How do i enable flv transcoding for LG TV?
• Page 1 of 2 • 1, 2
My LG TV can't play .flv files so i need help how to enable transcoding for that file. I'm no pro user so go easy please =)
Re: How do i enable flv transcoding for LG TV?
This is a local or online flv streaming ?
Local files from my HD.
You can edit LG profile (profile.xml) like this:
But it seems that Transcoding doesn't work with LG TV...
- Code:
<Profile id="8" name="LG TV / player" extendsProfileId="1">
<Detection>
<HttpHeaders>
<friendlyName.dlna.org>LG.*</friendlyName.dlna.org>
</HttpHeaders>
</Detection>
<MediaFormatProfiles>
<MediaFormatProfile mime-type="video/mp4" name="">AVI</MediaFormatProfile>
</MediaFormatProfiles>
<!--Transcoding doesn't seem to work and some files can be played natively:
http://forum.serviio.org/viewtopic.php?f=12&t=3914#p26273 -->
<Video targetContainer="mpegts" targetACodec="mp3">
<Matches container="matroska" aCodec="ac3" />
<Video targetContainer="mpegts" targetVCodec="mpeg2video" targetACodec="ac3" >
<Matches container="avi" vCodec="msmpeg4"/>
<Matches container="flv" />
Thanks! that worked just fine.
I have another file format that the LG don't support (.wmv) so i tried to add that also but Seriio service kept refusing to start so i had to figure out why... some sort of crash log i've read about in the forum. Yep, after some more searching i found that you need to name it .asf. Now Serviio starts up again, and i can transcode .wmv files also =)
It looks like this now if anyone else needs it:
- Code:
<Detection>
<HttpHeaders>
</HttpHeaders>
</Detection>
<Matches container="asf" />
Great!
For information, could you provide protocolInfo result of your device ? http://wiki.serviio.org/doku.php?id=device_sf
Could you also provide some elements like <modelNumber>,<friendlyname>,etc from device description xml with the upnp tools?
Okies, heres goes; ... i see now that wmv is mentioned in there but it will not play those directly.
- Code:
http-get:*:audio/l16;rate=44100;channels=1:DLNA.ORG_PN=LPCM,
http-get:*:audio/l16;rate=44100;channels=2:DLNA.ORG_PN=LPCM,
http-get:*:audio/mpeg:DLNA.ORG_PN=MP3,
http-get:*:image/jpeg:DLNA.ORG_PN=JPEG_SM,
http-get:*:image/jpeg:DLNA.ORG_PN=JPEG_MED,
http-get:*:image/jpeg:DLNA.ORG_PN=JPEG_LRG,
http-get:*:video/mpeg:DLNA.ORG_PN=MPEG_PS_PAL,
http-get:*:video/mpeg:DLNA.ORG_PN=MPEG_PS_NTSC,
http-get:*:video/vnd.dlna.mpeg-tts:DLNA.ORG_PN=MPEG_TS_SD_NA,
http-get:*:video/vnd.dlna.mpeg-tts:DLNA.ORG_PN=MPEG_TS_SD_NA_T,
http-get:*:video/mpeg:DLNA.ORG_PN=MPEG_TS_SD_NA_ISO,
http-get:*:video/vnd.dlna.mpeg-tts:DLNA.ORG_PN=MPEG_TS_SD_KO,
http-get:*:video/vnd.dlna.mpeg-tts:DLNA.ORG_PN=MPEG_TS_SD_KO_T,
http-get:*:video/mpeg:DLNA.ORG_PN=MPEG_TS_SD_KO_ISO,
http-get:*:video/vnd.dlna.mpeg-tts:DLNA.ORG_PN=MPEG_TS_SD_EU,
http-get:*:video/vnd.dlna.mpeg-tts:DLNA.ORG_PN=MPEG_TS_SD_EU_T,
http-get:*:video/mpeg:DLNA.ORG_PN=MPEG_TS_SD_EU_ISO,
http-get:*:audio/mpegurl:*,
http-get:*:audio/mp3:*,
http-get:*:audio/mpeg:*,
http-get:*:audio/mpeg3:*,
http-get:*:video/x-ms-wmv:*,
http-get:*:video/x-ms-asf:*,
http-get:*:video/x-ms-avi:*,
http-get:*:video/mpeg:*,
http-get:*:video/avi:*,
http-get:*:video/mp4:*,
http-get:*:video/x-matroska:*,
http-get:*:video/3gpp:*,
http-get:*:video/x-msvideo:*
Thanks,
That is the same than "LG Smart TVs " : http://wiki.serviio.org/doku.php?id=dev ... at_support
According to information, your TV should support WMV in native format (no need to transcode)
Do you have another information about format supported (usermanual) ?
Could you provide information about your wmv file ? (ffmpeg -i <file>)
Yeah, you are right'ish. I had some other wmv files that actually worked directly. But the one i tried first do not work. So there might be some wierd stuff going on with that file.
Here is the results from that file: (fl_intro.wmv taken from Freelancer game)
- Code:
c:\Program Files\Serviio\lib>ffmpeg -i fl_intro.wmv
configuration: --enable-static --disable-shared --disable-ffplay --disable-ffserver --enable-memalign-hack --enable-libmp3lame --enable-librtmp --extra-libs='-lrtmp -lpolarssl -lws2_32 -lwinmm' --arch=x86 --enable-runtime-cpudetect --enable-pthreads --target-os=mingw32 --cross-prefix=i686-w64-mingw32- --pkg-config=pkg-config
Guessed Channel Layout for Input Stream #0.0 : stereo
Input #0, asf, from 'fl_intro.wmv':
ToolName : Windows Media Encoding Utility
ToolVersion : 8.00.00.0343
VBR Peak : 2127.00.0343
Buffer Average : 5241.00.0343
Duration: 00:03:46.76, start: 0.000000, bitrate: 1374 kb/s
Stream #0:0: Audio: wmav2 (a[1][0][0] / 0x0161), 44100 Hz, stereo, s16, 64 kb/s
Stream #0:1: Video: wmv2 (WMV2 / 0x32564D57), yuv420p, 720x480, 29.97 tbr, 1k tbn, 1k tbc
Seems to be a standard asf/wmv2/wmav2, don't know what is the problem.
Could you provide MediaInfo tool result (in text format) ?
Does the other wmv files are similar asf/wmv2/wmav2 format?
Btw, <Matches container="flv" /> should be added for the next serviio release.
So these two files are asf/wmv2/wmav2 and are not supported by your TV model.
What are the format of others wmv files that are supported by your TV?
Spookyy wrote:...I had some other wmv files that actually worked directly. But the one i tried first do not work...
Spookyy wrote:These 2 worked directly:
These files are asf/vc1/wma2 supported in native format, so we can edit the profile like this :
- asf/vc1/wma2 will be delivered in native format
- asf/wmv2/* will be transcoded
- Code:
<Detection>
<HttpHeaders>
</HttpHeaders>
</Detection>
<Matches container="asf" vCodec="wmv2"/>
Great! Thanks for all the help.
Zip, do you think that could be added to the next realease ?
It worked okay when i tried those changes so i guess so =)
I have a video file that i downloaded from youtube and it's called *.webm. Is there a way for Serviio to transcode that video format?
Spookyy wrote:I have a video file that i downloaded from youtube and it's called *.webm. Is there a way for Serviio to transcode that video format?
Rename it to .mkv and try then.
Petr
Help translate Serviio
I get "file is invalid" when doing that.
I noticed some .mkv movies fails with "unsupported audio" error.
Spookyy wrote:I get "file is invalid" when doing that.
Could yo provide information about these *.webm and mkv files ?
