)
I've added these series as a web resource:
http://online.stepashka.com/serialy/eng ... -2012.html
Looking forward for your assitance,
vsn
Post Sun Jan 13, 2013 12:49 pm
Hi there,
Exactly the same problem as snexus suffers using the following link http://online.stepashka.com/filmy/dramy/12293-temnyy-rycar-vozrozhdenie-legendy-the-dark-knight-rises-2012.html. I am using Serviio 1.1 + Stepashka 1.4, Ubuntu 10.4 and OpenJDK Java 6. Please tell me if you need more info.
PS great plugin, thanks for your job.
BR,
vsn
qanatoz
Post Sun Jan 20, 2013 9:40 pm
The plugin updated
@vsn/ @snexus
Please let me know if this version fixes the problem.
vsn
Post Tue Mar 05, 2013 8:22 pm
Hi qanatoz,
Yes, I can confirm it works now. Great job. Sorry for delay...
Btw is there any possibility to improve the quality of streaming?
Thx!
BR
VSN
qanatoz
Post Wed Mar 06, 2013 4:27 pm
Unfortunately no. :-(
There is no different quality levels inside.
vsn
Post Wed Mar 06, 2013 7:27 pm
do you feel like to develop a simular plug in for vk.com? They have a huge media collection, fast servers and goot quality. I'm not a developer, but I took a fast look at your code and it doesn't seem to be a big affort. What do you think?
BR
VSN
PS http://forum.serviio.org/viewtopic.php?f=21&t=6631
qanatoz
Post Sat Mar 09, 2013 1:00 pm
vsn wrote:do you feel like to develop a simular plug in for vk.com? They have a huge media collection, fast servers and goot quality. I'm not a developer, but I took a fast look at your code and it doesn't seem to be a big affort. What do you think?
I'm not familiar with VK.com site.
Did it require user authentication to watch videos?
Can you post some links examples? I will take a look.
vsn
Post Sun Mar 10, 2013 7:08 pm
qanatoz wrote:Did it require user authentication to watch videos?
regarding authentication - yes, but there are some ways how to handle it.
Try with this one
http://vk.com/video_ext.php?oid=25977524&id=161038916&hash=8445b0cf2091a72d&hd=3
As you can see video id, user id, hash and video qulity are defind in the link.
Good luck!
ditr
Post Tue Mar 19, 2013 5:47 am
qanatoz - many thanks for plugin. Just thought may be it makes sense to add try-catch around webResourceTitle so even if it fails the moive will work. Better experience than everything after some movie that has broken html page (or whatever else can be the cause) just not being added/played at all.
ditr
Post Tue Mar 19, 2013 7:49 am
A quick patch for "out of bounds" I started to get a day ago. Shall be backward compatible too
21c21
<  * @version 1.4.2
>  * @version 1.4.1
25c25
<     final static WEB_RESOURCE_TITLE                         = /(?s)<h1 class=\"?btl\"?>(.*?)<\/h1>/
>     final static WEB_RESOURCE_TITLE                         = /(?s)<h1 class=\"btl\">(.*?)<\/h1>/
39,44c39
<         String webResourceTitle;
<         try {
<             webResourceTitle = (((pageSource =~ WEB_RESOURCE_TITLE)[0]-null)[-1]).trim()
<         } catch (Exception ex) {
<             webResourceTitle = "Unknown title";
>         String webResourceTitle =(((pageSource =~ WEB_RESOURCE_TITLE)[0]-null)[-1]).trim()
In_vain
Post Fri Mar 22, 2013 1:27 am
I'm new in Serviio. And have 0 experience in Java.
Could you please explain how to apply this patch?
In_vain
Post Sat Mar 23, 2013 1:08 pm
Never mind. Figured out.
qanatoz
Post Mon Mar 25, 2013 11:00 am
Plugin updated.
rimidalvr1966
Post Fri Mar 29, 2013 12:24 am
Have the same problem as snexus and vsn. Downloaded new plugin, added http://online.stepashka.com/god-2013/25 ... -2013.html as web resource and still no go.Here is my log
2013-03-28 19:23:25,758 WARN [FeedUpdaterThread] An error occured while scanning for online item information, will continue
java.io.IOException: Unexpected error while invoking plugin (Stepashka): assert videoResources.size() > 0
| 0 false
java.util.regex.Matcher[pattern=(?s)(&amp;|&)pl=(.*?)" region=0,96074 lastmatch=]
Caused by: Assertion failed:
| 0 false
at org.codehaus.groovy.runtime.InvokerHelper.assertFailed(InvokerHelper.java:386)
at org.codehaus.groovy.runtime.ScriptBytecodeAdapter.assertFailed(ScriptBytecodeAdapter.java:658)
at Stepashka.extractItems(Stepashka.groovy:55)
at java.util.concurrent.FutureTask$Sync.innerRun(Unknown Source)
at java.util.concurrent.FutureTask.run(Unknown Source)
at java.util.concurrent.ThreadPoolExecutor.runWorker(Unknown Source)
at java.util.concurrent.ThreadPoolExecutor$Worker.run(Unknown Source)
at java.lang.Thread.run(Unknown Source)
What did I do wrong? Thank you.
P.S. Forgot to mention, I use Serviio 1.2.1 if it makes any difference.
Thank you.
ditr
Post Mon May 06, 2013 8:09 am
You are probably watching series. They recently shuffled some file locations on server and old locations are now returning redirects, that plugin doesn't support. As a workaround before fix - get your url, paste it into browser, you'll see that when it opens the url is changed and is now different. Re-add your series with new url.
Or if you feel adventurous apply this diff
--- stepashka.groovy    2013-03-25 03:53:44.000000000 -0700
+++ stepashka.groovy.new        2013-05-06 01:07:31.717540179 -0700
@@ -68,18 +68,35 @@
     private String openURL(URL url){
-        Request request = new Request(Method.GET, url.toString());
         Client client = new Client(Protocol.HTTP);
         ClientInfo info = new ClientInfo();
         info.setAgent(USER_AGENT);
-        request.setClientInfo(info);
-        Response response = client.handle(request);
-        String orPageSource
-        if(Status.SUCCESS_OK.equals(response.getStatus())){
-            return response.getEntityAsText()
+        Response response = null;
+        int followed = 0;
+        while (response == null && followed < 10) {
+            log("Retrieving URL " + url.toString());
+            Request request = new Request(Method.GET, url.toString());
+            request.setClientInfo(info);
+            response = client.handle(request);
+            String orPageSource
+            if(Status.SUCCESS_OK.equals(response.getStatus())){
+                return response.getEntityAsText()
+            } else if (
+                Status.REDIRECTION_PERMANENT.equals(response.getStatus()) ||
+                Status.REDIRECTION_TEMPORARY.equals(response.getStatus()) ||
+                Status.REDIRECTION_FOUND.equals(response.getStatus())
+                url = response.getLocationRef().toUrl();
+                response = null;
+                log("Is redirect to " + url.toString());
+            } else  {
+                break;
+            ++followed;
         return ""
      * Finds all actual video links and titles in received data
      * @param data to search
by running copy-pasting this into stepashka.groovy.patch and doing
patch stepashka.groovy < stepashka.groovy.patch
There is probably better way of following redirects in java restlets, but I never encountered them before so this is pretty much quick and dirty fix.
ditr
Post Mon May 06, 2013 8:11 am
P.S. qanatoz - does it make sense to put this on GutHub so it will be easier to open issues, do pull requests etc?
qanatoz
Post Sat Jun 01, 2013 5:09 pm
Plugin updated
Hi @ditr,
I not think that it's making some sense to put one, small file to version control :)
Return to Available plugins
