Linux Daemon scripts
irlaird
Post Thu Dec 10, 2009 5:43 pm
Serviio Daemon Start/Stop script/Conf for Linux
Im sure someone has already done this but i didnt see it on the forums so i thought i would help out the next guy.
NOTE:
Make sure you update DAEMON="/bin/serviio" to point to the serviio.sh start script. I made sym link to it but it requires more modifications. :D
File: /etc/conf.d/serviiod
#- Daemon Script Configuration for Serviio Media Server
#- By Ian Laird
#- /etc/conf.d/serviiod
NAME="Serviio Media Server"
DAEMON="/bin/serviio"    ## Update this to point at pc5dczc_root/bin/serviio.sh
SERVICE_ACCOUNT="root" ## DON'T RUN UNDER ROOT!
File: /etc/init.d/serviiod
#!/sbin/runscript
#- Daemon script for Serviio media server
#- By Ian Laird
#- /etc/init.d/serviiod
PIDFILE="/var/run/serviiod.pid"
DAEMON_STOP=" -stop"
[ -x $DAEMON ] || exit 0
start() {
        ebegin "Starting $NAME"
        start-stop-daemon --start -q -b -p $PIDFILE -m -c ${SERVICE_ACCOUNT} -x ${DAEMON}
        eend $?
stop() {
        ebegin "Stopping $NAME"
        ${DAEMON} -stop
        start-stop-daemon --stop -p $PIDFILE
        eend $?
Post Thu Dec 10, 2009 6:15 pm
Re: Linux Daemon scripts
Cool, I'll probably copy this into FAQ or something.
Qkxy
Post Fri Dec 11, 2009 7:59 pm
Hi!
I made this script for serviio 0.2 on OpenSuSE 11.2:
/etc/init.d/serviio
#! /bin/sh
# Copyright (c) 2009 Zoltan Kukk
# Author: zoltan.kukk@gmail.com
# /etc/init.d/serviio
### BEGIN INIT INFO
# Provides: serviio
# Required-Start: $network
# Required-Stop: $network
# Default-Start: 3 5
# Default-Stop: 0 1 2 6
# Description: Start the serviio DLNA server in headless mode
### END INIT INFO
SERVIIO_BIN=/usr/bin/serviio
test -x $SERVIIO_BIN || { echo "$SERVIIO_BIN not installed";
        if [ "$1" = "stop" ]; then exit 0;
        else exit 5; fi; }
# Load the rc.status script for this service.
. /etc/rc.status
# Shell functions sourced from /etc/rc.status:
#      rc_check         check and set local and overall rc status
#      rc_status        check and set local and overall rc status
#      rc_status -v     ditto but be verbose in local rc status
#      rc_status -v -r  ditto and clear the local rc status
#      rc_failed        set local and overall rc status to failed
#      rc_reset         clear local rc status (overall remains)
#      rc_exit          exit appropriate to overall rc status
# First reset status of this service
rc_reset
case "$1" in
    start)
   echo -n "Starting Serviio DLNA server"
   ## Start daemon with startproc(8). If this fails
   ## the echo return value is set appropriate.
   startproc -f -u nobody -g video -l /var/log/serviio.log $SERVIIO_BIN -headless
   # Remember status and be verbose
   rc_status -v
    start-gui)
        rc_status -v
    stop)
   echo -n "Shutting down Serviio DLNA daemon"
   ## Stop daemon with killproc(8) and if this fails
   ## set echo the echo return value.
   startproc -f -u nobody -g video -l /var/log/serviio.log $SERVIIO_BIN -stop
   rc_status -v
    try-restart)
        ## Stop the service and if this succeeds (i.e. the
        ## service was running before), start it again.
        $0 status >/dev/null &&  $0 restart
        # Remember status and be quiet
        rc_status
    restart)
        ## Stop the service and regardless of whether it was
        ## running or not, start it again.
        $0 stop
        $0 start
        rc_status
    force-reload|reload)
   ## Signal the daemon to reload its config. Most daemons
   ## do this on signal 1 (SIGHUP).
   echo -n "Reload Serviio DLNA server"
        rc_failed 3
        rc_status -v
    status)
   echo -n "Checking for service serviio "
        ## Check status with checkproc(8), if process is running
        ## checkproc will return with exit status 0.
        # Status has a slightly different for the status command:
        # 0 - service running
        # 1 - service dead, but /var/run/  pid  file exists
        # 2 - service dead, but /var/lock/ lock file exists
        # 3 - service not running
        # NOTE: checkproc returns LSB compliant status values.
        checkproc $SERVIIO_BIN
        # NOTE: rc_status knows that we called this init script with
        # "status" option and adapts its messages accordingly.
        rc_status -v
    probe)
   ## Optional: Probe for the necessity of a reload,
   ## give out the argument which is required for a reload.
   echo "Usage: $0 {start|stop|status|try-restart|restart|force-reload|reload|probe}"
   exit 1
esac
rc_exit
Set Serviio owner (My video files owned by video group):
chown -R nobody:video /path_to_pc5dczc_root
Symlinks:
ln -s /path_to_pc5dczc_root/bin/serviio.sh /usr/bin/serviio
ln -s /etc/init.d/serviio /sbin/rcserviio
Set up running on default runlevel:
/sbin/insserv /etc/init.d/serviio
Samsung LE40B650T2W - SQ04 - 2009/09/30_002005
OpenSuSE 11.2
Serviio 0.3
NX3
Post Fri Jan 28, 2011 12:49 pm
For anyone on Ubuntu 10.10 you won't find /etc/conf.d/ on your system. However to get Serviio to start automatically is really easy as under the administration menu you'll find 'Startup Applications'. Select that and then just add the scripts files, you can browse to where ever you saved them. Next time you reboot Serviio just starts :-D
jopiexjoker
Post Tue Feb 01, 2011 6:50 pm
NX3 wrote:For anyone on Ubuntu 10.10 you won't find /etc/conf.d/ on your system. However to get Serviio to start automatically is really easy as under the administration menu you'll find 'Startup Applications'. Select that and then just add the scripts files, you can browse to where ever you saved them. Next time you reboot Serviio just starts :-D
It starts before log in?
Post Tue Feb 01, 2011 7:40 pm
Qkxy wrote:Hi!
/etc/init.d/serviio
#! /bin/sh
### BEGIN INIT INFO
# Provides: serviio
### END INIT INFO
        else exit 5; fi; }
. /etc/rc.status
rc_reset
case "$1" in
    start)
   rc_status -v
    start-gui)
        rc_status -v
    stop)
   rc_status -v
    try-restart)
        rc_status
    restart)
        $0 stop
        $0 start
        rc_status
        rc_failed 3
        rc_status -v
    status)
        rc_status -v
    probe)
   exit 1
esac
rc_exit
Symlinks:
i so love you for this post u have save me about 4 hours worth of work as im building a serviio linux build and this will help alot :)
jtl
Post Thu Feb 03, 2011 2:13 am
Debian Squeeze wants a little different init script. Also, -halt does not work for me (it behaves just like without the argument, i.e. if the server is already running, it will stay running, and if it is already stopped, it will be started up). I've updated Ian Laird's script to handle these two issues.
Copy Ian's config file (above) into /etc/default (Debian's path for such things). Update the user and path values. Then you can use this:
#!/bin/sh
#- By Ian Laird; converted for Debian by Jacob Lundberg
### BEGIN INIT INFO
# Provides:          serviio
# Required-Start:    $local_fs $remote_fs $network $syslog
# Required-Stop:     $local_fs $remote_fs $network $syslog
# Default-Start:     2 3 4 5
# Default-Stop:      0 1 6
# X-Interactive:     true
# Short-Description: Start/stop serviio media server
# Description:       The Serviio media server makes your media available to
#                    all kinds of networked devices.
### END INIT INFO
. /lib/lsb/init-functions
if [ -f /etc/default/rcS ]; then
        . /etc/default/rcS
fi
NAME="$(basename $0)"
TIMEOUT=10
if [ -f /etc/default/serviio ]; then
        . /etc/default/serviio
fi
[ -x "$DAEMON" ] || exit 0
running() {
        if [ "x$1" == "x" ]; then
                echo 0
                return 1
        fi
        PS=$(ps h -p $(echo $1 | sed -r 's/[\t \n]+/ -p /') | wc -l)
        echo $PS
        if [ $PS -gt 0 ]; then
                return 0
        else
                return 1
        fi
start() {
        log_daemon_msg "Starting Serviio media server daemon" "$NAME"
        start-stop-daemon --start -q -b -p "$PIDFILE" -m -c "${SERVICE_ACCOUNT}" -x "${DAEMON}"
        log_end_msg $?
stop() {
        log_daemon_msg "Stopping Serviio media server daemon" "$NAME"
        if [ -r "$PIDFILE" ]; then
                PIDS=$(pstree -p $(<"$PIDFILE") | awk -F'[\(\)]' '/^[A-Za-z0-9]/ { print $2" "$4; }')
                if running "$PIDS" > /dev/null; then
                        "${DAEMON}" "${DAEMON_STOP}"
                        for PID in $PIDS; do
                                if running $PID > /dev/null; then
                                        kill -TERM $PID
                                fi
                        done
                fi
                COUNTDOWN=$TIMEOUT
                while let COUNTDOWN--; do
                        if ! running "$PIDS" > /dev/null; then
                                break
                        fi
                        if [ $COUNTDOWN -eq 0 ]; then
                                                kill -KILL $PID
                                        fi
                                done
                        else
                                echo -n .
                                sleep 1
                        fi
                done
        fi
                log_end_msg 1
        else
                rm -f "$PIDFILE"
                log_end_msg $?
        fi
status() {
        echo -n "$NAME should be"
                echo -n " up with primary PID $(<"$PIDFILE")"
                RUNNING=$(running "$PIDS")
                if [[ $RUNNING && $RUNNING -gt 0 ]]; then
                        echo -n " and $RUNNING processes are running."
                else
                        echo -n " but it is not running."
                fi
        else
                echo -n " stopped."
        fi
        echo
case "${1:-}" in
        start)
                start
        stop)
                stop
        restart)
                stop
                start
        status)
                status
                log_success_msg "Usage: /etc/init.d/$NAME {start|stop|restart|status}"
                exit 1
esac
exit 0
Finally, to install the init script so it is automatic, run this as root:
update-rc.d serviio defaults
NX3
Post Fri Feb 04, 2011 4:07 pm
No it doesn't but I'm an Ubuntu newbie, 10.10 doesn't have a /etc/conf.d/ so I was stuck and the best solution for now. If anyone could post how to get it working without that file and pre-login ?
jopiexjoker
Post Fri Feb 04, 2011 6:40 pm
I hope the debian script in the reply above yours does the trick, because ubuntu is a debianbased distribution. I'll try it out soon.
jopiexjoker
Post Sat Feb 05, 2011 6:37 pm
For all you ubuntu lovers, like myself... I've combined above scripts and got it to work in ubuntu 10.10.
Make the configfile /etc/default/serviio
#- By Ian Laird
#- /etc/default/serviio
DAEMON="/usr/share/serviio/bin/serviio.sh"    ## Update this to point at pc5dczc_root/bin/serviio.sh
SERVICE_ACCOUNT="username"                       ## change to an appropriate username, DON'T RUN UNDER ROOT!
Then make the script /etc/init.d/serviio like this:
#!/bin/bash
#- By Ian Laird; converted for Debian by Jacob Lundbergand edited by Jopie
### BEGIN INIT INFO
# Provides:          serviio
### END INIT INFO
        . /etc/default/rcS
fi
TIMEOUT=10
fi
running() {
                echo 0
                return 1
        fi
        echo $PS
                return 0
        else
                return 1
        fi
start() {
        log_end_msg $?
stop() {
                                        kill -TERM $PID
                                fi
                        done
                fi
                COUNTDOWN=$TIMEOUT
                                break
                        fi
                                                kill -KILL $PID
                                        fi
                                done
                        else
                                echo -n .
                                sleep 1
                        fi
                done
        fi
                log_end_msg 1
        else
                rm -f "$PIDFILE"
                log_end_msg $?
        fi
status() {
                else
                fi
        else
                echo -n " stopped."
        fi
        echo
case "${1:-}" in
        start)
                start
        stop)
                stop
        restart)
                stop
                start
        status)
                status
                exit 1
esac
exit 0
Make it executable:
$sudo chmod 755 /etc/init.d/serviio
then run:
$sudo update-rc.d serviio defaults
all credits go to Ian and Jtl. I merely combined it to work under ubuntu.
edit: changed #!/bin/sh to #!/bin/bash, because i got an error on stopping the daemon...
thekat
Post Tue Feb 22, 2011 2:18 am
Thanks for the scripts.. !!
I found Serviio on the Ubuntu forums while searching on how to fix another player..
0.5 is a great improvement ..
tk
Luke
Post Sun Mar 06, 2011 9:40 am
Qkxy wrote:Hi!
/etc/init.d/serviio
#! /bin/sh
### BEGIN INIT INFO
# Provides: serviio
### END INIT INFO
        else exit 5; fi; }
. /etc/rc.status
rc_reset
case "$1" in
    start)
   rc_status -v
    start-gui)
        rc_status -v
    stop)
   rc_status -v
    try-restart)
        rc_status
    restart)
        $0 stop
        $0 start
        rc_status
        rc_failed 3
        rc_status -v
    status)
        rc_status -v
    probe)
   exit 1
esac
rc_exit
Symlinks:
With this script, serviio is starting with US-ASCII setting. I have added these lines after rc_reset to set it back to UTF8 (otherwise, serviio doesn't loading non-Ascii filenames, which is a real problem for me):
    rc_reset
    # Set up correct LANG
   test -f /etc/sysconfig/language && . /etc/sysconfig/language
   export LC_ALL="$RC_LC_ALL"
   export LC_CTYPE="$RC_LC_CTYPE"
   export LANG="$RC_LANG"
MulletBoy
Post Sat Mar 12, 2011 6:53 am
hi,
iv been using serviio for a while on a windows box but today changed that to a ubuntu 10.04 lucid lynx box
i am an experianced windows user but first time linux
i have downloaded serviio, and extracted it, its currently sitting on my desktop....
can someone please help me put it in the right stop and setup these scripts.... iv tried going to the locations listed in the above posts ... but i get permission denied errors when i try to create files in those directoiwa
like ect/default for example is owner "root"
from my reading i think i need to use sudo commands to do all this.... but i have no idea how to make those commands...
any help would be greatly appreciated,
Post Sat Mar 12, 2011 8:03 am
MulletBoy wrote:hi,
Ubuntu Tutorial: viewtopic.php?f=5&t=1605&start=10
Post Sat Mar 26, 2011 10:59 pm
jopiexjoker wrote:For all you ubuntu lovers, like myself... I've combined above scripts and got it to work in ubuntu 10.10.
#- By Ian Laird
#!/bin/bash
### BEGIN INIT INFO
# Provides:          serviio
### END INIT INFO
        . /etc/default/rcS
fi
TIMEOUT=10
fi
running() {
                echo 0
                return 1
        fi
        echo $PS
                return 0
        else
                return 1
        fi
start() {
        log_end_msg $?
stop() {
                                        kill -TERM $PID
                                fi
                        done
                fi
                COUNTDOWN=$TIMEOUT
                                break
                        fi
                                                kill -KILL $PID
                                        fi
                                done
                        else
                                echo -n .
                                sleep 1
                        fi
                done
        fi
                log_end_msg 1
        else
                rm -f "$PIDFILE"
                log_end_msg $?
        fi
status() {
                else
                fi
        else
                echo -n " stopped."
        fi
        echo
case "${1:-}" in
        start)
                start
        stop)
                stop
        restart)
                stop
                start
        status)
                status
                exit 1
esac
exit 0
Make it executable:
then run:
when I try to run the /etc/init.d/serviio under the normal run level I get.
* Starting Serviio media server daemon Serviio Media Server [ OK ]
mark@server:~$ start-stop-daemon: Unable to open pidfile '/var/run/serviiod.pid' for writing: Permission denied (Permission denied)
If I run it with sudo it works fine. I know a little about linux and learning more each day, since I started this ubuntu server.
when it run this way, I cannot use the windows serviio console client to see the server anymore. I could when I ran the /bin/serviio-sh file.
Post Tue Apr 05, 2011 5:06 pm
Ray
Post Mon Apr 11, 2011 3:39 pm
Did anyone find a solution for Ubuntu 10.10 above
"when I try to run the /etc/init.d/serviio under the normal run level I get.
mark@server:~$ start-stop-daemon: Unable to open pidfile '/var/run/serviiod.pid' for writing: Permission denied (Permission denied)"
I don't want to run with root privileges, so i ended up doing the following:
chmod +w /etc/init.d/serviio
But this still leaves an error on stopping the daemon. (Can't delete the file).
Is there a neater solution?
Thx.
Post Tue Apr 12, 2011 11:57 am
Ray wrote:Did anyone find a solution for Ubuntu 10.10 above
Thx.
try there dev site ;)
iglooc00l
Post Sat Apr 16, 2011 7:34 pm
1) Use sudo to create a pid file with the name "serviiod.pid" in the /var/run directory.
2) Give the user account you're running the script as (specified earlier) the ability to modify the pid file (chown it).
3) issue sudo /etc/init.d/serviio start
Should see no errors..
Ig
kc1
Post Tue Jun 07, 2011 10:15 am
jtl wrote:Debian Squeeze wants a little different init script. Also, -halt does not work for me (it behaves just like without the argument, i.e. if the server is already running, it will stay running, and if it is already stopped, it will be started up). I've updated Ian Laird's script to handle these two issues.
Copy Ian's config file (above) into /etc/default (Debian's path for such things). Update the user and path values. Then you can use this...
Hi I'm trying to figure out how to have Serviio start automatically on my ReadyNAS NXV.
I think the version of linux it's running is Debian (cat /etc/issue.net returns GNU/Linux 4.0, and uname -r returns 2.6.37.5.RNx86_32.1.1). Would that mean I could do it the same as for your "Debian Squeeze" example?
Trying to get Serviio working with Samsung D7000 and ReadyNas NVX without a PC in between
